| This is a discussion on Prius did not start within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi! I pulled out the serviceplug (model 2008) to get acess to the HV-Battery for measering purposes. Unfortunately the car ... |
Prius did not start
| Junior Member Join Date: Feb 2008
Friends: 0 | Hi! I pulled out the serviceplug (model 2008) to get acess to the HV-Battery for measering purposes. Unfortunately the car noticed this and now the Hybrid System is not starting. It shows the red "!" in the triangel. Must i delete some error codes in the memory or is there a easier way to reset the system. (prepearing for PHEV conversion) Thank you in advance for your answer, its urgent! Mike |
Friends: 10 | I assume you tried starting multiple times? Some error codes require a few reboots to clear. I also assume you correctly reinstalled the service plug. Tom |
Friends: 0 | Hi! Thank you very much for your answer! I tryed starting the hybrid system about three times. i have no diagnistic tool (ODB2) Waht do you mean with reboot? Do i need a odb2-tool? Mike |
My Car: 2005 Prius Model: Package: Thanks: 3
Friends: 9 | |
| Michigan Member Join Date: Mar 2007 Location: South Lyon, Michigan
My Car: 2007 Prius Model: N/A Package: #2 Thanks: 0
~~~~~~ Since he's asking about a reboot and ODB2 tool I'd assume the problem has not gone away. Last edited by SpartanScott; 03-22-2008 at 02:48 PM. | |
Friends: 0 | The thanks was for the quick anser! I tryed exact 4 times .. no change in the behavior. I can switch to neutral but not to "d" the red "!" with the triangle lights near the speed-meeter display and a red car with a "!" lights up on the lcd screen. Mike |
Friends: 9 | Quote:
did you check if the HV plug is really put back in correctly it needs to click or something | |
Friends: 0 | i pluged it back in and slided the handle up .. its realy fixed in place. the system was off when i worked with te plug. is this the normal behavior,that the error sign lights up whem the hv plug is removed? Mike |
Friends: 0 | was removed! (not is) |
| Senior Member Join Date: Jun 2004 Location: hell
My Car: 2004 Prius Model: N/A Package: #9 Thanks: 9
Friends: 5 | isn't the 12v supposed to be disconnected before you take off the hv battery? i remember hearing a situation like this before and it ended up costing the owner. i would check over everything a few more times. |
