| This is a discussion on Transaxle Oil Analysis within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi steve, both you and Edthefox are trying out non-WS and I hope that wea can eventually see chemical analyses ... |
| | #121 |
Friends: 14 | Hi steve, both you and Edthefox are trying out non-WS and I hope that wea can eventually see chemical analyses from these efforts. Thanks. |
| | #122 | |
I went with Redline D6 too around 15,000 miles ago. I dumped my 07's WS at 5K. I noticed an improvement in noise level and drivetrain seemed smoother especially at 85+ miles after the D6 install. Trying to wait till I have 30K on that fluid to replace it and at that time will have an UOA done on it. | |
| | #123 |
| Member Join Date: Nov 2007 Location: Webster, MA, New England, USA
Friends: 0 | I ordered mine online from here Red Line Oil. You can buy a gallon jug of D6 for $43 and it's just enough for the change. |
| The Following User Says Thank You to satwood For This Useful Post: | ETP (06-12-2009) |
| | #124 |
| Senior Member Join Date: Mar 2009 Location: USA
My Car: 2009 Prius Model: Package: #2 Thanks: 246
Friends: 19 | |
| | #125 | |
My Car: 2007 Prius Model: Package: #6 Thanks: 288
Friends: 11 | Quote:
I emailed them with the basic info, they gave me an address to send the sample to, they emailed me the results. My contact is Cheryl Huff, cheryl<at>randglabs.com (replace the <at> with @) | |
| The Following User Says Thank You to dogfriend For This Useful Post: | 2009Prius (06-16-2009) |
| | #126 |
| Ancient and decrepit Join Date: Apr 2009 Location: Crestview/North Florida
My Car: 2009 Prius Model: N/A Package: #6 Touring Thanks: 160
Friends: 57 | Boy no military discount/what a bummer. Ok the good news is WS is $7.70 a quart// no synthetic lable. Bad news is that they want $120 to dump and fill. They first quoted me $70 then changed their mind when I showed up. They said they had to use a computer. OK, I would have believed that was the only way if I was not a member of this forum. Then they said they have never did a fluid change on a Prius and it never needs one. Now this is a lie for sure because they have been in business for 20 years. I mentioned the forum and they said I should call Toyota. Not! OK, so I will have my local mechanic do it at 12K or I will do it myself. I really wanted the dealer to do this because I do not have the time to fool with it these days. But now it is the principle of the thing and I will have to make time. Last edited by ETP; 06-20-2009 at 06:18 AM. |
| | #127 |
Friends: 57 | PS// I wonder if the Honda CVT fluid would work? Does the Prius have a CVT tranny? |
| | #128 | |
My Car: 2010 Prius Model: III Package: #1 Thanks: 148
Friends: 20 | Quote:
Bob Wilson | |
| The Following User Says Thank You to bwilson4web For This Useful Post: | ETP (06-27-2009) |
| | #129 | |
My Car: 2004 Prius Model: Package: Base Thanks: 0
Friends: 10 | Quote:
JeffD | |
| The Following User Says Thank You to jdenenberg For This Useful Post: | ETP (06-27-2009) |
| | #130 |
| Senior Member Join Date: Oct 2005 Location: Chino Hills,CA
Friends: 0 | I finally got around to draining and filling the transmission in my 2005 Prius. After reading this thread, I went and bought the WS fluid at the dealer where I bough the car. This was after I inquired how much for a drain and fill. I was quoted $300 for the job. I declined and had a front wheel alignment and oil change with Mobil One instead. (usually do my own changes with M1 but had stitches on my toe from a surgery so I let them do this one). Maybe the service writer was confused about the price, but I decided right there to do it on my own. After finishing the job this morning(about 45 minutes cuz i took my time) I called two other dealers in the area. They averaged about $145 each to do the job. This was an easy DIY job, and I used the tools mentioned in this thread. First I opened the fill port, I heard the slight pressure hiss. I then opened up the drain port and positioned the used oil bucket in place, all went well with the drain. The drain plug did