This is a discussion on Battery drains if door panel off for extended period? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Last week I removed my driver side door panel to begin replacing the speakers. I also removed the hatch panel ...
Old 07-09-2007, 11:18 AM   #1
zenMachine
Just another Onionhead
zenMachine's Avatar
the hatch panel to add some sound dampening while I'm at it. While waiting for the speaker mount
adapter and the SecondSkin stuff on order, I decided to leave the panels off. I was driving the car
with the panels removed for a few days without any problem. But when I came back from a 5-day
vacation, I found this morning that the Prius wouldn't start. No power whatsoever.
Q: What could possibly have drained the battery?
Q: My car is in the garage head first. I should be able to jumpstart the rear battery directly, correct?
Thanks!
zenMachine is offline
Old 07-09-2007, 09:38 PM   #2
1fixitman
<div class='quotetop'>QUOTE(zenMachine @ Jul 9 2007, 11:18 AM) [snapback]475513[/snapback]</div>
Thanks!
Ensure that when you jump start it that you do not cross the leads up...ie pos on neg...blah blah. Much damage may result electronically if you mess it up and it will not be warranty covered. With the door panels off is the interior light still on when the door is closed??? BTW...when the small 12Volt battery is dead you can not take the car out of park to move it..Bah.
D Rock
1fixitman is offline
Old 07-10-2007, 12:12 AM   #3
zenMachine
zenMachine's Avatar
Of course, I couldn't open the hatch to get to the 12V battery either! Darn it...
Luckily, my neighbor lent me his 25ft heavy duty jumper cable so I was able to jumpstart at the front.
Removing the fuse box cover was a bit of guesswork since the manual really doesn't tell you much
about which way to open it up. Also, the jumper post was in such a tight spot that I couldn't clip the
clamp onto it. I ended up having to use a vice grip as an extension. What a difficult design!
(Note to self: Buy a LONG jumper cable that has needle-nose ends and stow it in the hatch box.)
Anyways, turned out the problem was that I left my dome lights on last night after installing the
non-slip console pads. And also the rear hatch was not closed all the way...
Now I'll have to re-disable all the freaking beeps...
Old 07-10-2007, 01:32 AM   #4
hschuck
<div class='quotetop'>QUOTE(zenMachine @ Jul 9 2007, 09:12 PM) [snapback]475948[/snapback]</div>
It is difficult (although possible) to get into the hatch box when you cannot open the hatch because your battery is dead. Maybe stow cables under a front seat.
hschuck is offline
Old 07-10-2007, 10:36 AM   #5
zenMachine
zenMachine's Avatar
<div class='quotetop'>QUOTE(hschuck @ Jul 10 2007, 12:32 AM) [snapback]475980[/snapback]</div>
I thought about that right after hitting "Add Reply". Figured somebody would bring up this up.
Note to self: write Toyota and congratulate their engineers for yet another brilliant "safety" feature.
Maybe the 3rd gen will have a mechanical keyhole for the hatch?? Nah, that'd be too easy...
Old 07-10-2007, 11:17 AM   #6
aaf709
Ravenpaw of ThunderClan
aaf709's Avatar
<div class='quotetop'>QUOTE(zenMachine @ Jul 10 2007, 07:36 AM) [snapback]476096[/snapback]</div>
My last car had a trunk release lever next to the gas cover release. Be handy when there's no power.
aaf709 is offline
Old 07-10-2007, 12:11 PM   #7
siliconhybrid
<div class='quotetop'>QUOTE(zenMachine @ Jul 9 2007, 10:18 AM) [snapback]475513[/snapback]</div>
Thanks!
When my Prius got rear-ended couple months ago, I park in the garage on Friday am.
Came Tuesday am, I could not get the car started, it was because the hatch light was always on (due to the accident the hatch did not close properly).
siliconhybrid is offline
Battery drains at 2 weeks? newmexjohn Gen II Prius Care, Maintenance and Troubleshooting 8 01-26-2009 06:20 PM
New speakers in Front Door panel - '06 steveduer1 Gen II Prius Audio and Electronics 9 07-05-2007 12:27 PM
Door Panel Plastic Peeling rsgoehri Gen II Prius Care, Maintenance and Troubleshooting 3 05-11-2006 12:24 PM
AGH! Crease in door panel two_masks Gen II Prius Care, Maintenance and Troubleshooting 1 08-03-2005 01:32 AM
Removing Door Panel XravenX Gen II Prius Care, Maintenance and Troubleshooting 4 05-23-2005 11:53 AM
