Headlight problem
| | #861 | |
| Protecting Habitat & AG Lands Join Date: Aug 2006 Location: Sacramento, CA.
My Car: 2012 Prius Model: Three Package: Solar Roof Thanks: 1,478
Friends: 74 | Quote:
The HIDs are adjustable but be careful you do not raise them too high or you'll blind oncoming traffic. The fact that Toyota used a reflector style housing instead of a projector makes aiming them properly even more important. The HIDs in the 2004-2009 Prius are pretty bad. To aim them you have to use the adjustment screw located on the back of the headlight. It is a small white screw (8mm). ![]() To properly/legally aim your headlights you'll need a tape measure at least 25ft long, an 8mm socket, masking or other dark colored tape and a dark area that has a solid wall that you can park 25ft away from.
For information regarding how to aim your headlights and remain DOT legal click the following link: Daniel Stern Lighting Consultancy and Supply HOW TO: aim HID headlights The attached pdf may be easier to understand.
__________________ 2012 Prius Three with Solar Roof - Blizzard Pearl w/dark gray interior: Yokohama AVID Ascend tires | Scangauge II | HIDs 5000K 2005 Prius - SOLD: 900w Kenwood eXcelon (Stealth Install), ARC Audio, Diamond Audio stereo system | 17x 7" Centerline RPM Wheels | Michelin Primacy MXM4 tires | Yokohama dB Super E-Spec | Eibach Pro-Kit | KYB G2 Struts | Progress Technology Rear Sway Bar | Corolla Front Sway Bar | WeatherTech floorliners | BT Stiffening Plate| ScanGaugeII | 35w HID Blazer Fog Lights | Morimoto Mini H1 Projector HID Headlights | For LRR Tire Info | Tire Test Results For Prius and green-tech transportation information check out the www.WhatDrives.us weekly podcast! ![]() | |
| | #862 |
| Junior Member Join Date: Feb 2005
Friends: 0 | I have a 2005 Prius with one burned out headlight and the other one intermittent. The Oakland Toyota dealer said "we have to remove the front bumper for that" and quoted $385 for one headlight bulb replacement, and only $190 more ($575) to do both! While reading the headlight woes stories on priuschat.com I saw a recommendation for Luscious Garage in San Francisco. Greg on the phone quoted me $130 per headlight for parts and labor. I had an appointment that evening and really needed it done. Greg said it would take about a half-hour total and they could see me that afternoon. I made the appointment and am now an ecstatic customer! He not only replaced the HID Xenon bulbs from inside the engine compartment (without removing the bumper - 10 min/side!), but also replaced the side parking light bulbs for free. And he replaced a broken fog lamp for just the $9 cost of the bulb. The garage I usually use in Berkeley didn't know off-hand what bulbs to use, or what procedure to use for changing them. Greg said he had already replaced 6 Prius headlamps that day! These guys REALLY now what they're doing. Total cost including tax, $270 and total time was just under 30min. I'll be going back to them for all my Prius maintenance. What a great garage! |
| | #863 | |
| Junior Member Join Date: Feb 2012 Location: Kentucky
My Car: 2005 Prius Model: N/A Package: Navigation Thanks: 0
I was convinced that it was the bulbs (which were cloudy white in the center) because the right side was only lasting a few minutes and hadn't gone out since -- and there was a good description on the forum about this being the typical failure pattern - light goes out but turning it off and back on relights it for a while (mine once relit for 4 hours). Took me 25 minutes to replace one, 5 minutes to find one of the clips and about 15 minutes to get the weather cover back on. I couldn't match the lady from Luscious Garage on You Tube who did it in 3 minutes. Maybe next time. You Tube videos were helpful, some with good close ups and photos. | |
| | #864 |
Friends: 5 | Seems the bulb manufacturers have a broad spectrum of leeway for quality control since bulbs are considered a maintenance item and its hard to pen them down on just how long they are supposed to last in order to claim a full refund. Seems some real trash is being put in the market place.. whether from ebay or from the dealer.... pretty much all equal ground. I find some bulbs seem to last forever, while others start up with problems in a couple of weeks of being installed.... quite frustrating. About all you can do is consider the relatively cheap cost of ebay bulbs and order extra and take your chances. Seems going to all the trouble and hassle of dealing with the dealers "does not" decrease the odds of having future issues again. Unless HID manufacturers can wake up, they will kill the goose that lays the golden eggs and HID bulbs will be considered a failure for future use in mass produced consumer goods and items such as cars etc. While they are a vast improvement from the Halogen of old, with the introduction of computer built reflectors to match the bulb with the reflector to maximize lack of waste of lumens into space and to the sides, LED's and Halogen's are now stealing the show. Its a darn good thing they haven't had such issues with the main traction battery as Toyotas reputation has been stained so much from this, I wouldn't be surprised if they would balk on those too claiming they are a "maintenance" item.... this whole HID bulb issue has gotten ridiculous a long time ago.... Toyota should offer to replace the whole headlight assembly with Halogen and a new reflector to match and write it off as a loss. They had a loyal crowd that would follow to Golgothas Hill.. but this whole episode has really strained the relationship between Toyota and customer.
