This is a discussion on Headlight problem within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I've got my 2006 going into the shop tomorrow for the bulb issue (for the 3rd time). I'm just off ...
Headlight problem
LinkBack (59) Thread Tools
Old 10-25-2009, 02:51 PM   #611
georgekessel
georgekessel's Avatar
Model: V
Package: Adv. Technology
Default Re: Headlight problem
I've got my 2006 going into the shop tomorrow for the bulb issue (for the 3rd time). I'm just off warranty for time not miles. I'll be calling that # in the morning but I'm in Canada now not the USA. It's an ex-US car so I wonder if they'll fix it for free or not?
georgekessel is offline
Old 10-27-2009, 01:42 PM   #612
J_w73
Been reading through this thread and have yet to conclude whether this is a bulb/capsule issue or a headlamp computer/ecu component. I see one or both being replaced and sometimes fixing the issue and sometimes not
Can someone let me know which is the culprit? My certified preowned prius passenger headlight went out with 3 miles left on my 3000 mile comprehensive warranty.. I immediately called the dealer (service department closed) to report the problem. I took a picture of the odometer as some additional proof my headlight was out before the warranty was up... unfortuneatly I didn't get a picture of the headlight being out as I turned the lights off and back on and it came back on..
Already getting ready for a battle with the dealer.. but hopefully they will fix under warranty.. even though I have seen that the warranty doesn't cover bulbs..
if it is only a bulb that they won't cover then I will spend the $70 on the ebay bulb and switch it out myself.
But if it is a bigger issue then I hope they make good and fix it.
J_w73 is offline
Old 10-30-2009, 12:29 PM   #613
isp2952
It began with one light going out. Not so unusual right? But before I could get it fixed I noticed that when I turned the lights on the burned out light would come on then dim slowly and go out. I also had my good bulb go out, leaving me with no headlights. When I turned the light switch off and then back on the good bulb came back on. Took it to dealer. They replaced the burned out bulb and told me they were interconnected and that is why the good one went out. I bought the story until this morning when the good one went out again and came back on after turning the lights off and on again. Got on this forum and noticed I wasn't the only one with the problem. All seem to be having the problem with 40K miles or more. Mine is at 47K. I called Toyota this a.m. and got a number. Will be contacted when they decide what they are going to do. I have already decided what I'm going to do. I'm contacted the NHTSB and going to the media. This is bull crap! It is a real safety issue. They had better jump on this faster than the accelerator pedal problem.
isp2952 is offline
The Following User Says Thank You to isp2952 For This Useful Post:
jaw444 (10-31-2009)
Old 10-30-2009, 12:47 PM   #614
In general, the problem has been a compatibility issue between the capsules and the ballast. It appears that the ballast is barely supplying enough voltage to maintain the capsule, so as the capsule ages, it stops working reliably. In this situation it usually doesn't help to replace the ballast, since you will most likely get another one built to the same specs. It gets complicated because a replacement ballast might work at the upper end of the voltage range, and that would fix the problem. A replacement capsule might be more tolerant of lower voltages, and that would also fix the problem. In rare cases the ballast might actually have failed, which means a replacement would work. On the other hand, a replacement capsule might be less tolerant and will not fix the problem. All of these permutations make the problem confusing.
Black 2006 package #7
Northern Michigan
qbee42 is online now
The Following 2 Users Say Thank You to qbee42 For This Useful Post:
farrellcsun (11-07-2009), jaw444 (10-31-2009)
Old 10-30-2009, 02:14 PM   #615
windstrings
Certified Prius Breeder
windstrings's Avatar
I think thats about it Tom.... that may be the reason the Chinese bulbs do better since they require less voltage as discussed here.
The quote below describes a push for genuine Phillips bulbs because the ballasts voltage it too high to support the "knock off" chinese bulbs without causing short life... but if the ballast is slightly "under powered" this would explain why the "knock offs" actually work better than the originals, and why it takes a second restrike to get the bulb going again, once it degrades a little from being underpowered.