have some small metal shavings that looked like magnetic stuff on those magnetic drawing boards. I cleaned them off and tightened it up with the torque wrench. I already had a length of plastic tubing from the pump device that was also pictured in this thread. I just inserted one end of a small funnel into the top end, and ran the hose through the engine compartment after raising the hood. Almost all 4 quarts were added until a little bit of fluid started to trickle out the fill port. Tightened the fill plug up and wiped it down. That was easy, thanks for all who contributed to this thread. Looks like no one has added anything here on this thread for almost 5 months. I am curious to hear how the guys with the synthetic oils for tranny use are doing. Anyone care to add there experience using synthetic tranny fluids? By the way, sorry I did not do a used oil analysis. The color of the fluid seemed pretty red for the drops that stained a white paper towel, but while the fluid was draining, the stream looked pretty dark and had a different smell than the new stuff I added. I did have my tranny fluid changed at the dealer when I had about 77 thousand miles on it.(this fluid had about 43 thousand miles on it roughly) I decide to do it early because I drive high freeway miles, and that summer I had driven through Arizona desert temperatures in the 110 degree range. The dealer originally denied to do the first drain and fill but, they knuckled under when I insisted they do it as preventative maintenance. Now when I go to the dealer there is a computer message flag that comes up when my car is on the service computer. It says that I had them do the tranny drain and fill against their advice. I have 124 thousand miles on it now and I can say she is still running good. It even feels like there is less or none of the tranny pulsing and such when the ICE is running in park. Maybe some of you know what I am talking about, it seems the tranny wants to go while ICE is running and you are stopped in park. Almost slight pulsing or shuttering. I did the drain and fill when the car was cold. I leveled the front wheels on two ramps because my driveway is somewhat downhill. After the job, I drove up and down the freeway for about 8 miles, so far so good. I will be driving to the OC in awhile and will observe any changes when the car really warms up through the hills into the OC. Will post any anomalies I find. Wish me luck and thanks again to all who posted in this thread. EDIT: After driving through the hills, I noticed that the overall smoothness of the transmission is improved. The transitions to ICE ON and electric motors on while accelerating seemed much smoother than before the fluid change. The transitions from ICE ON and or ELECTRIC motors ON to coasting is much smoother now too. The MPG display is showing 49.9 right now after 150 miles on the current gas tank. Now if I can only have enough courage to replace the PCV valve I bought last year.
__________________ 125,000 miles and still running strong..carpool stickers since august 2005...whoo-hoo ![]() Last edited by KD6HDX; 11-10-2009 at 01:57 PM. |
| oil, transaxle |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/38524-transaxle-oil-analysis.html | ||||
| ????????? - ?????? - PriusClub.TW Prius,TW,TOYOTA PRIUS,???,Hybrid,???????,????,????? - Powered by Discuz! | This thread | Refback | 04-14-2009 05:23 AM | |
| ????????? - ?????? - PriusClub.TW Prius,TW,TOYOTA PRIUS,???,Hybrid,???????,????,????? - Powered by Discuz! | This thread | Refback | 04-14-2009 04:14 AM | |
| DRAFT Transaxle Oil Testing Results | bwilson4web | Gen II Prius Care, Maintenance and Troubleshooting | 32 | 11-14-2009 04:50 PM |
| '01 transaxle questions | ozron | Gen II Prius Technical Discussion | 18 | 03-02-2009 04:44 PM |
| Prius Transaxle Pics | C.RICKEY HIROSE | Gen II Prius Main Forum | 0 | 10-12-2007 08:54 PM |
| 2001 Transaxle Replacement | pkamm | Dealers & Pricing | 3 | 09-13-2007 11:55 AM |
| HV Transaxle cooler/filter | IFixEm | Gen II Prius Technical Discussion | 15 | 05-29-2006 09:24 PM |
