This is a discussion on Headlight problem within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hello Sarah: When they do work, the HIDs give very good visibility, better than most regular car lights. However, sometimes ...
Headlight problem
LinkBack (59) Thread Tools
Old 06-29-2009, 11:21 PM   #511
yardman 49
yardman 49's Avatar
Default Re: Headlight problem
Hello Sarah:
However, sometimes we are seeing reports that they are not adjusted properly from the factory(vertical angle set too low). Mine were that way, until I adjusted them. Then they performed very well, doing an excellent job of lighting up the roadway.
There are some threads here on the forums that describe how to make this adjustment. Or you can take it to a shop and have them adjust them.
Best wishes,
Frank
yardman 49 is offline
Old 06-30-2009, 01:41 AM   #512
yorkeyng
yorkeyng's Avatar
Skip the dealer and contact Toyota directly either via email from their website or give them a call. Explain the situation to them and they'll understand--from what I've been told when I contacted them, they're well aware of the headlight issue with the 2006 MY. In fact, they didn't even ask me to go to the dealer for any diagnostics, they accepted my complaint without any verification and hooked me up with a local dealer to get the lights replaced. They paid for the lights and I paid for the labor, which came to just $40 for both lights.
Good luck!
Originally Posted by captpg View Post
Hello, and many thanks to the posters who contributed previously to this thread. Very helpful in dealing with with what appears to be some rather outrageous conduct by Toyota and its dealers with respect to this by now very well documented problem.
Does anyone have any experience or advice in how to handle the situation where the Toyota dealer denies being able to find anything wrong with the HIDs in their diagnosis? I suspect their diagnosis is incorrect, because police officers have twice issued my teenage daughter tickets for driving without her lights on. (Unfortunately, each time she didn't check the lights until after the officer had left and discovered to her confusion that the lights appeared to be working just fine). Is there a specific diagnostic test that will reveal the problem or are are the options just to wait until they burn out completely and not to drive at night until then? (I'm not really sure that is an option . . . .)
Thanks in advance for any insight and advice.
Captpg
2006 Prius Package 6
with HID Lights (sometimes)
yorkeyng is offline
Old 06-30-2009, 11:37 AM   #513
BShanahan14rulz
Has any of you tried upgrading the power harness for the headlights? I would say give thicker wiring. This thread has 51 pages, that definitely means a problem of some sort. I would look into finding an HID harness. Perhaps what is going on is that the ballast isn't getting enough current to keep the bulb lit.
BShanahan14rulz is offline
Old 06-30-2009, 12:37 PM   #514
windstrings
Certified Prius Breeder
windstrings's Avatar
Welcome to the Forum.....
Hid's are quite efficient, meaning they do allot with the power they have. A 35W HID will produce many more lumens than a 35W Halogen for instance.
My point being, they are not pulling that much power.
If the wires were too small, the problem would have been consistent from driving off the showroom floor till now.
However, as discussed a ways back on this thread, there may be some internal resistance in the bulb that gets created from impure components aging with the heat/cooling process over time. Everything from poor grade copper to the material in the bulb that gets vaporized as it goes into a plasma state is subject to having impurities and being more vulnerable to time.
In most cases, simply replacing the bulb does the trick.
IN those cases, problems such as ballasts or wires being too small would not have gone away and so the problem should not go away either.. but since it does with a new bulb, logic suggests the vulnerability is either the bulb, or the OEM supplied bulbs don't match the regulated power of the ballast well and so die prematurely.
If the voltage is too low "or" too high, the bulb could die prematurely.
So is the root problem the bulb or the ballast?... don't know.. but a new bulb fixes the problem.
I have been running on ebay bulbs "69.00 for two" for over 20, maybe 30K miles now and doing well in "both" of my 06 priuses.
So you tell me?
My suspicion is the bulb.... I think as the impurities start oxidizing over time, it takes more and more voltage to keep the fire a burning... a refire by turning the switch off and back on hits it again with a fresh high voltage blast to get it going again "while already very hot" and that keeps it going till it finally craters again....