Unlike other sellers' cheap Chinese knock-off retrofit D4S/D4R bulbs converted from regular D2S/D2R bulbs, our JDM D4C HID bulbs are genuine Mercury-Free D4 bulbs using genuine Philips Burners.
Those Chinese knock-off retrofit D4S/D4R from D2S/D2R bulbs will burn out quick because genuine D4S/D4R HID bulbs are working under a higher 43V ballast comparing with regular D2S/D2R's 36V ballast.
windstrings is online now
The Following User Says Thank You to windstrings For This Useful Post:
jaw444 (10-31-2009)
Old 10-31-2009, 01:36 AM   #616
jaw444
jaw444's Avatar
Originally Posted by isp2952 View Post
...Got on this forum and noticed I wasn't the only one with the problem. All seem to be having the problem with 40K miles or more. Mine is at 47K. I called Toyota this a.m. and got a number. Will be contacted when they decide what they are going to do. I have already decided what I'm going to do. I'm contacted the NHTSB and going to the media. This is bull crap! It is a real safety issue. They had better jump on this faster than the accelerator pedal problem.
When i was told by Toyota that they were going to reimburse the cost of replacing the bulb (that's what the invoice says was done), i thought they were openly recognizing that there is a problem, that progress is being made toward something being done about this. I called a few days later to follow up and make sure my fax of the invoice was received (having learned not to leave such things to chance). When i spoke to the same representative, there was something different in her manner, and this time she said "We have decided to pay for the repair on a one time only basis as a good will gesture" or something like that. The first time, there was no mention of "one time only" or "good will" and she had been warmer and friendlier. I was just calling to ask if she got my fax. She was making a whole new speech about why they were reimbursing me. I am left with a different impression from my initial one. I don't think the problem is being acknowledged at all, based on the second contact. I was pretty much told that if the problem recurs, i'm on my own, they are doing me a favor to reimburse me, because when it comes down to it, headlights repeatedly going out is just normal wear and tear. I hope you are able to get media attention to this. Reading this thread is not reassuring, about the future of my headlights.
jaw444 is offline
Old 10-31-2009, 02:00 PM   #617
windstrings
Originally Posted by jaw444 View Post
W The first time, there was no mention of "one time only" or "good will" and she had been warmer and friendlier. I was just calling to ask if she got my fax. She was making a whole new speech about why they were reimbursing me. I am left with a different impression from my initial one. I don't think the problem is being acknowledged at all, based on the second contact. I was pretty much told that if the problem recurs, i'm on my own, they are doing me a favor to reimburse me, because when it comes down to it, headlights repeatedly going out is just normal wear and tear. I hope you are able to get media attention to this. Reading this thread is not reassuring, about the future of my headlights.
The problem is now being acknowledged... just not officially for fear it would gender an onslaught of recalls.
They are oiling the greasy wheel hoping the problem with go away.
Don't worry, the Chinese ebay bulbs seem to do fine.... I hear they like the lesser voltage anyway.
I still have two GenII's and they both have the ebay bulbs for close to 40K miles now with no problems.
If defense of Toyota... they are a big target for lawsuits so they are trying to do good to the customer without attracting attention.
I reality, you would think they would "love" for the media to get ahold of honest good will gestures but reality is.. its not a good will gesture, but rather.... here's your cookie, now go away and be quiet and don't tell anybody!
Alan
________________________
2010 Blue Ribbon Metallic IV with Bisque leather...."My Blue Baby"
And my "other" cars......
2006 Barcelona Red Prius Pkg #8 with Bisque leather.... Yea Baby, Yea! "The Hot Tamale"
2006 Silver Pine Mica Pkg#8 with Bisque leather.... "The Mint Julip"
2006 Mods so far:
1. Coastal EV switch 2. BT stiffening Plate 3.Zaino "the works" 4. Heat Shield "from Canvas Works" 5. Magnetic Oil plugs - Yes they work and you want them! 6. Speed sensor now switched!
