| This is a discussion on Strange noise when starting within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by TSFlyer ...I've just recently started experiencing the same ticking noises described in this thread and like the ... |
| | #11 |
My Car: 2007 Prius Model: N/A Package: #4 Thanks: 57
Friends: 46 | That is the sound of the engine coolant heat recovery pump working to move hot coolant from the thermos container into the engine, which is a pollution-control activity. The sound is normal. |
| | #12 |
| Junior Member Join Date: Nov 2007
Friends: 0 | Thanks for the reply Patrick. I'm curious why the sound would only show up around 9,500 miles. Like I mentioned before, I'm keenly aware of the different sounds of the Prius, but the heat recovery pump ticking is a new one for me, even if it is normal. |
| | #13 | |
Friends: 46 | Quote:
Well - either you are now more aware of the various sounds that are being made; or the pump may be noisier now, than when new. Others have complained about a noisy pump. Some owners have been able to get the pump replaced under warranty, while other dealer service depts say this is normal, don't worry about it. If the noise bugs you, then I suggest you consult with your dealer's service writer. | |
| | #14 | |
| Senior Member Join Date: May 2007 Location: Arlington, VA
However since it only happens on a cold start I won't be able to demonstrate it for the dealer. So I'm waiting to see if it gets worse. Maybe next winter when temps drop it will happen more often and I can show the dealer. I've still got almost 2 years on my warranty. | |
| | #15 |
| Senior Member Join Date: Jun 2005 Location: Long Island
Friends: 0 | The Prius makes all sorts of strange noises, but it has worked perfectly for 65k so I don't worry about it. |
| | #16 | ||
Thanks again. TS | ||
| Strange noise??? | gforeman | Gen II Prius Main Forum | 3 | 11-07-2007 05:14 PM |
| Strange noise | AOV | Gen II Prius Care, Maintenance and Troubleshooting | 5 | 08-26-2007 11:10 AM |
| strange noise? | kleinchen | Gen II Prius Main Forum | 0 | 06-14-2007 06:06 PM |
| Strange Noise | heliotropehead | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 08-03-2006 07:25 AM |
| Strange noise ??? | G-Man | Gen II Prius Main Forum | 0 | 12-31-1969 07:00 PM |