Finally the impurites overwhelm the ability of the bulb to maintain the runtime even after refiring.
This is just my speculation.
Alan
________________________
2010 Blue Ribbon Metallic IV with Bisque leather...."My Blue Baby"
And my "other" cars......
2006 Barcelona Red Prius Pkg #8 with Bisque leather.... Yea Baby, Yea! "The Hot Tamale"
2006 Silver Pine Mica Pkg#8 with Bisque leather.... "The Mint Julip"
2006 Mods so far:
1. Coastal EV switch 2. BT stiffening Plate 3.Zaino "the works" 4. Heat Shield "from Canvas Works" 5. Magnetic Oil plugs - Yes they work and you want them! 6. Speed sensor now switched!
windstrings is offline
Old 06-30-2009, 03:56 PM   #515
rickkop
My Car: Other Hybrid
I saw this on The Truth About Cars website. I know some Prius owners have had problems with these so I thought I'd post this article for them to see.
Is Toyota HIDing from Prius Headlight Problem?
June 30, 2009
First, engine sludge in the Camry. Then, rusty frame rails on the Tacoma. Advertising Age (of all people) reveals the latest problem to tarnish Toyota’s solid gold quality image: the Prius’ HID headlights. A number of owners of Toyota’s green machine weren’t well pleased happy their high intensity headlights died after a few years. No surprise there; replacing them runs up a $1000+ parts and labor bill. Owners claim HID death is a “a dangerous but undisclosed safety defect” and that Toyota has “long been aware of Prius’ HID headlight problem” and is “concealing the problems from owners.”
So far the national Highway Traffic Safety Administration (el NHTSA) has received over 300 complaints about the headlights. When El NHTSA contacted Toyota about the issue, the automaker said they’d provlde information on the headlights “by the end of the month.”
Meanwhile, an unnamed “company spokesman” told AdAge that Prius owners are responsible for repairs after the warranty has expired. So it doesn’t look like Toyota may be willing to do much to sooth owners’ ruffled feathers.
Looking forward, ToMoCo better be careful, though. As marketing expert Andy Fletcher pointed out, Prius owners are “sensitive people with a clear sense of right and wrong and their obligation to society.” With the new Prius whirring onto the streets, they’re “the wrong group to mess with, particularly now.”
Is Toyota HIDing from Prius Headlight Problem? | The Truth About Cars
rickkop is offline
Old 06-30-2009, 04:37 PM   #516
windstrings
Nice link Rickkop... I"m part of the solution "or problem" now as I am registered and have commented too.
Its ashamed its not till things get media attention before the big guys figure its in their best interest to take care of the issue.... until that happens, they think its in their best interest to hide it.
Toyota must have had a management shift in the last few years.
What made them great "customer service and a product of pure excellence" has faltered.
Anyone can forgive someone for not being perfect, but few customers will forgive for buying a bum product when that same vendor wants them to buy again.
I can respect that Toyota has done away with HID's in their 2010's if they can't get them to work right " don't other vendors do ok?", but its harder when they won't take care of the customers that got burn't and then to beat all, want them to pay thousands of dollars to fix it themselves when the problem can be fixed for very little.
There are some isolated rays of hope as more and more people are getting Toyota to listen, but we shouldn't have to hold their feet to the fire... there should be a simple recall..... period!
It won't be the first time a vendor has been found to not be perfect....
What makes them perfect is not that they produce flawless products, but rather that they stand behind them flawlessly!
Old 07-01-2009, 07:17 AM   #517
talonts
VFAQman
talonts's Avatar
An update on my 06. Last Dec (just SIX MONTHS ago), the passenger bulb started winking out. January I ordered a set off bulbs from stillenmaxima98. Put them in around the 15th. Mid-Feb, the DRIVER'S side starts winking. Sent it back for replacement put my original driver's "good OEM" in its' place, no issues...
Put the replacement in the driver's side about 6 weeks ago. About 2 weeks ago, the driver's side starts winking AGAIN. 3 bulbs in 6 months!
