Dead battery after 2.5 weeks
Old 02-09-2009, 02:46 PM   #81
shortbus driver
richard schumacher's Avatar
Default Re: Dead battery after 2.5 weeks
True, the US is actually on the metric system (the inch is legally defined as 25.4 mm, and the second is an SI unit), so the problem must be with those old Imperial seconds.
richard schumacher is offline
Old 02-11-2009, 03:31 AM   #82
Thumbs up Re: Dead battery after 2.5 weeks
My Fluke can take basic recordings. I have access to an AEMC power quality analyser that can be used for detailed, long term power quality analysis
I really don't care about voltages at the inverter or front of the car. I'm concerned about voltages at the rear of the car, where the 12 vdc battery is. I think it's pretty conclusive with the lower charge voltage in Ready, and the distance to the back of the car, once the aux battery gets discharged, it *must* be manually charged
My first winter with my Prius, 15 minute city commutes, with headlights on, max heat, electric rear defrost, at -40, the aux battery slowly lost its charge. It got to the point in the undergrond parking at my old condo, when I would power on, the auto headlights would dim to a yellow glow as the coolant transfer pump ran.
I knew I had to go away for about a month on a business trip. I got a VDC Battery Minder, took the battery out of the Prius, and left it in my suite with the Battery Minder hooked up. When I took the battery out, my Fluke claimed 12.2 vdc, call it almost dead
I returned after about 2.5 weeks, and the Prius behaved much better. With the freshly charged battery in, the auto headlights barely flickered when I powered on. I used the VDC supplied ring terminals to make a permanent connection to the aux battery, and got in the habit of plugging in the Prius overnight
It's going on 5 years now, the battery is still very strong
Jayman: Since replacing my 12v Aux. Battery, now over a month of same, same driving (no fancy hypermiling for this leadfoot!), my mileage has increased from approx. 36-38mpg to 43 - 44mpg. I plug the puppy into my BMW Battery Minder overnight and
S H A Z A A M, AWESOME MILEAGE (in comparison).
FYI, I drive approx. 15 miles round trip each morning to drop my kids off at school then back to my office. Ambient winter night temps are in the high 20 to low 30 degree (F) and days are in the high 30's and low 40's, so I use the heater, defroster, lights, the whole shebang.
My guess is that due to the shortness of time that I drive during the day didn't allow sufficient time for the 12v Aux Battery to recharge, causing it to get weaker and weaker over time... Not to mention the average 80 -100 degree Fahrenheit days in the summer and 60 + degree F nights in the summer. A Perfect Storm for really messing up the 12v Aux BATT.
DID I MENTION THAT I'M HAPPIER THAN A Chocaholic at a Candy Convention!!!
Go Prius!
Thanks again to all!
Ken
05 Mil. Silver</span> w/Custom Rear Hatch Leather Pull-Down Strap,
Custom High Mount Stop Light-Light Stopper,Custom Custom Center Console Power Mod, <span style=\'colorurple\'>Custom Non-Green Color, Non-Auto Dimming, Non-Home Link Day Night Inside Rear View Mirror (Think '94 525 BMW), Custom MFD Beep-Free Upgraded JBL Parallel Audio System, Custom Key/Stuff Stopper between two front seats, All Weather Mats All The Way Around, Custom Black Ice and Headlamp ON "Band-Aids"... Custom Coastal EV Mod, Mudflaps and Engine Block Heater, Coastal Receiver Hitch (Uninstalled)... Now 44mpg average (thanks to EV Mode & Driver Training) in somewhat hilly So. Oregon. Driving the Evolution.
kenkneeb is offline
Old 03-11-2009, 01:36 AM   #83
Well, the honeymoon didn't last more than 4 weeks and my once stellar mileage has decline from approx. 43mpg back down to 38- 40mpg with similar ambient temps, same gas, same driving loops & same Battery Tender topping off the Aux. battery. I don't know what to think now!!! I was so pleased with the momentus increase in mpg from, what I inferred, was the replacement of the Aux/Starting Battery.
Anybody care to venture a guess as to why the mileage peaked so strongly after I replaced the Aux/Starter Batt???
Thanks, Ken
kenkneeb is offline
Old 03-11-2009, 08:57 AM   #84
DIY Enthusiast
Patrick Wong's Avatar
Friends: 59
How are you measuring mpg? Are you logging odometer miles driven and gallons purchased? Or are you relying on the MFD display?
If the latter, then note that the MFD display can change over time as more data is accumulated by the complex system that drives that readout. This is reset when the 12V battery is disconnected.
Patrick Wong is offline
Old 03-12-2009, 02:38 PM   #85
Friends: 16
Ken
Am unsure why. I've never noticed any difference using a Battery minder on any of my equipment. That is, not any difference in fuel economy.
For the rest of the equipment, the starter cranks much more strongly than before, and the equipment is much easier to start up
jay
jayman is offline
Old 04-22-2009, 12:22 AM   #86
A Wimpy DIYer
2009Prius's Avatar
Friends: 22
Question Re: Dead battery after 2.5 weeks
Would a 10 day period of no driving hurt the 12V battery at all? Thanks!
2009Prius is offline
Old 04-22-2009, 08:51 AM   #87
jdenenberg's Avatar
Friends: 16
With a new 12v battery in good condition and fully charged, 10 days should not cause a problem. Just shut off the system to unlock the car without pressing buttons (if you have it) as it does put a noticeable drain when the car is not being used. There is a button under the steering column that turns this function on/off.
Most of the discussion here is about long-term maintenance of the little 12v battery and a "Battery Minder" or "Battery Tender" does a good job of maintaining both the state-of-charge (SOC) and prevent/reduce the level of sulfate on the battery plates which is a major cause of failure in lead-acid batteries. One of these units is a good idea if either you are going to leave your car unused for longer periods or tend to do a lot of short trips (the Prius built-in charging system does not rapidly charge the 12v battery).
There is a simple procedure to test the health of your 12v battery. I have documented it in several of these discussions. You can see the procedure at:
Checking 12v Battery Health - Hybrid Car Forums
It is also documented at
http://www.elearnaid.com/12vo1topraub.html
which sells high quality replacement batteries for the Prius.
JeffD - Engineering Professor
MakesMeLookSmart - My 2004 Prius
jdenenberg is offline
Thanked by:
2009Prius (04-22-2009)
battery, dead, weeks
Battery drains at 2 weeks? newmexjohn Gen II Prius Care, Maintenance and Troubleshooting 8 01-26-2009 06:20 PM
Dead Battery ReneGS Gen II Prius Main Forum 21 03-17-2007 05:02 PM
Dead Battery Rick Grahn Gen II Prius Care, Maintenance and Troubleshooting 29 11-19-2006 07:35 AM
Dead 12 V Battery Andrew Szolnoki Gen II Prius Care, Maintenance and Troubleshooting 8 10-18-2005 01:45 PM
Dead battery? Got JBL? TSB for new Amp! naterprius Gen II Prius Care, Maintenance and Troubleshooting 3 08-06-2005 07:46 PM
