| This is a discussion on Losing Bluetooth Connection every few minutes within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have just bought a new 2007 Prius w/ package #6. I also have a Blackberry 8100 (Pearl) that I ... |
| Junior Member Join Date: Jul 2007
Friends: 0 | I have just bought a new 2007 Prius w/ package #6. I also have a Blackberry 8100 (Pearl) that I have paired with the Prius. Everthing will work for 5 to 10 minutes and then the Prius will loose its BT connection. The BB is still showing the BT is active on the phone, but not paired with the Prius. After a minute the Prius will auto connect with my BB again and everthing is fine for another few minutes. This cycle just continues. I have my BB laying in the cupholder so I know it's not too far away. The BB is only 3 mos old. I'm not sure what is causing the Prius to lose the BT and then re-connect every 5 minutes or so. Has anybody seen this before? I research the forum and haven't seen anyone post a similar problem. Thanks in advance for any help. |
| Super Moderator Join Date: Nov 2003 Location: Chicago
Friends: 0 | Welcome! Let's hope another member with a Pearl jumps in here. In the meantime, have you taken a look at the official instructions? http://toyota.letstalk.com/brands/toyota-b.../293_05Navi.pdf Apparently, you might want to add the connection to "Trusted" (under "Device Properties") as well as disable the address book transfer feature when you're not using it to transfer contacts. |
Friends: 0 | <div class='quotetop'>QUOTE(tag @ Jul 22 2007, 06:37 PM) [snapback]483291[/snapback]</div> Quote:
Friends: 0 | <div class='quotetop'>QUOTE(GMHPrius @ Jul 22 2007, 10:16 PM) [snapback]483405[/snapback]</div> Quote:
One thing you might want to do is to change the name of the Car's Bluetooth Name. It is default at "hands free". Try changing the name of it. I recall when I went to a Lexus dealership to take my mom's lexus in, my phone was trying to connect to other car's blue tooth devices as they are all probably named "hands free". Who knows, maybe another Lexus/toyota drove by and your BB pearl tried to associate with it. Just a thought!
__________________ [font=Georgia][font=Franklin Gothic Medium]Freddyfoxx / 07 Magnetic Grey Pkg #4 | |
Friends: 0 | <div class='quotetop'>QUOTE(freddyfoxx @ Jul 24 2007, 02:41 AM) [snapback]484024[/snapback]</div> Quote:
Thank you everyone. Hopefully this post will be helpful for others that run across the same problem. | |
| Junior Member Join Date: Aug 2006
Friends: 0 | I was going to ask whether or not the Pearl was new because I had the same problem when I bought my Dash. The only reason that I knew it was phone related was because my SDA worked flawlessly just prior. I wound up exchanging the phone for another Dash that worked. Voila! |
| Bluetooth connection | Tripod137 | Gen II Prius Technical Discussion | 4 | 07-20-2007 10:08 AM |
| Bluetooth Connection | abas | Gen II Prius Main Forum | 3 | 05-11-2006 03:05 PM |
| Bluetooth Connection | abas | Gen II Prius Audio and Electronics | 2 | 05-04-2006 08:25 PM |
| Bluetooth connection | Surfer | Gen II Prius Main Forum | 13 | 01-19-2006 03:49 PM |
| Bluetooth Connection | PRIUSNC | Gen II Prius Audio and Electronics | 15 | 12-20-2005 11:29 PM |