I put in my NHTSA complaint. If I didn't leave my foglights on all the time, it would be a real hazard, as people might assume I am a motorcycle, or if BOTH wink out at once, I'm blind.
They'd better recall these soon.
They could make me happiest of all by just handing me a pair of 04-05 ballasts, I'll slap them in my spare set of 04 housings, buy some D2Rs, and swap them into the 06, as my 04 has had zero problems with its' D2Rs so far.
Tom Stangl
* http://www.vfaq.net/
* Prius Visual FAQ Home
* 04 Prius AM #7
* 06 Prius NL #7
* http://www.vfaq.com/
* DSM Visual FAQ home
* 90 Talon AWD
talonts is offline
Old 07-01-2009, 11:10 AM   #518
BShanahan14rulz
Originally Posted by windstrings View Post
Welcome to the Forum....thanks! I just saw that you all were having headlight problems and wanted to try to help find a solution.
Hid's are quite efficient, meaning they do allot with the power they have. A 35W HID will produce many more lumens than a 35W Halogen for instance. true indeed!
My point being, they are not pulling that much power. Except during start-up, which lasts about 30 seconds or so, pulls some mean amperage, and puts out around 25,000 volts to the bulb. This is why I suggested an aftermarket heavy duty wiring harness. They are simple to make but are also widely available premade due to the HID kit market
If the wires were too small, the problem would have been consistent from driving off the showroom floor till now.true, but perhaps this is where your next point comes into play:
However, as discussed a ways back on this thread, there may be some internal resistance in the bulb that gets created from impure components aging with the heat/cooling process over time. The bulbs that are used have high QC standards, since they should be made by philips or osram. If you have GE or Koito bulbs, they are fine as well, but the general concensus seems to be that philips (85122, 85122+ for D2 systems) is at the top of the pecking order. Everything from poor grade copper to the material in the bulb that gets vaporized as it goes into a plasma state is subject to having impurities and being more vulnerable to time. Even OEM bulbs will degrade over time. start-up voltage sputters the electrodes, mixing whatever metal the electrodes are made of into the salts. This may very well lead to increased resistance which would require a higher current pulse during startup to start an arc, and a higher current flow to maintain that arc.
In this paragraph, I do not agree with the logic of bulb replacement ruling out a ballast or wiring inadequacy. However, my third agreement to a possible problem is that the ballast is not very well made. I know this is a lot to ask, but does anybody happen to have a picture of this ballast? Stands to reason that if other cars using different ballasts but same bulbs are doing fine, it should be either wiring or ballast.
So you tell me?
My suspicion is the bulb.... I think as the impurities start oxidizing mixing with the electrodes over time, it takes more and more voltage to keep the fire a burning... a refire by turning the switch off and back on hits it again with a fresh high voltage blast to get it going again "while already very hot" and that keeps it going till it finally craters again....
This is just my speculation. That last bit was pretty spot on.
Here is what my take on this is for possible problems, in no specific order:
1: Ballast. Toyota/Lexus usually use ballasts made by Denso. These things are definitely nowhere near weatherproof. Let me try to dig up a picture...
Well, I had a picture, but I don't have 5 posts yet. That's ok, just google image search for Denso ballast.
Perhaps it is mounted in a bad location on the prius.
Being that it is in a prius, I also wouldn't put it out of toyota's realm to try to create a more efficient ballast for the energy-efficient prius. look around for a Matsushita ballast (round, dark-grey, finned case) or a Hella Gen. 3 (many asian kits copy off of the gen 3, you all prob. know what it looks like)
2: wiring. It's only logical that as a bulb ages, it takes more power to start it up. the voltage is more or less constant in a car system, so the ballast has to pull more current to start and maintain arc in an older bulb. Perhaps somebody who is currently experiencing the problem on a regular basis could try this out and report back.
3: Bulb. the Brand Names have it when it comes to bulbs. Make sure your dealer is not putting mercury-free bulbs in a d2 system or d2 bulbs in a d4 system. Also make sure they are made by a reputable manufacturer. imo philips>osram>koito>GE when it comes to HID bulbs.
