2007 Tail light removal instructions
Old 01-06-2008, 03:53 PM   #1
Default Tail light removal instructions w/ pics
Long story short the top layer lens cracked on my left tail light. You can't replace just the lens it's all one complete assembly as others have mentioned in other posts.
I decided to take a few pictures to help out others.
Tools you will need-
1-10mm 2" long socket and wrench plus 3" extension
2- Smaller width flat blade screw driver.
3- Strong fingers
4-Gentle Touch
Steps to reach tail light assembly (mine was the driver side tail light).
1-Fold Down the rear seats
2-Remove the privacy trunk blind bar
3-Remove three seperate 10mm bolts as shown in pictures:
Click the image to open in full size. Pull the silver toggle out once you pull the bolt
Inside that hole is a super long bolt-Use the wrench extension here
4-Pull the trim away from the car to expose the hidden retention clips and pull out the clips:
5- Pull the plastic trim apart:
5a- Start in the back
5b- Pull down and out in the middle:
Click the image to open in full size.Click the image to open in full size.
5c- Pull back, down and out at this area. I grabbed where the shade slides into- this will require extra force:
6-Remove the trunk light wiring clip:
7-Un-clip the tail light harness using a small width flat head:
8- now that everything has been separated from the wall you can pull/push the carpeting away from the tail light assembly and remove the two bolts for the tail light using the 2" long 10mm socket:
Bottom Bolt
Top Bolt
Tada- now just push the assembly out from the inside and put the the new one in place.
Follow the steps in reverse to put it all back together.
Remember to be gentle yet firm when you pull all this stuff apart. I've pulled off trim in the past and it takes some finesse and skill to not break stuff.
This should be a 15 minute job to do .
It cost me $165.00 to get a replacement assembly from my buddies auto body shop.
I used my cell phone to take these pictures so I apologize if they may be poor quality
Feel free to PM me with any questions/issues.
msoengineer is offline
Thanked by 9 Users:
2004 Prius Guy (03-17-2012), 2004and2010 (10-23-2011), archiveman2977 (03-25-2011), blueumbrella (09-07-2009), Boo (09-07-2009), gleneagle1 (12-04-2010), Irn (09-04-2009), krg03 (09-14-2010), moussehead (09-19-2009)
Old 01-06-2008, 08:18 PM   #2
seasalsa's Avatar
Model: II
Default Re: 2007 Tail light removal instructions
Don't apologize about the pictures, great info.
Thanks
seasalsa is offline
Thanked by:
Old 09-07-2009, 02:21 AM   #3
Package: Comfort
Dear msoengineer- I had a small break in my driversside taillight that I had patched with clear ducttape and it was just fine. But my 07 didn't pass inspection (FY TiresPlus PA). TP wanted $350 to replace it. Well, thanks to Your excellent instructions I ordered the part on Ebay for $130 and replaced it myself! Took this girlie about an hour; first repair I ever attempted. Thank you so much, I did not break anything in the process and it was a great boost of self-confidence. Bless you dude!
notmyrealname is offline
Old 09-07-2009, 08:04 AM   #4
An Aussie perspective
patsparks's Avatar
Friends: 36
Well done notmyrealname and thanks to the OP for posting this thread.
PriusChat has saved me thousands of dollars, it really has. Thanks everyone!
patsparks is offline
Old 10-03-2009, 03:53 PM   #5
MSO
just wanted to say thanks for your clear explanation and pictures...thanks for taking the time to share your knowledge....Got my replacement tail assembly on EBay for $110 and installed it in under 20 minutes!!!
be easy
Zinn
zinndeadly is offline
Old 09-14-2010, 12:39 AM   #6
Model: II
Thanks a bunch for the great article.
I was able to replace a broken driver's side brake light; however now the turn signal the light itself doesn't work! Any ideas how to troubleshoot this problem?
Thanks in advance.
splunge is offline
Old 09-14-2010, 12:46 PM   #7
The turn signal is a regular bulb. Make sure that it is good, and properly installed.
vertex is offline
Old 09-14-2010, 07:09 PM   #8
Model: II
Gah. Yeah. I replaced the part and forgot to install all of the other light bulbs. Once I did that it works like a charm.
Thanks for the pointer.
splunge is offline
Old 09-14-2010, 07:16 PM   #9
Not expert, just experienced
Model: II
Default Re: Tail light removal instructions w/ pics
Great job. Another "how to" to add to my list.
krg03 is offline
Old 10-05-2010, 02:57 PM   #10
Bought a new unit on E-Bay to replace my cracked lens (parking lot tap, crack and run). Thanks for the write-up and pics. My passenger side replacement went very smoothly.
BOB
Speedwing is offline
2007, instructions, light, removal, tail
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/41423-2007-tail-light-removal-instructions.html
Mi Toyota Prius - Desmontaje piloto trasero Prius 2004 - Prius 2004/2005/2006/2007/2008/2009 This thread Refback 07-17-2011 07:28 PM
Mi Toyota Prius - Desmontaje piloto trasero Prius 2004 - Prius 2004/2005/2006/2007/2008/2009 This thread Refback 07-17-2011 05:39 AM
Prius-2G : Messages : 80816-80861 of 84214 This thread Refback 03-04-2011 10:36 AM
Sunglasses This thread Trackback 02-03-2011 10:14 AM
Prius links This thread Refback 01-09-2011 10:32 AM
blekko | Prius tail light removal This thread Refback 11-01-2010 08:21 PM
Prius links This thread Refback 05-13-2010 05:07 PM
