| This is a discussion on My HID bulb replacement on my 06 prius within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by kevin_rf Philips D2R 85126 HID Xenon off of ebay (genuinexenon). Time to go figure out how the ... |
| | #111 | |
Friends: 4 | Quote:
Sorry to hear that.... your one of the very few that has not alleviated the symptoms with a mere bulb change. I'm not sure of the properties of those Phillips.... my guess is they are close to the specs of what is "supposed" to work but since these ballast are in suspect, possibly the cheaper ones do better "they require less voltage". At this point, do you still have your old oem bulbs?.... if so, maybe call that number and see if you can get satisfaction. If they will..... keep those phillips as spares. Theres always a small chance you got a bad one..... switching the bulbs from right to left to see if the symptoms switch is the best way to tell. There is also a chance one of the high school kids "touched" the bulb and it gets too hot now...... but I would think that would just cause premature failure..... not sure about that one. I have bought 4 of the ebay bulbs and one did soon start with the same symptoms, I simply put one of my OEM bulbs in its spot that never exhibited the symptoms and all has been well for close to 40K now. Yes, there is a tiny bit color difference during warmup between those two bulbs, but once they are good and hot, its really hard to tell and kelvin difference... they are very close.
__________________ Alan ________________________ 2010 Blue Ribbon Metallic IV with Bisque leather...."My Blue Baby" And my "other" cars...... 2006 Barcelona Red Prius Pkg #8 with Bisque leather.... Yea Baby, Yea! "The Hot Tamale" 2006 Silver Pine Mica Pkg#8 with Bisque leather.... "The Mint Julip" 2006 Mods so far: 1. Coastal EV switch 2. BT stiffening Plate 3.Zaino "the works" 4. Heat Shield "from Canvas Works" 5. Magnetic Oil plugs - Yes they work and you want them! 6. Speed sensor now switched! Last edited by windstrings; 11-07-2009 at 09:39 AM. | |
| bulb, hid, prius, replacement |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/47938-my-hid-bulb-replacement-my-06-prius.html | ||||
| Is Toyota HIDing from Prius Headlight Problem? | The Truth About Cars | This thread | Refback | 06-30-2009 10:45 PM | |
| Headlamp (bulb) replacement | p626808 | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 05-02-2008 09:41 AM |
| Fog light bulb replacement | ISherman | Gen II Prius Care, Maintenance and Troubleshooting | 3 | 10-27-2007 05:45 PM |
| Taillight Bulb #'s | treehggr | Gen II Prius Main Forum | 6 | 08-18-2007 09:21 AM |
| Bulb replacement | astroqb | Gen II Prius Care, Maintenance and Troubleshooting | 6 | 06-21-2007 03:23 AM |
| Best foglight bulb | nesss01 | Gen II Prius Modifications | 9 | 02-10-2006 06:11 AM |