Old 07-01-2009, 05:29 PM   #519
windstrings
If I remember right, seems I read the D4R bulbs that go in the 06 prius were the first year they were released. I still think its a bulb issue more than anything.
Although the ballast are not waterproof, that would still be a non-issue unless replacing the bulbs alone did not make the problem go away.
Old 07-01-2009, 06:45 PM   #520
talonts
VFAQman
talonts's Avatar
1 - They're mounted on the bottom of the headlight housings, and they are pretty waterproof - they even have an O-ring to seal them to the housing (though that only stops water from the bottom, not sneaking in from the back of the housing). See http://www.vfaq.net/proj-pics/headli...t_04_right.jpg for pics of the 04 (D2R) and 06 (D4R) housings. Notice the D4R ballast is about 2/3 the size of the D2R by the footprint on the housings.
2 - the wiring from the bulb to the ballast is less than a foot long (more like 6" - see the 06 housing above, you can see the silver jacketed wire and a bit of the ballast where it is hanging off the back of the housing). If it were that sensitive to resistance changes, it would flare out from temp differences from day one.
3 - True factory bulbs are Philips for the 06-up D4R, so if you get anything else, suspect that your dealer is outsourcing.
From Philips email I got today:
"Thank you for your submission, the D2R HID bulbs are 85V 35W. D4R bulbs are 42V 35W. If you have any further question let us know."
So I doubt that D2R bulbs would even start up with a D4R ballast at half the voltage needed.
talonts is offline
headlight, problem
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/34584-headlight-problem.html
Aaron's Rambling Inanity This thread Refback 11-12-2009 12:56 AM
Toyota This thread Refback 09-27-2009 11:49 AM
Prius Headlight Bulb Co$t$ at the Toyota dealer - Page 2 - TDIClub Forums This thread Refback 09-23-2009 04:57 PM
Prius Headlight Bulb Co$t$ at the Toyota dealer - TDIClub Forums This thread Refback 09-17-2009 12:31 PM
Home This thread Refback 09-15-2009 06:51 PM
Toyota This thread Refback 08-18-2009 03:18 PM
Toyota This thread Refback 08-05-2009 11:59 PM
Home This thread Refback 07-18-2009 05:18 PM
High-Intensity Headlight Horrors Perplex Prius Owners - All About Prius This thread Refback 07-16-2009 02:05 PM
Prius Headlight Bulb Co$t$ at the Toyota dealer - Page 2 - TDIClub Forums This thread Refback 07-06-2009 06:14 PM
Prius Headlight Bulb Co$t$ at the Toyota dealer - TDIClub Forums This thread Refback 07-03-2009 07:29 PM
Prius Headlight Bulb Co$t$ at the Toyota dealer - TDIClub Forums This thread Refback 07-02-2009 11:28 PM
Prius Headlight Bulb Co$t$ at the Toyota dealer - TDIClub Forums This thread Refback 07-02-2009 08:00 PM
Prius Headlight Bulb Co$t$ at the Toyota dealer - TDIClub Forums This thread Refback 07-02-2009 07:49 PM
Mi Toyota Prius - quejas sobre las luces xenon del Prius USA - Noticias Prius This thread Refback 07-01-2009 03:11 PM
Mi Toyota Prius - quejas sobre las luces xenon del Prius USA - Noticias Prius This thread Refback 07-01-2009 12:53 PM
Toyota This thread Refback 06-30-2009 04:46 PM
PriusOnline.com • View topic - Head Light 2006 This thread Refback 05-23-2009 10:01 PM
PriusOnline.com • View topic - Head Light 2006 This thread Refback 05-20-2009 05:31 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 05-17-2009 10:57 AM
PriusOnline.com • View topic - Head Light 2006 This thread Refback 05-12-2009 11:52 AM
Luscious Garage | Blog This thread Refback 04-24-2009 08:17 PM
Luscious Garage | Blog This thread Refback 04-17-2009 06:48 PM
Luscious Garage | Blog | Prius HID D4R Headlights This thread Refback 04-17-2009 02:19 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 04-12-2009 11:55 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 04-10-2009 01:38 AM
