| This is a discussion on 30,000 Mile Recommendations within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have a 2005 Prius, purchased used. I don't have an official Toyota booklet on needed service. I downloaded the ... |
| Junior Member Join Date: Feb 2005 Location: SW Michigan
Friends: 0 | I have a 2005 Prius, purchased used. I don't have an official Toyota booklet on needed service. I downloaded the 30,000 mile from toyota. com. All I can find are things that need checking in addition to the routine items I have done by a local mechanic. Are the items listed as to be checked sufficient? |
Friends: 44 | Quote:
When you get up to 60K miles you may want to add the following items to the list: - replace transaxle fluid - replace PCV valve Also, you may want to think about replacing the 12V auxiliary battery when the car is 5 or 6 years old as a preventive measure. If you live in an area with cold winters, sooner vs. later would be better. | |
