| This is a discussion on Intermittant, Single BEEP within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; After 2,000 miles, my 08 Touring suddenly developed an odd, intermittant, single beep from somewhere in the dash. It happens ... |
| Junior Member Join Date: Apr 2008 Location: Bremerton, WA
Friends: 0 | After 2,000 miles, my 08 Touring suddenly developed an odd, intermittant, single beep from somewhere in the dash. It happens irregularly, but usually with at least a minute between beeps. "One ping, only", but no display warnings or dash lights. No weight on passenger seat, drivers belt fastened, not in reverse (although the beep is the same tone/pitch as the reverse beep). Clues?? |
| Junior Member Join Date: May 2008 Location: Little Egg Harbor, NJ
Friends: 0 | You will get a single beep when the last pip on the gas gauge starts flashing to indicate low fuel. |
| Senior Member Join Date: Jun 2005 Location: Long Island
Friends: 0 | Just out of curiosity - I always let the gas go down to flashing before filling up so I am used to the "add fuel" warning. Is there another more serious warning before you run out of gas? I have driven over 40 miles on a flashing gas pip and never run out. |
| Senior Member Join Date: Nov 2007 Location: Hobbs, NM
Friends: 0 | From all the posts I've read on running out of gas, I think you've been lucky so far not to run out of gas. |
Friends: 10 | Quote:
Tom | |
Friends: 0 | You probably have about 2 gallons of fuel left when the last pip begins to flash, so that's why you haven't run out yet. I understand it is not good for the fuel pump to consistently let the tank run that low. |
| Senior Member Join Date: Jul 2007 Location: Sydney, Australia
My Car: 2007 Prius Model: N/A Package: Base Thanks: 6
Friends: 3 | I don't think that it is the low fuel warning that the OP is hearing. I have had the one-off beep with no warning lights, more than half a tank of gas, everyone buckled in, crusing along at the speed limit. I have heard it now only a couple of times, not enough to identify a possible cause. I have thought that it may be a traction control warning, but the last time I was not braking, just comfortably cruising with the traffic flow. Also, courtesy of a neighbour who is re-building their home, I do get a traction control warning flash nearly every day as I need to brake just as I go past their house and hit the rough patch that their plumber put into the road when he connected to the sewer. But this just gives me a flash on the dash, no beep. So, anyone else who can offer a possible cause for the beep?
__________________ Eric Crystal Blue 2007 Prius Base Model - Schneider reversing camera added |
Friends: 0 | Can the "scheduled maintenance reminder" have gotten confused somehow? |
| Senior Member Join Date: May 2007 Location: Arlington, VA
Friends: 0 | |
| sexy, high tech, fun Join Date: Apr 2008 Location: Kentucky
Friends: 5 | . If you have Sirius, it could be an accidental setting to be reminded whenever a favorite artist's song is on. That happened to me and caused a beep confusion for a couple days. . |
| [ KB ] How to eliminate Reverse Beep & Seatbelt Beep | Danny | Knowledge Base Articles Discussion | 65 | 06-12-2009 03:56 PM |
| single beep upon shutdown | kawagreg | Gen II Prius Care, Maintenance and Troubleshooting | 26 | 01-13-2009 05:11 PM |
| Cruise Control intermittant | emosca | Gen II Prius Main Forum | 4 | 10-02-2007 10:11 AM |
| Disabling reverse beep/seatbelt beep on an 06' | Paradox | Gen II Prius Main Forum | 31 | 05-30-2006 10:53 PM |
| Disabling the reverse beep (and seatbelt beep) | dougkm | Gen II Prius Main Forum | 1 | 12-01-2003 07:42 AM |
