This is a discussion on Oil Plug Torque within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; What is the recomended torque for the oil plug on my prius? I wouldn't think it should be too much, ...
Oil Plug Torque
Old 01-18-2008, 04:59 PM   #1
jmatuska
Default Oil Plug Torque
What is the recomended torque for the oil plug on my prius? I wouldn't think it should be too much, not too tight, but not too loose. However when I started changing my own oil (after my first two free from my dealer) I had to use a 2 foot breaker bar to get the oil plug loose, it was that tight. It was like the dealer used an air wrench to put it on. I'm pretty sure that it too tight. What is the official torque setting for the oil plug? Also what about the lug nuts?
jmatuska is offline
Old 01-18-2008, 06:42 PM   #2
OverTork
OverTork's Avatar
Default Re: Oil Plug Torque
Oil pan drain plug 28 ft/lbs (38 N/m). Lug nuts for standard wheels, I don't know if the Touring wheels are different, 76 ft/lbs (103 N/m). This one is in the owners manual.
OverTork is offline
Old 01-19-2008, 07:35 PM   #3
dorf
That's the correct torque according to Toyota.
But.....But .......It seemes way too much.
My original plug torque was way less.... really really easy to come off.
28 foot pounds is allot of torque.---That's 336 inch pounds. Must be a mistake in translation.
dorf is offline
Old 01-19-2008, 08:33 PM   #4
jayman
I just go hand tight with a new plug gasket. Plenty tight enough.
For the lugnuts I use the torque wrench as I don't want to take a chance and warp a rotor. Ironically, my FJ Cruiser not only has the same 76 ft lbs lug torque, it even takes the same size and thread lugnut
That made it very handy to get conical seat lugnuts for the steel winter wheels. I actually did try one from my Prius, it couldn't hurt and I was pleasantly surprised it worked
jayman is online now
Old 01-20-2008, 02:35 PM   #5
lefat1
Fat Member
lefat1's Avatar
Friends: 9
i think youre referring to the filter
lefat1 is offline
Old 01-20-2008, 02:38 PM   #6
lefat1
Fat Member
lefat1's Avatar
Friends: 9
as a reference, 21 ft/lbs is normal for spark plugs, so 28 for this application seems about right
lefat1 is offline
Old 01-20-2008, 04:49 PM   #7
okiebutnotfrommuskogee
okiebutnotfrommuskogee's Avatar
Package: #1
[quote=jayman;547073]I just go hand tight with a new plug gasket. Plenty tight enough.
76 ft lbs is probably pretty standard for Toyota aluminium wheels. My Avalon uses 76 ft lbs too.
okiebutnotfrommuskogee is offline
Old 01-20-2008, 05:02 PM   #8
patsparks
An Aussie perspective
patsparks's Avatar
Friends: 33
I think he means hand tight with a spanner.
A normal ring spanner is the right length to tighten a fastener to roughly the right torque.
If the wheel studs on 2 different cars are the same size they will have the same torque spec. You will find the pitch circle diameter of the Cruiser is a lot bigger than the Prius which makes it a much stronger attachment.
patsparks is offline
Old 01-21-2008, 12:08 PM   #9
jayman
Originally Posted by patsparks View Post
I think he means hand tight with a spanner. A normal ring spanner is the right length to tighten a fastener to roughly the right torque.
That's right. The ratchet is about 25 cm long, from ratchet head to end of handle.
Yes, in addition the Prius has 5 lugnuts holding the wheel down, my FJ Cruiser has 6 lugnuts holding the wheel down
The wheel on the FJ is a lot heavier too, as it's a much larger tire. The standard tire on the FJ is P265 70 17 on a factory alloy wheel.
For winter I'm running a studless snow/ice tire in P265 75 16, as it has the same outside diameter. Am running a cheap steel wheel due to the road salt used here, saving the alloy's for when there is no salt on the roads. The 16 inch tire on steel wheels is actually heavier than the factory alloy with 17 inch tires
For those contemplating running a steel wheel in winter, remember you must get the proper conical seat or "acorn" lugnuts. The factory alloys use a shank style lugnut that will dangerously loosen up on an aftermarket steel wheel
Old 01-21-2008, 04:34 PM   #10
N3FOL
N3FOL's Avatar
Cool Re: Oil Plug Torque
I've done over 250 oil changes throughout my lifetime. Believe it or not, I never use a torque wrench just to tighten that oil drain pan bolt. Simply tighten it snuggly (but not loose) and that should do it. I've heard of people stripping their oil pan thread, because they over torqued the bolt using a torque wrench.
N3FOL is offline
