| This is a discussion on 2007 Prius engine ticking noise within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hello, I'm noticing a ticking noise from the engine during normal acceleration proabably at around 25-35 mph. Wondering if this ... |
#1 |
Friends: 0 | Hello, I'm noticing a ticking noise from the engine during normal acceleration proabably at around 25-35 mph. Wondering if this is normal. Thanks! |
My Car: 2006 Prius Model: Package: #7 Thanks: 94
Friends: 10 | Are you sure it's engine noise and not the brake accumulator pump? Tom |
Friends: 0 | <div class='quotetop'>QUOTE(qbee42 @ Jun 27 2007, 07:58 PM) [snapback]469179[/snapback]</div> Quote:
Friends: 10 | <div class='quotetop'>QUOTE(aktam @ Jun 28 2007, 12:07 PM) [snapback]469443[/snapback]</div> Quote:
Tom | |
Friends: 0 | <div class='quotetop'>QUOTE(qbee42 @ Jun 28 2007, 11:41 AM) [snapback]469553[/snapback]</div> Quote:
| Artist In Residence Join Date: Jul 2006 Location: Newton, MA
Friends: 7 | All sorts of weird noises are normal. Don't sweat it unless it breaks down |
Friends: 12 | My Prius never makes any sort of clatter or ticking noise, except idling and you have to open the hood to really listen for it. Even running 0W-20, the motor sounds happy at idle. The FJ makes more of a rattle at idle, apparently there is a check valve in the PWM purge valve. An easy fix for that is to unbolt the PWM valve and isolate it from the intake manifold. I did that with mine and the annoying ticking/tapping sound disappeared. |
My Car: 2004 Prius Model: Package: #9 Thanks: 1
Friends: 0 | In the last week or so I've noticed a distinct tick sound when the car is idling, which has been at the start of driving when it's too cold to stop the ICE at the light. It gets louder once I accelerate, but is lost in the road noise soon after. I googled a bit and manifold leaks are supposed to sound like that, but I'm not sure at what point I'll see some drop in power or MPGs as the sign the dealer should look at it. 63,500 or so as of this week. And while I did only notice it once the radio was accidentally left off, I doubt I missed it all this time just because I usually have the volume up rather high. Is there anything the might have been muffling the noise that might have worked its way loose?...
__________________ 2004 Seaside #9/BC as of 1/3/2004 Oil now any GOOD synthetic I can get on sale Michelin Hydroedge 195/65R15 tires since 2/5/2009 ![]() 90,000 miles as of 8/15/2009 |
Friends: 26 | any chance you've put premium gas in it? |
Friends: 0 | <div class='quotetop'>QUOTE(galaxee @ Jul 3 2007, 11:39 PM) [snapback]472729[/snapback]</div> Quote:
I did add some Lucas Oil gas additive well over two weeks ago, but I expect that to be long gone. I guess when something bad happens I'll be primed for it. Not today: 49.9MPG on the 16-mile drive back from getting gas after seeing "Transformers"... | |
| 2007, engine, noise, prius, ticking |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/34274-2007-prius-engine-ticking-noise.html | ||||
| PriusOnline.com • View topic - Whining noise from left-front corner | This thread | Refback | 08-23-2009 12:14 AM | |
| 2007' Prius clicking noise in front end/dash? | voi9 | Gen II Prius Technical Discussion | 14 | 11-22-2007 12:27 PM |
| Check Engine Light 2007 Prius | rlafosse | Gen II Prius Care, Maintenance and Troubleshooting | 3 | 10-02-2007 01:35 PM |
| engine noise 01 Prius | jbondman871 | Gen II Prius Care, Maintenance and Troubleshooting | 0 | 09-28-2007 08:23 AM |
| ENGINE NOISE 2007 PRIUS | srichardson1958 | Gen II Prius Care, Maintenance and Troubleshooting | 1 | 08-21-2007 02:53 PM |
| Spooling / ticking noise? | pshady | Gen II Prius Main Forum | 22 | 09-23-2004 09:48 PM |
