| This is a discussion on Headlight problem within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Update on my Headlight situation: I called the dealership and was told I needed to contact Toyota. They gave me ... |
Headlight problem
| | LinkBack (63) | Thread Tools |
| | #621 |
| Junior Member Join Date: Nov 2007
Friends: 0 | Update on my Headlight situation: I called the dealership and was told I needed to contact Toyota. They gave me the number 800-331-4331 which I called and reported the issue. I was given a case number and told I would receive a call back in 24 hours by someone more familiar with the issue. I did receive a call back the next day and was told Toyota would replace the headlight and computer as a "goodwill reimursement" covering the full amount. I was also told I would need to pay then fax the information to them (at 310-381-6858) and would receive a check in 2 to 5 weeks. I was also told some dealers were replacing both headlights, but that it was up to the dealer. The Toyota representative informed me that he had already called my dealer and spoken to the service manager. I next called my dealer back and explained that Toyota would cover both headlights if the dealer thought it was prudent. The dealer agreed (TriCounty Toyota in Limerick, PA). The dealer ended up replacing both headlights and entering the repair as a warranty coverage so I didn't need to pay a penny! YAY! Happy customer here! |
| | #622 | |
| Junior Member Join Date: Nov 2009 Location: Orinda
My Car: 2007 Prius Model: N/A Package: #4 Thanks: 0
| | #623 |
| Junior Member Join Date: Dec 2005
Friends: 0 | My 2006 with 96k had the same problem about 50k ago. I contacted Toyota directly and as another poster said, they replaced both bulbs as a "one time, good will gesture." I did report the problem to the NHTSB. |
| | #624 |
| Member Join Date: Feb 2007 Location: Bonny Doon, CA
Friends: 0 | Yay! I had my case answered and the HID headlight repaced by a local Toyota Dealership under Warrenty! Filed the case with Toyota, got contacted, etc. Made an appointment at Sunnyvale Toyota and they handled everything. No charge to me, no reimbursement hassle. BTW- My 2007 Touring had almost 66,000 miles on it, but they did it anyway. |
| | #625 |
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 0
Friends: 0 | So far so good with mine - Toyota said they will be sending me a check for the money I paid to replace the bulb at the dealer. |
| | #626 |
| Junior Member Join Date: Nov 2009 Location: Modesto, CA
My Car: 2005 Prius Model: N/A Package: Navigation Thanks: 0
Friends: 0 | I have a 2005 Prius with 115,000 miles on it. About 3 weeks ago I noticed that my passenger side headlight would turn peach colored after running a while and then go out. Then the next time I started the car, it would shine fine, then turn peach colored and go out. I took it in to the dealer to get a new light. I was quoted $400 parts and labor. Later, I got a call saying they had to go somewhere to pick up the light and they got the wrong one, but it would fit. The only thing was that it cast a little different color. The good news was that it would only cost $300. I said o.k. I waited over 2 and half hours for the light to be changed, so the service manager said he was only charging me $200 for materials and waiving the labor. So, I guess I got off cheap. But, I can't help remembering when I used to go to an auto parts store and buy a replacement headlight for $5.00. What's up? I discovered this site just a few days ago and there was a popup about contacting a lawyer over this issue, so I sent off the information. Maybe I should contact Toyota directly? |
| | #627 |
| Junior Member Join Date: Jun 2007
Friends: 0 | My 2007 Prius has 44,000miles on it and just a couple weeks ago my doughter told me that my passanger side headllight is not working. It was a day time so I just turned the lights off. When I stopped the car and turned the lights on everything was fine. So I forgot about it untill two days ago the driver from the car next to me told me that my right headlight is not working. I assumed it is a30 dollars repair. Imagine my panic when I start surching internet and discovered that it is well known problem and repair can cost up to a thousand dollars! I emailed Toyota but three days later still did not hear from them. I will call them Monday. The price is absolutely outrageous! I am very scared to drive at night now. |
| | #628 |
| Member Join Date: Nov 2007 Location: Webster, MA, New England, USA
Friends: 0 | Sardis, Welcome to the Headlight thread. You are not alone. We are all very concerned and depending on where you are in th process either getting sticker shock or working through the problem with Toyota. So far, it seems most people have either done the repair themselves or achieved some satisfaction with the company. In any case, I believe you should be able to get some relief. I carry an LED flashlight with me and if my headlight goes out I can duct tape the flashlight in place to get home. It's really a lame problem for such a fine car.
__________________ Steve 2007 Silver Pine Mica Prius Package 4 Added EBH, Coastal Auto Door Lock Kit LED Lights, Side trim from Danny's group buy |
| | #629 | |
My Car: 2004 Prius Model: N/A Package: Base Thanks: 203
Friends: 36 | Quote:
| headlight, problem |
| The $400 Headlight | Skarka | Gen II Prius Care, Maintenance and Troubleshooting | 48 | 11-28-2009 03:25 AM |
| headlight problem | tedlouv | Gen II Prius Care, Maintenance and Troubleshooting | 0 | 07-22-2007 11:11 PM |
| Headlight Problem | maximo | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 06-04-2007 10:16 PM |
| Headlight help | cry4dawn | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 01-23-2007 01:46 PM |
| Climate System Problem (Thought to be MFD Problem) | losaltosprius | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 03-17-2005 06:08 PM |
