This is a discussion on Rough idle plus 'lumpy' start stop? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have a 06 Prius which the idle seems quite rough and lumpy. The main time I notice it is ...
Old 10-19-2007, 04:17 PM   #1
abtim
Thumbs up
I have a 06 Prius which the idle seems quite rough and lumpy. The main time I notice it is when the petrol engine comes in and out as the car shakes a little as if the engine doesn't quite turn off properly. When it comes on it then thumps in. The dealer says it is within limits blah blah.... but it just doesn't feel right.
Anyone else have this problem or at least; what is normal?
Cheers
abtim is offline
Old 10-19-2007, 04:55 PM   #2
Devil's Advocate
The automatic on/off differs depending on conditions. Some days you don't even notice and some days you're like the whole thing is shaking. Pretty normal. Cold usually causes rougher starts and stops.
Devil's Advocate is offline
Old 10-19-2007, 04:55 PM   #3
Friends: 14
This is normal. The ICE only stops in one position, and if it misses, MG1 will spin it around and try again. Most people notice these rough shut-downs when the engine is new, cold, or both. It's just part of the low emissions of the Prius.
Old 10-20-2007, 09:15 AM   #4
abtim
Thanks for that. It was less of the lumpy start stop which I do understand is to do with the engine clearing the fuel. The bit that I am not so happy about is that when the engine does idle iw it is charging the main battery or you have aircon on - the whole car shakes. I would have thought that a car of this expense would have a really smooth idle. My Saab of 200000 miles has a far smoother idle.
Any thoughts?
abtim is offline
Old 10-20-2007, 09:48 AM   #5
donee
Hi PriusBrit,
Water in the gas is my guess, if its allot different than previously. I had something similar happend, but it was 5 degree F for the high temp that week. Bought gas from a station I usually don't, as it was the only one with an open pump. Next tank, no problems, even at similar temps.
donee is offline
Old 10-20-2007, 12:35 PM   #6
hobbit
hobbit's Avatar
Ooh, that was the theory we came up with a couple of nights ago after
I tanked up, drove about half a mile and then let the car sit for a
day and a half. In the meantime someone who didn't quite understand
the user interface powered up to READY to get the windows open, and
powered off just after the engine lit for its warmup cycle. Next
time I went to start, the ICE felt like it was on about a cylinder
and a half for a little while, and then finally leveled out. It
was very humid that night and someone suggested "spark plug wires?"
until I pointed out that there aren't any in this car and the
ignitors are pretty well protected down in their little wells.
But a little water in the gas, that then had plenty of time to
settle down around the tank pickup, sounded plausible. The MPG was
also absolute crap for the first third or so of our return trip
home, and began to pick up a little later.
Keep in mind that we're getting into colder weather, and this tends
to make Priuses whose throttle bodies haven't been maintained and
cleaned well start droppin' like flies with no-starts. Happened
last year, too. Suggest you get out there and clean those suckers
up [don't spray, just wipe] while there's still some warm weather.
_H*
hobbit is offline
Old 10-20-2007, 12:41 PM   #7
hyo silver
awaaay
hyo silver's Avatar
Friends: 64
Sounds to me like it could be electrical. I had a similar, though more severe problem that turned out to be $500 worth of towing, plugs, and coils caused by water getting in. The Prius is not waterproof.
hyo silver is offline
Old 10-20-2007, 02:02 PM   #8
richard schumacher
Destination: Eschaton
richard schumacher's Avatar
<div class='quotetop'>QUOTE(hyo silver @ Oct 20 2007, 11:41 AM) [snapback]528178[/snapback]</div>
Did you ever wash or hose down the engine?
richard schumacher is offline
Old 10-20-2007, 02:13 PM   #9
hyo silver
awaaay
hyo silver's Avatar
Friends: 64
<div class='quotetop'>QUOTE(richard schumacher @ 2007 10 20 11:02) [snapback]528209[/snapback]</div>
No. Driving in the rain is apparently sufficient.
Old 10-20-2007, 02:20 PM   #10
abtim
Hi Hobbit
Is there a technical term for throttle body? Thought I could try that on the dealers
Thanks!
PS My MPG seems to have also dropped from 55 to 33. Bizarre.
abtim is offline
Comparing the Prius v. Honda hybrid idle-stop feature davide Gen II Prius Audio and Electronics 4 11-06-2007 04:35 PM
Rough start and loss of accelerator while driving steviet Gen II Prius Main Forum 7 03-11-2007 04:48 PM
Weird ICE start-stop at bottom of hill kinghuang Gen II Prius Main Forum 6 07-06-2005 06:02 AM
Rough Idle HTMLSpinnr Gen II Prius Care, Maintenance and Troubleshooting 35 02-26-2005 08:49 PM
Start, stop, start, stop ICE HTMLSpinnr Gen II Prius Main Forum 6 01-28-2004 11:08 PM
