| This is a discussion on Check Engine Light -- 2001 Prius within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; For what it's worth, my 2002 Prius also gave me the same P0420 code yesterday, along with P3191. The folks ... |
| | #21 |
| Senior Member Join Date: Oct 2007 Location: Maryland
My Car: 2002 Prius Model: Package: Base Thanks: 0
Friends: 0 | For what it's worth, my 2002 Prius also gave me the same P0420 code yesterday, along with P3191. The folks at Auto Zone were nice to lend me a OBDII reader for free and I got the code off the car myself. I also used the tool to erase the codes and now the engne warning light is off and the code did not come back on after about 30 miles or so. In my case, I think I was the reason for the code though. It appeared after I washed the engine with A LOT of high-pressure water to remove some oil spills. I think the water vapors along with the cooling effect that washing had on the cat converter may have helped ![]() At first, the car gave me the Hybrid System failure icon as well (the red "!") but that disappeared shortly. I'll see if it reappears and I am nervous as I just bought this Prius used with no history from the prior owner (except that he was a heavy coffee drinker, judging by the many coffee stains I'm still trying to suck out with my carpet cleaning machine). So, visit Autozone, borrow the code reader, plug it in, read the codes to make sure there are no others, then reset them.... If they reappear - time to take action |
| | #22 |
| Senior Member Join Date: Apr 2006 Location: Austin, TX
Friends: 0 | Kocho, I followed a similar route. I cleared the ODBII code with the help of a friend. The Prius, like most cars, will then leave the CEL off for six trips. After the sixth trip, the light came on again under the exact same scenario, after driving the car for 5 minutes. I had him visually inspect the CC and he did not see any damage or rusting to it. I have a friend in California who owns a Toyota dealership. I had them look up the part cost, and it is $650, and it should take only 1 hour to install. So if a Toyota dealership tries to sell you one for $1700 plus 2.5 hours of labor as they did to me, you can tell them where to stick it. Another thing they wanted to do was replace the spark plugs for $150. When a dealership feeds you a line like that, you know you just need to leave. One thing I also need to mention is that my friend who owns this dealership confirmed that this is a KNOWN PROBLEM with the Gen I Prius. Their dealership has replaced several CCs, and they seem to think that there might be a recall coming. (I personally doubt that Toyota will recall for any problem that happens after 100,000 miles, though). |
| | #23 | ||
Friends: 0 | <div class='quotetop'>QUOTE(FL_Prius_Driver @ Oct 5 2007, 01:47 PM) [snapback]521930[/snapback]</div> Quote:
<div class='quotetop'>QUOTE(Kocho @ Oct 16 2007, 05:29 PM) [snapback]526616[/snapback]</div> Quote:
__________________ You can quote me on this, People who drive vehicles that idle at a traffic light, are idiots. mine 2k3 avg. 5.36 for 46,915Km Best tank 4.4L per 100K 64.2 Imperial 53.4 U.S. gallon, MiniScanner, SilverStars, block heater, winter lips, in as of Oct 15, out on April 25. In again on Sept. 21st. her's 2k4 "B" avg. 6.01 for 42,317 Km Best tank 4.02L per 100K, CAN-view with OBD11 module and flashloader, SilverStars, 06 Chrome grill bar, Michelin HydroEdge, upper and lower grill blocker,upper out as of April 7, lower out on April 28. In again on Sept 21st. | ||
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/38192-check-engine-light-2001-prius.html | ||||
| Toyota Prius Check Engine on Kosmix : Reference, Videos, Images, News, Shopping and more... | This thread | Refback | 07-14-2009 11:16 PM | |
| Check Engine Light 2007 Prius | rlafosse | Gen II Prius Care, Maintenance and Troubleshooting | 3 | 10-02-2007 12:35 PM |
| 05 Prius died, later restarted, check engine light | Jeri | Gen II Prius Care, Maintenance and Troubleshooting | 5 | 04-28-2007 02:33 PM |
| Check Engine Light | maknowlton | Gen II Prius Care, Maintenance and Troubleshooting | 12 | 12-13-2006 02:01 PM |
| check engine light | 100MPG | Gen II Prius Main Forum | 35 | 08-04-2006 06:00 PM |
| Check Engine Light | jerollo | Gen II Prius Care, Maintenance and Troubleshooting | 8 | 03-19-2004 09:39 PM |