Luscious Garage | Blog | Prius HID D4R Headlights This thread Refback 03-27-2009 06:24 PM
35W HIDflashlight..too cheap? - Page 2 - CandlePowerForums This thread Refback 03-24-2009 09:00 AM
Malibu Boat Parts List, Malibu And Car Of The Year, Malibu Motors Toronto - Ktmgirls This thread Refback 03-14-2009 06:59 AM
Chevrolet Wiring Diagrams, 2007 Chevrolet Silverado, 1957 Chevrolet - Confederatewholesale This thread Refback 03-13-2009 06:17 AM
Buick Rendezvous Backup Light Lens, Buick Rendezvous Suggested Maintenance, Buick Rendezvous Cruise - Victorycanter This thread Refback 03-13-2009 06:09 AM
Nissan Maxima Air Filters, Kn Air Filters For Harleydavidson, Oldsmobile Cabin Air Filter - Secessionconfederate This thread Refback 03-13-2009 05:46 AM
Daniela Mercury Free Download, Mercury Boats, Mercury Quicksilver Shifter Parts - Classicmovies This thread Refback 03-12-2009 05:39 AM
Oxegen Sensor Reset 97 Jeep, Nth Degree Jeep, Jeep Wrangler Stuff - Squireparsons This thread Refback 03-12-2009 04:13 AM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 03-11-2009 03:26 AM
2002 Buick Rendezvous Recalls, Buick Rendezvous Overall Length, Buick Rendezvous Extended Warranties - Freddiefender This thread Refback 03-09-2009 06:15 AM
Nissan Maxima Side Molding, Nissan Maxima Service Engine Soon Light, Nissan Maxima Tail Light Lens Replacement - Yamahansaw350 This thread Refback 03-08-2009 10:44 AM
How A Insurance Company Considers A Car Value, Houston Toyota Center, How An Air Conditioner Compressor Works On A Car - Lowaboots This thread Refback 03-07-2009 04:09 AM
Maximum Tow Capacity Of 2005 Buick Rendezvous, Maxima Toy Car, Maxwell Car Parts - Parkingbrake This thread Refback 03-06-2009 03:36 AM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 03-01-2009 10:14 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-28-2009 09:55 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-24-2009 03:00 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-19-2009 01:51 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-11-2009 11:49 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-09-2009 01:21 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-07-2009 09:56 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-05-2009 12:16 PM
Headlight Problem - Kosmix This thread Refback 02-04-2009 08:35 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-04-2009 04:40 PM
35W HIDflashlight..too cheap? - Page 2 - CandlePowerForums This thread Refback 02-03-2009 02:37 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-01-2009 02:39 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 01-31-2009 03:24 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 01-29-2009 11:11 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 01-28-2009 11:21 AM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 01-23-2009 04:58 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 01-22-2009 09:51 AM
electrical problem with headlights - GreenHybrid - Hybrid Cars This thread Refback 12-27-2008 04:06 AM
Ahh toyota quality... - Page 2 - Impala SS Forum This thread Refback 12-18-2008 04:49 PM
Luscious Garage | {title} This thread Refback 11-24-2008 05:14 PM
The $400 Headlight Skarka Gen II Prius Care, Maintenance and Troubleshooting 47 08-15-2009 11:41 PM
headlight problem tedlouv Gen II Prius Care, Maintenance and Troubleshooting 0 07-22-2007 11:11 PM
Headlight Problem maximo Gen II Prius Care, Maintenance and Troubleshooting 4 06-04-2007 10:16 PM
Headlight help cry4dawn Gen II Prius Care, Maintenance and Troubleshooting 7 01-23-2007 01:46 PM
Climate System Problem (Thought to be MFD Problem) losaltosprius Gen II Prius Care, Maintenance and Troubleshooting 2 03-17-2005 06:08 PM