__________________ Alan ________________________ 2010 Blue Ribbon Metallic IV with Bisque leather...."My Blue Baby" And my "other" cars...... 2006 Barcelona Red Prius Pkg #8 with Bisque leather.... Yea Baby, Yea! "The Hot Tamale" 2006 Silver Pine Mica Pkg#8 with Bisque leather.... "The Mint Julip" 2006 Mods so far: 1. Coastal EV switch 2. BT stiffening Plate 3.Zaino "the works" 4. Heat Shield "from Canvas Works" 5. Magnetic Oil plugs - Yes they work and you want them! 6. Speed sensor now switched! |
| | #865 |
| Junior Member Join Date: Feb 2012 Location: Oxnard California
My Car: 2009 Prius Model: N/A Package: #9 Thanks: 0
Friends: 0 | I just spent about an hour reading through this topic and I want to thank everyone and Windstrings in particular. I was stopped and ticketed in my (beloved) 2009 Prius on the Pacific Coast Highway last weekend for a passenger side headlight out. Decent cop gave me the yellow warning thing and I have to get it fixed and go get it signed off. I stopped going to the dealer at about 75,000 miles. Just too much money for too little service. My private, independent mechanic said the righthand bulb is $150 and I authorized the purchase. But he called earlier and said that when he talked to Toyota to pick up the bulb, somebody over there told him the bulb is not the problem. It's a computer chip or a ballast or something. The guy at Toyota Parts seemed to know all about the problem. My mechanic is telling me to go to Toyota because he almost cost me $150 for a bulb I didn't need and he's out of his depth. This is not a complaint about a forum where so many intelligent people have tried so hard to learn and proceed, but I've read almost the entire thread and I don't know what to do. Nobody seems to be sure what the problem is, or how to fix it without placing oneself at the (non-existent) mercy of the Toyota Corporation. Many people who've posted have replaced one bulb, or both bulbs, from eBay, or Amazon, with varying results. Lacking any further suggestions I plan to drive over to the Highway Patrol, turn the headlights off and back on, go inside and get signed off based on the (temporary) situation where I have both lights on for however long, and go about my business, turning the lights off and back on whenever I can see that the right one is off again. But because I realize that I'm simply having an adolescent reaction to the way Toyota is bullying and deceiving and overcharging people, could someone please give me the part number or the model number of the HID headlamp for my 2009? And thanks, really, for everything. |
| | #866 |
| My other car is a boat Join Date: Mar 2006 Location: Northern Michigan
My Car: 2006 Prius Model: N/A Package: #7 Thanks: 1,351
Friends: 18 | The problem is well understood, and discussed in detail on several threads. The underlying problem is the D4R bulbs. Toyota switched to D4R bulbs for environmental reasons (no mercury), but mercury is there for a reason. It makes the bulbs easier to strike and increases the light output. The D4R bulbs are fussier, and Toyota shipped a bunch of Prius with dodgy D4Rs. They worked, but were perilously close to not working, even when new. As they aged, they became harder to strike, as happens with all HID lamps. Unfortunately, since they were bad to begin with, they reached this end of life intermittent condition quickly. The solution is to replace the bad D4R bulbs with good ones. Note that you can also have a failed ballast, which is the "chip" that your mechanic mentioned. It's unusual for the ballast to be the problem. In the early days of this problem Toyota was shotgunning the fix by replacing everything. The Toyota tech that talked to your mechanic is relaying outdated information. Tom
| | #867 | |
| | #868 | |
| Senior Member Join Date: Sep 2005 Location: SF Bay Area, CA
My Car: 2006 Prius Model: N/A Package: #7 Thanks: 1,521
Friends: 8 | Quote:
