This is a discussion on ice shutdown vibration within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; i searched the forums and did not see any related posts. Has anyone else noticed when the ice shutsdown it ...
Old 10-12-2004, 12:50 AM   #1
toolbox
Default ice shutdown vibration
Has anyone else noticed when the ice shutsdown it can cause an excessive vibration almost like a broken motor mount. i have noticed my car starting to do this harder and harder. this morning when coming to a red light the ice shut down and it sputtered 2-3 seconds hard enought to feel a vibration through the steering wheel. from what i have read the ice is under load during shut down and you are going to feel it quit but i dont think it should spill your coffee either. i talked to a couple shops all said this was not normal. any ideas? oh yea 3k miles
toolbox is offline
Old 10-12-2004, 02:51 AM   #2
seeh2o
Prius OG
seeh2o's Avatar
Check out these links:
http://www.priuschat.com/forums/viewtopic....ighlight=shimmy
http://www.priuschat.com/forums/viewtopic....&highlight=idle
http://www.priuschat.com/forums/viewtopic....highlight=rough
seeh2o is offline
Old 10-12-2004, 03:46 AM   #3
eak354
eak354's Avatar
Default Re: ice shutdown vibration
it's something that get's better or less noticeable as you break-in your car. when i first got mine those 'shudders' of the shutting down of the ICE did kind of unnerve me at first... wondering if they were normal. then as i got used to them i seldom even notice it anymore... and when i do i welcome it knowing i'm going stealth! :mrgreen:
eak354 is offline
Old 10-12-2004, 11:26 AM   #4
DaveinOlyWA
3rd Time was Solariffic!!
DaveinOlyWA's Avatar
the shutter is normal and will lessen as the car warms up and breaks in over time.
also the fact that the engine design in the Prius opens all the valves at the same time lends to more momentum to the flywheel. in a normal engine when a valve is always closed and therefore providing some resistance to the flywheel, the shake is not pronounced since when the engine is shutoff, valve pressure allows less than one full revolution of the engine.
in the Prius, the flywheel may rotate 2-3 full revolutions before coming to a stop.
DaveinOlyWA is offline
Old 10-12-2004, 12:00 PM   #5
toolbox
thanks for the links and follow up guys.
i feel a lot better now knowing other people have noticed this also and have had no problem
toolbox is offline
Old 10-12-2004, 12:22 PM   #6
onerpm
My Car: Other Hybrid
my 2004 still has the occasional "rough" shutdown after 12,000 miles.
however, I'm currently testing the theory that it might occur (or be worse) more often when I don't have my foot firmly planted on the brake.
rpm
onerpm is offline
Old 10-12-2004, 04:43 PM   #7
toolbox
i have noticed the electric doesnt shut off unless you press firmly on the brake also thanks for the tip i am gonna watch that
toolbox is offline
Vibration on first engine shut down Winston Gen II Prius Technical Discussion 9 02-14-2009 04:08 PM
Engine Rev and Tire Vibration? alexstarfire Gen II Prius Care, Maintenance and Troubleshooting 1 04-21-2007 11:01 PM
Rearview Mirror Vibration Stilview Gen II Prius Main Forum 8 05-21-2005 01:33 PM
Rearview Mirror Vibration Stilview Gen II Prius Care, Maintenance and Troubleshooting 0 05-16-2005 08:36 PM
Vibration PetersPrius Gen II Prius Main Forum 3 05-31-2004 07:32 AM
