This is a discussion on Lube Service Question within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I'm going to be changing my own oil, oil filter, and air/cabin filter on my new 2008 Prius. However, I'm ...
Old 04-04-2008, 10:02 AM   #1
Aaron
Aaron's Avatar
Package: #5 Touring
Default Lube Service Question
However, I'm going to the dealer for tire rotation and "lube". Now, when I think of lube, I think hitting the grease-points under the car with a lube grease gun. Does the Prius have these grease-points like normal cars? No one mentions it. How often should this be done?
Anything else I should get done at the every 5000 mile service besides "lube" and tire rotation?
Aaron is offline
Old 04-04-2008, 10:24 AM   #2
hobbit
hobbit's Avatar
Default Re: Lube Service Question
I haven't seen any zerk fittings [grease tits] in my travels
underneath the car. All the balljoints and the like seem to
be permanently sealed.
_H*
hobbit is offline
Old 04-04-2008, 12:00 PM   #3
richard schumacher
Destination: Eschaton
There are no grease fittings, but that will not stop a dealer from charging you the full price for his 5k miles service special.
Everything that the car needs for normal service is stated in the scheduled maintenance guide (a separate document from the owner's manual). Use it, follow it, and save money.
richard schumacher is offline
Old 04-04-2008, 01:35 PM   #4
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
There's nothing to "lube"; save your money.
Why not invest in a couple of jackstands and a hydraulic floor jack, and rotate the tires yourself? Think of this as part of your physical fitness program, and owning those items will make it much easier when you drain the engine oil and replace the oil filter.
If you must pay for tire rotation, I suggest the initial rotation at 5K miles; then rotate at 10K mile intervals.
Patrick Wong is offline
Old 04-04-2008, 04:00 PM   #5
Aaron
Aaron's Avatar
Package: #5 Touring
Good advice. Thanks. This Prius just keeps getting better.
But...will the dealer try to void my warranty when he finds out I haven't brought my Prius in every 5K miles?
For example, when I hit 60K miles and want my PCV Valve replaced, won't the dealer see that I haven't been in before and try to say "By the way, you voided your warranty by not coming in here in the last 60K miles"
FYI...I also bought the 100K Warranty for $980. Probably will never need it, but oh well.
Aaron is offline
Old 04-04-2008, 04:09 PM   #6
Patrick Wong
DIY Enthusiast
Friends: 44
This is why you must keep receipts for the filters and oil that you purchase, as well as maintain a good record of what you do, when you do it, and the odometer reading.
When you get to 60K miles maybe you'll decide you can replace the PCV valve yourself, hence no need to hear stories and lies from the dealer service staff.
Old 04-04-2008, 04:19 PM   #7
Aaron
Aaron's Avatar
Package: #5 Touring
Gotcha. Now I DO believe the Prius has the lowest ownership cost of any vehicle
Aaron is offline
Old 04-04-2008, 07:36 PM   #8
Weinerneck
FWIW
We got the same warranty, 4 years/100,000. We also just replaced both front hub assemblies at 77,000 miles, $800 for both sides. Guess we're getting are money back.
Bill
Weinerneck is offline
Old 04-05-2008, 01:30 PM   #9
jayman
Originally Posted by hobbit View Post
I haven't seen any zerk fittings [grease tits] in my travels underneath the car.
grease tits, I like it!
Nope, no zerks on my Prius either
Oddly enough, my FJ also has no zerks on the balljoints or tie rod ends. You would think a vehicle intended for off road travel would be equipped with zerks on suspension components
However, the u-joints on my FJ do have zerks. Planning on taking my grease gun and hitting those grease tits sometime this weekend
jayman is offline
Old 04-05-2008, 02:37 PM   #10
hobbit
hobbit's Avatar
remember to do it while naked
_H*
hobbit is offline
