This is a discussion on Little piece that pops within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I think something's wrong with my Prius. On a sunny day, the little piece that sits between the dashboard and ...
Old 07-09-2007, 09:58 AM   #1
mcsj
I think something's wrong with my Prius. On a sunny day, the little piece that sits between the dashboard and the driver-side little window (the one in front of the driver door) will pop up like it has been pressured by the expanded dashboard. Also there's some "cracking" noise somewhere on the driver side, around the leg area (haven't figure out exactly where it comes from) when my Prius runs thru some rough roads.
Any suggestions on how to fix those?
mcsj is offline
Old 07-09-2007, 02:09 PM   #2
MarinJohn
MarinJohn's Avatar
Friends: 7
Your problem is a post not normally seen here. The fix must not interfere with air bag deployment. Perhaps next service you might mention this to the service adviser. I can't help but wonder if your car was in an accident and is perhaps slightly bent and/or if the airbag was once deployed.
MarinJohn is offline
Old 07-09-2007, 02:12 PM   #3
mcsj
No not anywhere close to the airbag. I mean the little piece of plastic with an air vent next to the little window.
And no, no accident involved.
<div class='quotetop'>QUOTE(MarinJohn @ Jul 9 2007, 01:09 PM) [snapback]475623[/snapback]</div>
mcsj is offline
Old 07-09-2007, 02:44 PM   #4
surfacinglove
<div class='quotetop'>QUOTE(mcsj @ Jul 9 2007, 11:12 AM) [snapback]475626[/snapback]</div>
I had the same case wth my new 2007. I noticed it pop up in one corner about a week after having it. So I just forced it back down. It kept popping up every day or so for about 2 weeks, and I'd just shove it down again. Once it got a little warmer here, it just stayed down!
I notice the plastic parts of the dash and interior are very flexible and kinda cheap, but that's probably good they are flexible and are easily removable if needed for mods, maintenance, etc. All in all, it's good now! You could also drop a little glue maybe on the edge carefully, then give it a good shove down?
2007 Black Package #3
EV switch, <strike>trim rings</strike>
surfacinglove is offline
Old 07-10-2007, 04:41 AM   #5
DaveG
DaveG's Avatar
Package: C
That plastic panel with the vent is held in-place by plastic clips on the back of it - sounds like one of the clips isn't latching properly, or the latch is popping open when it gets warm.
You could remove the entire panel (it's very easy to remove by putting a thin plastic spatula behind it and popping it off, or by reaching behind (down by the emergency brake) and pushing on the clips from behind (my preferred method, but more difficult until you know where the latches are).
Or just bring it in to your dealership and have them take a crack at it. They might need to replace the clips or the latches they pop into.
DaveG is offline
What is this piece? TRStahl Gen II Prius Main Forum 17 07-05-2007 04:31 PM
Any luck with Pops-A-Dent? DougSlug Gen II Prius Care, Maintenance and Troubleshooting 2 03-02-2007 11:02 AM
Tow Eye cover pops out Charles Suitt Gen II Prius Care, Maintenance and Troubleshooting 11 03-18-2006 09:18 PM
GREAT RESPONSE TO WSJ PIECE larrysullivan Prius and Hybrid News 16 12-05-2005 03:11 PM
Little piece that pops mcsj Gen II Prius Main Forum 0 12-31-1969 07:00 PM
