| This is a discussion on rapid HV battery drain on startup hot days only within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; We are having a problem with rapid HV battery drain after startup on hot days, from green to 2 or ... |
| Junior Member Join Date: Nov 2007 Location: Santa Clarita, CA
Friends: 0 | We are having a problem with rapid HV battery drain after startup on hot days, from green to 2 or no bars in 1/2 mile the following relates our experience Our car is a 2008 Prius package 2 purchased in November 2007 with 9000 miles ![]() date Last edited by mikemartin9; 06-08-2008 at 05:15 PM. Reason: add and remove table |
| Wrnchs OScopes Computers oh my Join Date: May 2008 Location: Ottawa/Aylmer, Canada
My Car: 2008 Prius Model: Package: Pioneer #3 Thanks: 2
So you are getting 43-44 MPG now. What were you getting before ? Where you having any 80 degree days before this started ? Sounds like dealer is trying to blow you off if your mileage suddenly plummetted and battery discharge characteristics changed quite a bit. I achieved a new "first week of ownership" mileage records Friday morning of 63 US MPG with no AC and temps about 70-75. I drove with the same techniques home with AC and temp about 85 and very humid and I got about 18% less, about 52 US MPG. This was half city, half 35-45 MPH straights, some hills but even overall.
__________________ 2008 "Canadian base" (Touring pkg 2++): PSI: 50/48. Best 40 mile RT commute max 31-44 MPH: 60 US MPG. (37-50 MPH: 54 MPG) Why: (1) thrift, (2) Priups/PHEV hackable, (3) ecology. Week 5: 1250 miles, 3MClearbra, oil lower, 50/48 PSI, Trim ring remov, ScotchGard, UOA. Last edited by hiremichaelreid; 06-07-2008 at 08:16 PM. | |
Friends: 44 | Your log is fascinating. Most of the time when you arrive at work you show 8 green bars.
__________________ 2006 Highlander Hybrid 4WD-i 2004 Prius 2001 Prius (sold Feb. 2008, 75K miles) 2000 Ford Mustang GT conv. |
Friends: 0 | I'm seeing a troubling hot weather battery related low MPG complaint trend here. 3 different threads started in the last few days: sudden battery discharge rapid HV battery drain on startup hot days only Drop in performance / mpg? Going to dealer, please help! I'm thinking this could be a widespread "defect" in Gen-II Prii... |
Friends: 44 | Quote:
We really haven't seen many 2G owners report that their traction battery needed replacing. It is about time for a small % of owners to start reporting this failure. The summer is a good time to provoke failures, with the extra stress from ambient heat, running AC, etc. I used to own three Toyota hybrids (sold the 2001 4 months ago) and out of the three, two needed new traction batteries. The 2004 Prius still has the original traction battery. Last edited by Patrick Wong; 06-08-2008 at 01:02 AM. | |
Common things to check include: 1. tire pressure 2. oil level | |
:Mike Last edited by mikemartin9; 06-08-2008 at 05:03 PM. Reason: add info | |
Mike | |
Friends: 44 | Hi Mike, Thanks for providing more detail. Your road trip mpg sounds quite normal. I think that the Toyota hybrid system is stressed severely when it is necessary to regularly climb and descend hills. This may provoke a traction battery failure much sooner than flat terrain usage. (Certainly my personal experience will attest to this, as I live at 1,100 ft elevation and regularly commute to sealevel.) |
| Senior Member Join Date: Oct 2007 Location: San Diego, CA
My Car: 2008 Prius Model: Package: #2 Thanks: 120
Friends: 1 | It was a warm & humid day here the other day and the car was sitting in the sun all morning. Came out and went for a drive to the park. A/C was going full blast trying to get the temps down to 72*. Got stuck at a couple lights. Notice the battery down to the purple and the engine started up immediately when going for the green light. Seemed to be fairly normal to me? First 5 minutes indicated ~20 mpg which did not surprise me. Average for the tank is 47mpg right now. Had it a bit over 50 over 70 miles before a few short, hilly, hot trips like the trip to the park brought it down. If you frequently have shortish, hot trips which require extended time at full A/C to cool things off, I'd expect to see low 40s mileage. If you are doing city driving with full A/C, I'd expect to see the battery go into the purple fairly frequently, too. |
| 12V Aux Battery Drain - when off | boom27 | Gen II Prius Care, Maintenance and Troubleshooting | 1 | 02-25-2008 10:33 PM |
| Battery Drain | Prianista | Gen II Prius Technical Discussion | 2 | 10-09-2007 12:43 AM |
| Battery Drain | skijapan | Gen II Prius Technical Discussion | 1 | 08-03-2006 02:11 AM |
| HV Battery Drain | Tideland Prius | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 04-30-2005 09:46 PM |
| Will my battery drain? | dbascher | Gen II Prius Care, Maintenance and Troubleshooting | 17 | 11-11-2004 01:48 AM |
