This is a discussion on Prius Dead After Sitting 1 week within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; My wife returned home from vacation after a week and our Prius was dead (we thing a door was left ...
Old 12-29-2007, 10:16 PM   #1
Dilbert
Dilbert's Avatar
Default Prius Dead After Sitting 1 week
My wife returned home from vacation after a week and our Prius was dead (we thing a door was left open). She hooked up the battery charger at the low setting, which restores the interior power, but only gets the clicking of a relay whe she tried to start the car. The car will not "start" and there was a warning that the transmission has malfunctioned. I assume this car needs go be towed. Will the main battery really go dead if a door is left open? Anyone recover from this state on their own before?
Dilbert is offline
Old 12-29-2007, 11:17 PM   #2
richard schumacher
Destination: Eschaton
Default Re: Prius Dead After Sitting 1 week
Sounds like the car was not shut OFF. If so then a tow to a dealer is in your near future. Bummer.
After this is resolved, get in the habit of always locking the car no matter where you park it. If it is not OFF or if something is ajar it will warn you with a long beep.
richard schumacher is offline
Old 12-29-2007, 11:38 PM   #3
TonyPSchaefer
Your Friendly Moderator
TonyPSchaefer's Avatar
Friends: 23
Make sure you let the trickle charge work over night before you attempt another start.
When you say that there is a warning that the transmission has malfunctioned, is the warning on the MFD? If so, did you have the door open when you saw this warning because when you have the door open while the car is on you get some arcane warning that could be interpreted as a transmission problem.
Good luck. Keep us posted.
TonyPSchaefer is offline
Old 12-29-2007, 11:52 PM   #4
Dilbert
Dilbert's Avatar
I really don't think the car was left on. We left for vacation in our other car and this one was already in the garage from the previous night. I am not actally at home yet, and my wife knows little about cars, so it sounds like a tow. We decided not to leave on the trickle charge because here was a relay constantly tripping on and off when the charger was on and she could not get the car to "power down" either. The door could have been open. If I were home I would attempt to charge it, but I don't want her to take any chances. Thank goodness I got the extended warranty. We have had this 2004 for 3.5 years and it has 30,000 miles.
Dilbert is offline
Old 12-30-2007, 12:29 AM   #5
TonyPSchaefer
Friends: 23
Don't worry too much, Dilbert. I somehow managed to drain my 12v battery a couple years ago. After a jump start from AAA, all was well. In fact, I'm still running on that same battery even though some have told me to replace it. I just never got around to it.
In short, this isn't a big deal. The hybrid battery is just fine. If your wife can't start the car (in my case, I had a heck of a time turning it off) than it's the little 12v and not the hybrid battery. After all, it's the 12v that actually starts the car.
Proud father of Priapus: the '04 Tideland BC9 with an OEM EV button and sense of self-righteousness
Current Mileage
Chicago Prius Group Website
Chicago Hybrid Group on FaceBook
Find me on faceBook
Old 12-30-2007, 09:05 AM   #6
Friends: 37
You need to do what you feel you need to do, but this doesn't sound like a towing situation.
I think you need a jump start.
The only other thought I had is that your battery may be dead. I don't know what year/how old your Prius is, but you joined in '04 so it may be as much as almost 4 years old and the 12v could be nearing the end of it's useful life and not holding a charge well.
efusco is offline
Old 12-30-2007, 01:40 PM   #7
Doc Willie
Shuttlecraft Commander
Doc Willie's Avatar
Friends: 11
Where are you attaching the trickle charger? If you are going through the cigarette lighter/power ports, it won't work.
And a trickle charger may actually have enough juice to start the Prius if you follow the friendly owner's manual.
Doc Willie is offline
Old 12-30-2007, 09:05 PM   #8
jayman
A very low or dead 12 vdc battery will cause very odd system behavior.
You can hook the charger to either the underhood jump point, or directly to the 12 vdc battery. The underhood jump point is easiest.
I have posted in previous threads the TSB regarding how to properly charge the Prius 12 vdc battery. Toyota does recommend an automatic battery charger - one with their own brand of course! - at the 10 amp setting.
A 12 vdc battery that has been in a dead state for a few days or longer, will need a lot more than 2-3 amps before accepting charge. For some truly dead batteries (Lights left on all day) I have had to use a 60 amp setting
jayman is offline
Old 12-31-2007, 09:11 PM   #9
bigj3347
I was out of town for three weeks and forgot to turn off the sks. When I got back, the sks was turned off but my car was able to start fine, you might want to get the battery checked. just my 2 cents.
bigj3347 is offline
Old 12-31-2007, 11:01 PM   #10
patsparks
An Aussie perspective
patsparks's Avatar
Friends: 33
Remove the negative battery lead from the battery terminal, leave the charger connected directly to the battery for a few hours, reconnect the battery and try again.
Good luck.
patsparks is offline
