This is a discussion on 2008 EV Mode Mod within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; So I've read through tons of threads on EV mode and just don't see anything about the 08 Prius and ...
2008 EV Mode Mod
Old 10-04-2007, 08:26 PM   #1
Alabama
So I've read through tons of threads on EV mode and just don't see anything about the 08 Prius and EV mode. Even on Costal's site it only gives the option for 2004-2007 accessories. I assume the 07 and 08 is interchangeable as far as EV mode is concerned but I just have to ask to see if someone can confirm this.
The Costal method of using CC stem wouldn't work for me anyway as I don't have CC. So I will probably have to go the I'm thinking install a button to me sounds like the only option with no drawback. Someone correct me if I'm wrong there, it just seems with the flasher method you get into flashing your lights at people for no good reason, and the CC doesn't apply to me as I said anyway.
Alabama is offline
Old 10-04-2007, 08:39 PM   #2
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 23
Then you need a 2006+ button (note that it is different from the 04/05 button).
Tideland Prius is offline
Old 10-04-2007, 08:44 PM   #3
Friends: 37
The programming and all are identical on all '04-'08. As Tideland said the OEM button is a different size for the slot than the '04 & '05, but that's the only thing that's different. Choose your favorite method.
efusco is online now
Old 10-04-2007, 08:54 PM   #4
Alabama
Thank you sir's!!
Alabama is offline
Old 10-05-2007, 08:23 PM   #5
bruceha_2000
bruceha_2000's Avatar
Package: #8
<div class='quotetop'>QUOTE(Alabama @ Oct 4 2007, 08:26 PM) [snapback]521440[/snapback]</div>
The Costal method of using CC stem wouldn't work for me anyway as I don't have CC. [/b]
Unless there has been a big change (for the worse) in the '08, you should have Cruise. ALL Prii packages have had cruise since the '04 came out.
bruceha_2000 is offline
Old 10-08-2007, 06:54 PM   #6
Alabama
<div class='quotetop'>QUOTE(bruceha_2000 @ Oct 5 2007, 07:23 PM) [snapback]522013[/snapback]</div>
Toyota has just started this year offering the Prius with absolutely NO package on it. To make it as cheap as possible so they do offer it with no cruise.
Alabama is offline
2008 Honda Civic Hybrid vs. 2008 Toyota Prius (#5) siouxnami Gen II Prius Main Forum 29 08-13-2008 06:52 PM
2008 mpg da prius Gen II Prius Fuel Economy 29 05-16-2008 07:31 PM
My 2008 came in twilsonchicago Gen II Prius Main Forum 5 09-09-2007 01:31 PM
Hybrids on Hold: GM axes hybrid pickups until two-mode system debuts in 2008 cwerdna Prius and Hybrid News 39 05-03-2007 02:09 PM
2008 Chevy Tahoe Two-Mode Hybrid Preview Tideland Prius Prius and Hybrid News 39 01-19-2006 11:00 PM
