| This is a discussion on MFD issues on '04/'05 Prius within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by F8L Look in the driver's side door jamb and find the build date for your Prius. It ... |
| | LinkBack (18) | Thread Tools |
| | #221 |
My Car: 2004 Prius Model: N/A Package: #6 Thanks: 93
Friends: 0 | He probably meant, what constitutes early/late for this problem. The TSB explicilty lists the range of affected VINs; as I recall it went into April of 2005. |
| | #222 | |
| Junior Member Join Date: May 2009
My Car: 2004 Prius Model: N/A Package: N/A Thanks: 0
patsparks, You're very fortunate to have an electronic repair person custom repair something for $25. Most of the electronic repair people that I've been associated with just want to swap out boards rather than actually go in fix the problem part. | |
| | #223 | |
My Car: 2004 Prius Model: N/A Package: Base Thanks: 108
Friends: 33 | Quote:
Ask your local computer shop if they know someone who fixes stuff by repairing damaged boards etc. I got sent from one shop to another then another and that shop put me onto Harry the tech with an actual soldering iron and a microscope. He also has a video microscope so I could see his work, beautiful!! Remember, Hobbit has done all the hard work doing the diagnostics and you can tell the tech you won't put any responsibility on them if the repair doesn't work. $25 was Harry's minimum price for a repair. He was an interesting guy to talk to as well. Does a lot of work for the mining industry in remote locations, he has his own plane to get to work. | |
| | #224 |
Friends: 0 | Well, I just completed and shipped off my first for-pay repair. A totally "textbook" [?!] pin-60 crack: _ http://techno-fandom.org/~hobbit/car...524rs-ck01.jpg _ http://techno-fandom.org/~hobbit/car...526rs-ck02.jpg There were also some suspicious-looking areas on some of the other connections so I wound up reflowing several more of them and a couple on the other side of the connector too. . Remember that these pins are only about the width of two or three human hairs... . On this one I noticed that due to the way the MFD frame parts are stamped, it is possible that the upper board winds up being slightly stressed toward one corner -- coincidentally, *away* from the pin 60 corner of the connector which would have a tendency to try and pull that corner up. By "biasing" the play around various screws before tightening them down I was able to neutralize this shift and have the upper board sit squarely over the lower one, which will hopefully keep the problem from recurring long-term. In extreme cases it might even make sense to ream out the non-threaded parts of some holes to give the whole thing a little more play. This is a new factor I didn't notice in the original analysis, but may be relevant for others doing their own fixes as more and more '04 etc units succumb to the pounding of economic-downturn-driven road maintenance degradation. . _H* |
| | #225 |
My Car: 2004 Prius Model: Package: B Thanks: 32
Friends: 12 | ![]() I gotta admit, an Uber Geek like you makes me feel pretty unworthy Agree with your assessments, but a couple of questions: What are you using for reflow? I've got a handle on a slightly used hot air reflow station - thank you downturn in the economy You really do need a stereo microscope to work on a lot of these teeny parts, or maybe my eyes are getting worse. do you use the headband-style magnifier or a genuine stereo microscope? |
| | #226 |
Friends: 0 | I've got a genuine 20x and 30x stereo microscope, which is also how the "vignetted" pictures were shot, *and* a head-mounted "old man" style flip-down magnifier for the more generic stuff. I forget where I got the scope, but it's fairly old and I had to add a top-light to it to make it actually useful. There's a picture of it in the original MFD page. I'd love a pair of those flexible fiber illuminators that sometimes go along with them. . Reflow is maybe the wrong word; it's straightforward touch-up with a small weller tip "extended" with a bit of something like 22 ga copper wire wound around it. That and the thinnest solder I have. It's a little dicey but I wait for a while until after the coffee wears off and I can be reasonably steady in there. . _H* |
| | #227 |
Friends: 12 | Geez, you ARE a techno-stud I'm trying to determine if I can write-off a Nikon stereo scope, the model I'm considering is around $4,300. No way in hell I'd buy something like that if I can't write it off Do you think a air reflow might be better for that sort of work? My track record for pencil solder rework/touchup is iffy. I was able to play with a Madell air reflow station, and was VERY impressed with it. I was also very impressed with the estimated $9 G's price tag too As far as coffee shakes, try heavy drinking. That seemed to work for me
__________________ 2007 Toyota FJ Cruiser 5AT "C", Sun Fusion |
| | #228 | |
| Junior Member Join Date: Apr 2008 Location: Las Vegas, NV / Cedar Hills, UT
My Car: 2008 Prius Model: N/A Package: #6 Thanks: 2
Now in my case, I am such a terrific mechanic that I have found over the years that I can reassemble devices (mechanical and electronic) and not need nearly as many parts as was originally used to put the device together | |
| | #229 | |
I was once such a great mechanic, I overhauled a Ford 3 speed gearbox, had a thrust washer left over. The gearbox lasted until the first downshift. It was my own gearbox! Ouch! | |
| | #230 | |
Friends: 12 | Quote:
Around 5 years ago when I put the PowerTrax LockRight POWERTRAX® TRACTION SYSTEM in the Ford work truck rear axle at my hobby farm, I buttoned everything up and then found this tiny spring. To properly position the engagement and disengagement, each half has four recesses with four springs. Actually, a large spring with a smaller spring inside. For some reason, one of the smaller springs managed to escape on me. Having accidently destroyed stuff in my youth due to not checking things over (An oil pump relief spring on a Chevy motor, a cone washer on a transmission, the list goes on) I knew better, and tore everything apart again | |
| ཀ or ཁ, issues, mfd, prius |
| Prius Phonebook Issues | Tadashi | Gen II Prius Audio and Electronics | 24 | 03-18-2009 09:34 PM |
| Maintenance issues with 1st generation Prius? | paulccullen | Gen II Prius Care, Maintenance and Troubleshooting | 5 | 11-06-2007 06:06 PM |
| New Prius' Paneling Alignment Issues | Ryn01599 | Gen II Prius Main Forum | 4 | 07-20-2006 06:36 PM |
| Al Gore on his Prius & earth issues | Danny | Prius and Hybrid News | 62 | 06-25-2006 07:33 AM |
| Only 3% of Prius Owners have maintenance issues | Danny | Prius and Hybrid News | 8 | 10-30-2005 10:32 AM |
