This is a discussion on MFD issues on '04/'05 Prius within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Yep, you're right Jay. Booking reading lessons as we speak....
LinkBack (18) Thread Tools
Old 10-19-2009, 08:32 PM   #261
patsparks
An Aussie perspective
patsparks's Avatar
Friends: 33
Default Re: MFD issues on '04/'05 Prius
patsparks is online now
Old 10-21-2009, 05:15 PM   #262
fatdawg
The clean-only method lasted for about 2 weeks, when the car sat idle for 4 days during vacation, the problem started up again. Therefore I thought I'd give the soldering a try, per instructions given by hobbit.
Cheap tools will work, if you feel adventurous, you can fix it for $10-$15. Luckily I had all these old tools in my toolbox.
I used a cheap old soldering gun, copper wire (hammered down to make the end sharp), solder, and a magnifying glass (unable to see details but helped). It worked! I haven't soldered anything for a long time, re-flowing the connections was fairly easy, I did 4 of the connections next to #60.
Good luck to those who want to try it out.
fatdawg is offline
Old 10-21-2009, 07:29 PM   #263
patsparks
patsparks's Avatar
Friends: 33
Further confirming my thoughts: - MFD issues on '04/'05 Prius
Old 10-25-2009, 01:54 AM   #264
HTMLSpinnr
Gen III Forums Moderator
HTMLSpinnr's Avatar
Friends: 18
I used to sit back and say "Wow, I'm glad that hasn't happened to me...".
I've noticed over the past 6-9 months that our 2004's MFD was a bit sluggish at times. Now starting a few days ago, my wife's been reporting the same "external system not connected" errors, along with missing NAV voice, etc. She finally left the car on for me so I could see the issue in action. Seems to be after the car has been in the heat for some time. At 117k miles, it'd far past any warranty. Sounds like I may be attempting to solder, or doing some eBay bidding for a used MFD.
Rick Johnson - Prius Expert/Gen III Forums Moderator
His: Gen III 2010 Prius - Blizzard Pearl Prius IV w/ Solar - 6.3k miles - (First in SW Region!) - 2010 Photos - Mods: Curt Hitch, Toyota Premium Horn, Illuminated Door Sills
Hers: Gen II 2004 - Tideland Green Pearl #9 - 117.6K miles - Mods: Bridgestone Ecopia Tires, Homemade mesh foglamp grills
Past: Gen I 2002 - Blue Moon Pearl - Mods: Costal hitch
I am not employed by Toyota, and the opinions expressed by me as a Prius Expert are not those of Toyota.
HTMLSpinnr is offline
Old 10-25-2009, 11:28 PM   #265
HTMLSpinnr
HTMLSpinnr's Avatar
Friends: 18
Pulled the screen out today, soldered on one plug, realized it was the wrong board, then went at the correct board. Took Hobbit's idea of a wire on the tip of my cheap 30w soldering iron. It, and a pin to keep the solder out from between the connectors seemed to work. It doesn't take much solder (I too used the good 'ol non RoHS 60/40) to get the job done. Kinda wish I had steadier hands and more than a 2x magnification on my wife's Ott-Lite, but managed anyway. The test points are quite useful in checking continuity of your work, but you need good clean tips on your multi-meter.
One thing worth noting is to be aware of the alignment of the frame when putting it back together. There's room for adjustment and allowing it to fit incorrectly angles the screen incorrectly, leaving a nasty gap between the beazel and the screen.
I sorta cheated getting to the screen, didn't remove all panels left to right, but instead loosened them up just enough to get the 10mm socket wrench in to remove the left bolt.
Only time will tell how long this "fix" will hold. Thanks again to Hobbit for digging into this.
Old 10-25-2009, 11:35 PM   #266
djasonw
You guys are adventuresome and handy. I have two left thumbs so I have 1 more year of extended warranty on my 2004. I hope something happens before then!!
djasonw is online now
ཀ or ཁ, issues, mfd, prius
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/33923-mfd-issues-04-05-prius.html
Touchscreen problems This thread Refback 09-30-2009 08:52 AM
Mi Toyota Prius - Averķa en el DISPLAY - Prius 2004/2005/2006/2007/2008/2009 This thread Refback 07-16-2009 06:58 PM
Datsun Z 240Z Parts, 240Z Triple Carbs, Best Carburator For 240Z - Thorogoodboots This thread Refback 03-14-2009 09:24 AM
Motor Swap Honda Civic, Jdm Honda Civic Si, Honda Civic Type S - Justtires This thread Refback 03-14-2009 05:59 AM
Toyota Of Lompoc, Toyota Of Greer, Toyota Mini Motorhome - Kias This thread Refback 03-09-2009 08:16 AM
Nissan 300Zx Timing, Nissan 300Zx Or Datsun 240Z Ownership, Nissan 300Zx V8 - Husabergparts This thread Refback 03-08-2009 06:28 AM
Prius MFD This thread Refback 02-01-2009 12:39 PM
CanadianDriver Green Reviews Used Vehicle Review: Toyota Prius, 2004 - 2008 This thread Refback 01-29-2009 01:23 AM
The display panel on our 2004 Toyota Prius doesn't work? - Yahoo! Answers This thread Refback 12-23-2008 06:09 PM
The display panel on our 2004 Toyota Prius doesn't work? - Yahoo! Answers This thread Refback 11-23-2008 12:15 AM
The display panel on our 2004 Toyota Prius doesn't work? - Yahoo! Answers This thread Refback 11-23-2008 12:01 AM
Re: Artie's Prius Problems!! - The Mainstreamers This thread Refback 06-01-2008 06:28 PM
Artie's Prius Problems!! - The Mainstreamers - Car and Driver Forums This thread Refback 05-18-2008 10:44 PM
Prius MFD This thread Refback 05-07-2008 04:38 AM
Re: Artie's Prius Problems!! - The Mainstreamers - Car and Driver Forums This thread Refback 05-05-2008 08:58 AM
Re: Artie's Prius Problems!! - The Mainstreamers - Car and Driver Forums This thread Refback 04-23-2008 04:14 AM
Prius MFD This thread Refback 04-08-2008 12:55 PM
Lights failed on me today - GreenHybrid - Hybrid Cars This thread Refback 03-07-2008 08:30 AM
Prius Phonebook Issues Tadashi Gen II Prius Audio and Electronics 24 03-18-2009 09:34 PM
Maintenance issues with 1st generation Prius? paulccullen Gen II Prius Care, Maintenance and Troubleshooting 5 11-06-2007 06:06 PM
New Prius' Paneling Alignment Issues Ryn01599 Gen II Prius Main Forum 4 07-20-2006 06:36 PM
Al Gore on his Prius & earth issues Danny Prius and Hybrid News 62 06-25-2006 07:33 AM
Only 3% of Prius Owners have maintenance issues Danny Prius and Hybrid News 8 10-30-2005 10:32 AM
