| This is a discussion on Warm A/C when Idle within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by scorpionsix A week later, I have found that if I turn off the Auto AC, and set ... |
Warm A/C when Idle
| | #11 |
Friends: 0 | That sounds peculiar. What happens if you leave it in Auto and simply set the temperature lower? But hey, whatever works :_> |
| | #12 |
| Junior Member Join Date: May 2008 Location: Glendale, Arizona
My Car: 2005 Prius Model: Package: Base Thanks: 0
Friends: 0 | So, do all your vehicles run "ice cold" when idle or moving below 10 mph? Is this the same when the outside temps are around 85 to 95 Degrees and your car is warmed up? Currently, my AC is only "ice cold" above 60mph and above 20 mph its cold. But at low speeds and idle the AC feels like the ac isn't even on and I am simply blowing outside air in (mildly cool - like a warm day in the shade)... Have a 2nd appointment to verify that I am not crazy - if this fails then I will be test driving a newer Prius to see if what my car is doing is normal. Thanks again to everyones comments! |
| | #13 |
Friends: 0 | Yes, nice and cold when the car is not moving. I agree it's not as cold as when the car is moving fast, but if you can't feel it at all then something is broken. |
| | #14 |
Friends: 0 | 3rd and Final Follow-up $1725 dollars later (of which $1675 was covered by extended warranty) I am now happy to report that my AC is cold all the time. It turns out the compresser was coming a part internally and was only putting out 75 volts on High (when it should have been around 195 volts). A new receiver/dryer & compresser was installed and the system recharged. NOW LIFE IS GOOD in the HOT Phoenix Summer weather! Thank you all for your helpful responses |
| | #15 | |
| Senior Member Join Date: Oct 2007 Location: Gilbert, AZ
My Car: 2008 Prius Model: Package: #6 Thanks: 1
Friends: 1 | Quote:
Also, many may think their A/C is working perfectly if they for example live in Canada.... but in the southwest US, we really push our A/C and if it's not 100% we can feel a difference when we're trying to cool down a 150 degree interior that's been sitting baking under the sun on a 115 degree day. | |
| | #16 |
Friends: 0 | Thanks for the offer! If my last service visit did not fix the problem, I was considering trading in the car because you are SO right about the HOT temperatures here. Comuting in the HOV lane was always cool inside, but when you drive up to an accident or looky-loo's and have to slow down, it was almost cooler to simply roll the window's down. I can not begin to put in words how much I missed my Prius when I had to drive in the regular lane -- Commuting 30 miles one way. It Sucked! Thanks Again! |
| a/c, air conditioning, hot climate, temperature |
| Idle Check | The Tramp | Gen II Prius Fuel Economy | 3 | 05-10-2008 02:06 PM |
| Prius Idle | perryma | Gen II Prius Main Forum | 3 | 04-15-2008 10:43 AM |
| MPG decline when off or in idle | Dr Ed | Gen II Prius Technical Discussion | 5 | 04-12-2008 01:07 AM |
| Idle Charge | mss | Gen II Prius Main Forum | 5 | 04-13-2005 12:40 AM |
| Rough Idle | HTMLSpinnr | Gen II Prius Care, Maintenance and Troubleshooting | 35 | 02-26-2005 08:49 PM |
