This is a discussion on MFD issues on '04/'05 Prius within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Ok, I've found a stereo store claiming total experience in dismantling the dashboard, guy said, prius? my favorite car, and ...
LinkBack (18) Thread Tools
Old 09-30-2009, 09:03 PM   #241
artie
Default Re: MFD issues on '04/'05 Prius
Ok, I've found a stereo store claiming total experience in dismantling the dashboard, guy said, prius? my favorite car, and i've found a computer tech who owns an 08 prius and whose mom has an 04 whose mfd failed whilst still in warranty and so dealer replaced it, but he said no problemo, he'd love to solder the thing, and i emailed him the link to hobbit's great treatise on mfd diagnosis and repair, and so tomorrow i'll be doing what you did. thanks.
one question, you say one can drive the car w/out the mfd but that "you need to reassemble the rest of the dash", hopefully that will be easy enuf to do, and then it has to be dessembled to re-install the mfd and then reassembled once again, right? hopefully that will not be too tedious for the stereo shop to do.
i'll let you know what happens next. (at this point guestimated cost is $50.)
artie is offline
Old 09-30-2009, 10:09 PM   #242
patsparks
An Aussie perspective
patsparks's Avatar
Friends: 33
Putting the dash together and pulling it apart is 10 - 15 minutes work if you take your time once you have done it a couple times. Apart from the screws holding the MFD there are only 2 others on the driver's side down low, the rest is clips, and click together wire harnesses.
patsparks is offline
Old 10-02-2009, 01:52 AM   #243
fatdawg
FYI, I just performed this cleanup to fix the problem, under this post by northwichita - search for "intermittent mfd display fixed cleaning circuit board" (I am unable to post URLs).
It worked great! The teardown, cleanup, re-install took under 2 hours. Give it a try if you don't have a good the proper tools to solder the connectors. Only tool required was a phllips screw driver, size 10 socket with extension, and the DeoxIT cleaner kit.
Readup and good luck, I will update if things break down again.
a
fatdawg is offline
The Following User Says Thank You to fatdawg For This Useful Post:
Boo (10-02-2009)
Old 10-02-2009, 02:32 AM   #244
Boo
Boola Boola Member
Boo's Avatar
Friends: 22
a
Thanks fatdawg.
This is an important but very long thread. So it's worth pointing out here that hobbit's pioneering work and fix of this MFD issue is set forth in Post #46 of this thread.
Boo is offline
Old 10-02-2009, 01:45 PM   #245
fatdawg
Originally Posted by Boo View Post
Thanks fatdawg.
Thanks boo, hobbit's work is also quoted on the other link I mentioned, I give him full credit he's due, however, I also would like to give credit to northwichita for the cleanup idea.
fatdawg is offline
Old 10-02-2009, 01:53 PM   #246
artie
Well, here in San Diego, I found the stereo guy, the pc solder guy, in and out in one day...and it works fine! I paid about $60 altogether.
Fingers crossed it stays that way, thanks to this board, hobbit, patsparks and my prius
artie is offline
Old 10-08-2009, 09:04 AM   #247
xunkn0vvnx
Hi there, I live in Southern California, but the Long Beach area to be exact. Does anyone know anybody here that can fix my MFD problem as well?
Also, can you provide the contact details for the San Diego, stereo guy, pc solder guy that can fix this problem for me? Thanks.
xunkn0vvnx is offline
Old 10-08-2009, 09:14 AM   #248
patsparks
patsparks's Avatar
Friends: 33
Nothing is as satisfying as doing it yourself, here is how.
Really, click here, it is worth the look.
Mine is still going strong near 2 years and 60,000 kilometres later.
Old 10-08-2009, 09:27 AM   #249
patsparks
patsparks's Avatar
Friends: 33
My repair is 18+ months old and going strong, uncross those fingers now.
Old 10-09-2009, 05:08 PM   #250
artie
In San Diego, I used San Diego Car Stereo on Convoy, Christopher Doom, 858-569-0777 to R & R the unit, and West at Laptops Plus in Santee, CA at 619-596-2141,
art
artie is offline
ཀ or ཁ, issues, mfd, prius
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/33923-mfd-issues-04-05-prius.html
Touchscreen problems This thread Refback 09-30-2009 08:52 AM
Mi Toyota Prius - Averķa en el DISPLAY - Prius 2004/2005/2006/2007/2008/2009 This thread Refback 07-16-2009 06:58 PM
Datsun Z 240Z Parts, 240Z Triple Carbs, Best Carburator For 240Z - Thorogoodboots This thread Refback 03-14-2009 09:24 AM
Motor Swap Honda Civic, Jdm Honda Civic Si, Honda Civic Type S - Justtires This thread Refback 03-14-2009 05:59 AM
Toyota Of Lompoc, Toyota Of Greer, Toyota Mini Motorhome - Kias This thread Refback 03-09-2009 08:16 AM
Nissan 300Zx Timing, Nissan 300Zx Or Datsun 240Z Ownership, Nissan 300Zx V8 - Husabergparts This thread Refback 03-08-2009 06:28 AM
Prius MFD This thread Refback 02-01-2009 12:39 PM
CanadianDriver Green Reviews Used Vehicle Review: Toyota Prius, 2004 - 2008 This thread Refback 01-29-2009 01:23 AM
The display panel on our 2004 Toyota Prius doesn't work? - Yahoo! Answers This thread Refback 12-23-2008 06:09 PM
The display panel on our 2004 Toyota Prius doesn't work? - Yahoo! Answers This thread Refback 11-23-2008 12:15 AM
The display panel on our 2004 Toyota Prius doesn't work? - Yahoo! Answers This thread Refback 11-23-2008 12:01 AM
Re: Artie's Prius Problems!! - The Mainstreamers This thread Refback 06-01-2008 06:28 PM
Artie's Prius Problems!! - The Mainstreamers - Car and Driver Forums This thread Refback 05-18-2008 10:44 PM
Prius MFD This thread Refback 05-07-2008 04:38 AM
Re: Artie's Prius Problems!! - The Mainstreamers - Car and Driver Forums This thread Refback 05-05-2008 08:58 AM
Re: Artie's Prius Problems!! - The Mainstreamers - Car and Driver Forums This thread Refback 04-23-2008 04:14 AM
Prius MFD This thread Refback 04-08-2008 12:55 PM
Lights failed on me today - GreenHybrid - Hybrid Cars This thread Refback 03-07-2008 08:30 AM
Prius Phonebook Issues Tadashi Gen II Prius Audio and Electronics 24 03-18-2009 09:34 PM
Maintenance issues with 1st generation Prius? paulccullen Gen II Prius Care, Maintenance and Troubleshooting 5 11-06-2007 06:06 PM
New Prius' Paneling Alignment Issues Ryn01599 Gen II Prius Main Forum 4 07-20-2006 06:36 PM
Al Gore on his Prius & earth issues Danny Prius and Hybrid News 62 06-25-2006 07:33 AM
Only 3% of Prius Owners have maintenance issues Danny Prius and Hybrid News 8 10-30-2005 10:32 AM