The 06-09 HID equipped Priuses went with D4R bulbs seem to be less reliable than the D2R bulbs (which have mercury) that went in HID equipped 04-05 Priuses (04-05 (NOT 06-09) Prius owners w/HIDs - how long did they last?). One HID on my 06 started getting flaky last year and I had some trouble DIYing (can't remove washer fluid tank, trying to replace passenger side HID) but eventually got the job done. I was a bit past the 5 year/50K mile warranty extension provided by the class action lawsuit settlement. My local dealer wasn't willing to submit a claim after being out of warranty so I bit the bullet and did it myself, at the cost of $55.23 per Philips D4R (at the time) from Amazon. Toyota Will Pay For HID Repairs, I got the Letter! points to the dealers previously unnecessarily replacing the ECU (ballast). Toyota Prius HID Headlight Class Action Settlement - Consumer Class Action Attorneys - Girard Gibbs LLP is a class action lawsuit that involved 06-09 HID equipped Priuses. I received my settlement check recently (06-09 Prius HID class action settlement award letters), after pleading my case in the paperwork I submitted. Usually, the problem can be in 1 of 3 places: bulb, ballast or wiring. It's cheaper and easier to replace the bulb first (and keep the old likely bad bulb) before mucking w/the rest. If there's still a problem after replacing w/a known good bulb, then you can try to tackle the others and keep the "bad" bulb as a spare. I bought my replacements Philip D4R bulbs from Amazon w/Amazon as the reseller (not some random 3rd party reseller there), however, after reading the great article at Not all HID Bulbs are created equal, I can't be 100% confident that the bulbs I got weren't fakes (see post #6). See
__________________ 06 white package #7 (NL); sold 04 Daytona Blue Nissan 350Z Enthusiast trim; mom has 07 white NAHLast edited by cwerdna; 02-03-2012 at 06:28 PM. | |
| | #869 |
Friends: 5 | Good job Qbee on the mercury notes...makes sense too. Seems I remember a few folks using the mercury bulbs by filing a notch off so they would fit ...seems that could be a solution. However the reflector is customized for the stock type so the beam it cast could be slightly altered. I also agree its to the advantage of the mechanic to target the more expensive parts such as ballast rather than a simple bulb replacement . I somehow think Toyotas recommendations as to how to fix it would be quite different if it was a covered warranty item.......don't you somehow think they would recommend common sense bulb replacement first to? Its bold of them to act like its a confirmed issue that needs a ballast replacement when so many have proven them wrong? Isn't it also funny that part of the ballast replacement procedure is to replace the bulb? Seems so many companies make more profit from service than sales?....its no wonder why. Last edited by windstrings; 02-04-2012 at 08:00 PM. |
| | #870 |
Friends: 0 | I ordered a Phillips D4R HID bulb from Amazon for about $61 including a quick delivery fee. It seems this is the first step in any process leading to the restoration of the working headlight and the calming of the Malibu Sheriff's Department. BTW: Why does Toyota lie about their liability in this matter and collect exorbitant fees for the unnecessary removal of bumpers and replacement of ballasts from both consumer and corporate? For the same reason dogs lick their own genitals. Because they can. Thanks to all, and especially to cwerdna who culled through the thousands of words on this topic and presented the information anyone would need to move forward with as much confidence as can be mustered in these troubled times. IMNSHO, cwerdna's post, two above, should be copied like gateposts to anyone arriving on this thread. |
| headlight, problem |
| The $400 Headlight | Skarka | Gen II Prius Care, Maintenance and Troubleshooting | 52 | 07-14-2010 02:08 PM |
| headlight problem | tedlouv | Gen II Prius Care, Maintenance and Troubleshooting | 0 | 07-22-2007 11:11 PM |
| Headlight Problem | maximo | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 06-04-2007 10:16 PM |
| Headlight help | cry4dawn | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 01-23-2007 01:46 PM |
| Climate System Problem (Thought to be MFD Problem) | losaltosprius | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 03-17-2005 06:08 PM |