Old 11-02-2009, 10:16 AM   #618
FJRGerry
Hi all,
I haven't read this entire thread since it's 62 pages, but that tells me this has been an issue for quite some time. My 2007 Prius has the same issue and is 2.5 years old at 41K. I just got a voicemail from the dealer that the cost to repair is $566!!! I called back and left a VM to not repair and that Toyota should repair at their expense. We'll see...
FJRGerry is offline
Old 11-03-2009, 07:39 PM   #619
Longdriver
Originally Posted by FJRGerry View Post
Hi all,
I just had my 2008 Prius in for this problem except i didn't think it was anything but some headlights that just needed to be replaced.
I didn't really think anything of it until they told me the cost of each bulb would be $150.00. To top it off they also wanted to charge me $45.00 to replace each one. So $390.00 just to put in 2 headlamps.
After talking with one of the service people they called Toyota and said they would pay for one of the bulbs even though the HID bulbs were not covered by any warranty. I am glad i declined the service after reading some of the posts on this page.
Lets hope Toyota will recognize there is a problem soon and do the right thing.
Longdriver is offline
Old 11-04-2009, 11:43 PM   #620
Wheelin1
Thanks guys got my lights fixed 1-800-331-4331 and got a case # 2006 red 54000 miles
Wheelin1 is offline
headlight, problem
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/34584-headlight-problem.html
Aaron's Rambling Inanity This thread Refback 11-12-2009 12:56 AM
Toyota This thread Refback 09-27-2009 11:49 AM
Prius Headlight Bulb Co$t$ at the Toyota dealer - Page 2 - TDIClub Forums This thread Refback 09-23-2009 04:57 PM
Prius Headlight Bulb Co$t$ at the Toyota dealer - TDIClub Forums This thread Refback 09-17-2009 12:31 PM
Home This thread Refback 09-15-2009 06:51 PM
Toyota This thread Refback 08-18-2009 03:18 PM
Toyota This thread Refback 08-05-2009 11:59 PM
Home This thread Refback 07-18-2009 05:18 PM
High-Intensity Headlight Horrors Perplex Prius Owners - All About Prius This thread Refback 07-16-2009 02:05 PM
Prius Headlight Bulb Co$t$ at the Toyota dealer - Page 2 - TDIClub Forums This thread Refback 07-06-2009 06:14 PM
Prius Headlight Bulb Co$t$ at the Toyota dealer - TDIClub Forums This thread Refback 07-03-2009 07:29 PM
Prius Headlight Bulb Co$t$ at the Toyota dealer - TDIClub Forums This thread Refback 07-02-2009 11:28 PM
Prius Headlight Bulb Co$t$ at the Toyota dealer - TDIClub Forums This thread Refback 07-02-2009 08:00 PM
Prius Headlight Bulb Co$t$ at the Toyota dealer - TDIClub Forums This thread Refback 07-02-2009 07:49 PM
Mi Toyota Prius - quejas sobre las luces xenon del Prius USA - Noticias Prius This thread Refback 07-01-2009 03:11 PM
Mi Toyota Prius - quejas sobre las luces xenon del Prius USA - Noticias Prius This thread Refback 07-01-2009 12:53 PM
Toyota This thread Refback 06-30-2009 04:46 PM
PriusOnline.com • View topic - Head Light 2006 This thread Refback 05-23-2009 10:01 PM
PriusOnline.com • View topic - Head Light 2006 This thread Refback 05-20-2009 05:31 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 05-17-2009 10:57 AM
PriusOnline.com • View topic - Head Light 2006 This thread Refback 05-12-2009 11:52 AM
Luscious Garage | Blog This thread Refback 04-24-2009 08:17 PM
Luscious Garage | Blog This thread Refback 04-17-2009 06:48 PM
Luscious Garage | Blog | Prius HID D4R Headlights This thread Refback 04-17-2009 02:19 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 04-12-2009 11:55 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 04-10-2009 01:38 AM
Luscious Garage | Blog | Prius HID D4R Headlights This thread Refback 03-27-2009 06:24 PM
