This is a discussion on Noise on start up within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; My 2007 has always booted up with an electric motor running in the left front of the engine compartment before ...
Noise on start up
Old 10-09-2007, 06:16 AM   #1
dmb40
dmb40's Avatar
My 2007 has always booted up with an electric motor running in the left front of the engine compartment before the ICE starts. Recently it sounds quite different, almost like it is cavitating. All the fluid resoviors are full. Can you tell me what that pump/motor noise is and how to check it out?
Thanks,
Dave
dmb40 is offline
Old 10-09-2007, 08:55 AM   #2
Has it been cooler outside? The coolant transfer pump often makes a bit more noise when it is cold. The pump you are hearing transfers engine coolant to and from a thermos bottle so as to save the heat in the liquid as long as possible.
Old 10-09-2007, 09:27 AM   #3
Friends: 37
This is probably the 4th 'report' of this so far this season...perhaps I need to make a sticky?
As the weather gets cold the coolant pump motor gets noisy...sometimes it'll even sound like it's 'stuttering'...but unless and until it makes a terrible loud noise or quits working completely there's nothing to be done.
efusco is offline
Old 10-09-2007, 11:15 AM   #4
dogfriend
Human - Animal Hybrid
dogfriend's Avatar
Friends: 11
I noticed that the sound of the coolent pump has changed in the last couple of weeks (as the outside temp has dropped). Mixed in with the other boot up noises, it sounds like something in a bad science fiction movie. :P
dogfriend is offline
Old 10-09-2007, 11:19 AM   #5
narf
narf's Avatar
There are lots of reports on this forum of coolant transfer pumps failing. It begins by making a howling noise which gets worse over time. It seems to make more noise when cold. I'd guess it's a bearing failing. My first Prius got noisy at about 30,000 miles. My current Prius is beginning to howl at 15,000. (I'd hoped they would have come up with an upgraded design by now)
Correct me if I'm wrong, but I think a total failure of the transfer pump will throw a code, but since it doesn't prevent coolant flow (there is a traditional coolant pump) it won't prevent use of the car.
narf is offline
Old 10-09-2007, 12:33 PM   #6
dmb40
dmb40's Avatar
Thank you for the replies. Any advice on whether the possible failing of this pump should be covered by Toyota's warranty? Might they agree to replace it before it fails if so? It does sound like a overspec clearance in a pump drive. My car has about 13,500 miles. The weather is still 70-80 here in Santa Barbara.
dmb40 is offline
Old 10-09-2007, 01:06 PM   #7
kettledrum
Dave,
Have you seen this thred here?
http://priuschat.com/forums/prius-ma...power-off.html
The third post has a .wav file. Does your car sound like that? That's the sound of the bad coolant transfer pump according to the experts here.
I'm hoping mine will last until my 15k service, which is still 2,500 miles away.
Last edited by kettledrum; 06-21-2008 at 02:05 PM. Reason: fixing link from new url names
kettledrum is offline
Old 10-09-2007, 01:50 PM   #8
dogfriend
dogfriend's Avatar
Friends: 11
Mine sounds like the .wav file.
Old 10-09-2007, 02:22 PM   #9
dmb40
dmb40's Avatar
<div class='quotetop'>QUOTE(kettledrum @ Oct 9 2007, 10:06 AM) [snapback]523157[/snapback]</div>
Dave,
Have you seen this thread here?
That is it. Thanks. I will see what Toyota offers...
Dave
dmb40 is offline
Old 10-09-2007, 03:56 PM   #10
kettledrum
Evan,
Would you characterize the noise in that .wav file as the "terrible loud noise" you were referring to?
Cold weather related? Car won't start unless we try to start about 5-10 times JasonInNJ Gen II Prius Care, Maintenance and Troubleshooting 13 01-28-2009 04:39 PM
Wa Wa Noise / Hard Steering Noise Fibb222 Gen II Prius Care, Maintenance and Troubleshooting 4 03-14-2007 05:49 PM
Car Start sgails Toyota Prius Service Bulletins - TSBs 1 05-30-2006 04:01 PM
Horrible grinding noise upon cold start up... Mystery Squid Gen II Prius Main Forum 1 01-24-2006 10:36 AM
Loud clicking noise on cold start jsikora Gen II Prius Care, Maintenance and Troubleshooting 4 11-27-2005 12:50 PM