35W HIDflashlight..too cheap? - Page 2 - CandlePowerForums This thread Refback 03-24-2009 09:00 AM
Malibu Boat Parts List, Malibu And Car Of The Year, Malibu Motors Toronto - Ktmgirls This thread Refback 03-14-2009 06:59 AM
Chevrolet Wiring Diagrams, 2007 Chevrolet Silverado, 1957 Chevrolet - Confederatewholesale This thread Refback 03-13-2009 06:17 AM
Buick Rendezvous Backup Light Lens, Buick Rendezvous Suggested Maintenance, Buick Rendezvous Cruise - Victorycanter This thread Refback 03-13-2009 06:09 AM
Nissan Maxima Air Filters, Kn Air Filters For Harleydavidson, Oldsmobile Cabin Air Filter - Secessionconfederate This thread Refback 03-13-2009 05:46 AM
Daniela Mercury Free Download, Mercury Boats, Mercury Quicksilver Shifter Parts - Classicmovies This thread Refback 03-12-2009 05:39 AM
Oxegen Sensor Reset 97 Jeep, Nth Degree Jeep, Jeep Wrangler Stuff - Squireparsons This thread Refback 03-12-2009 04:13 AM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 03-11-2009 03:26 AM
2002 Buick Rendezvous Recalls, Buick Rendezvous Overall Length, Buick Rendezvous Extended Warranties - Freddiefender This thread Refback 03-09-2009 06:15 AM
Nissan Maxima Side Molding, Nissan Maxima Service Engine Soon Light, Nissan Maxima Tail Light Lens Replacement - Yamahansaw350 This thread Refback 03-08-2009 10:44 AM
How A Insurance Company Considers A Car Value, Houston Toyota Center, How An Air Conditioner Compressor Works On A Car - Lowaboots This thread Refback 03-07-2009 04:09 AM
Maximum Tow Capacity Of 2005 Buick Rendezvous, Maxima Toy Car, Maxwell Car Parts - Parkingbrake This thread Refback 03-06-2009 03:36 AM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 03-01-2009 10:14 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-28-2009 09:55 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-24-2009 03:00 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-19-2009 01:51 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-11-2009 11:49 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-09-2009 01:21 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-07-2009 09:56 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-05-2009 12:16 PM
Headlight Problem - Kosmix This thread Refback 02-04-2009 08:35 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-04-2009 04:40 PM
35W HIDflashlight..too cheap? - Page 2 - CandlePowerForums This thread Refback 02-03-2009 02:37 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 02-01-2009 02:39 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 01-31-2009 03:24 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 01-29-2009 11:11 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 01-28-2009 11:21 AM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 01-23-2009 04:58 PM
PriusOnline.com • View topic - Headlight Replacement This thread Refback 01-22-2009 09:51 AM
electrical problem with headlights - GreenHybrid - Hybrid Cars This thread Refback 12-27-2008 04:06 AM
Ahh toyota quality... - Page 2 - Impala SS Forum This thread Refback 12-18-2008 04:49 PM
Luscious Garage | {title} This thread Refback 11-24-2008 05:14 PM
The $400 Headlight Skarka Gen II Prius Care, Maintenance and Troubleshooting 47 08-15-2009 11:41 PM
headlight problem tedlouv Gen II Prius Care, Maintenance and Troubleshooting 0 07-22-2007 11:11 PM
Headlight Problem maximo Gen II Prius Care, Maintenance and Troubleshooting 4 06-04-2007 10:16 PM
Headlight help cry4dawn Gen II Prius Care, Maintenance and Troubleshooting 7 01-23-2007 01:46 PM
Climate System Problem (Thought to be MFD Problem) losaltosprius Gen II Prius Care, Maintenance and Troubleshooting 2 03-17-2005 06:08 PM
