| This is a discussion on ! & headlight level alert within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have a 2005 prius, pkg #6 w/ nav system. The not to be ignored red ! came on with ... |
#1 |
| Junior Member Join Date: Jun 2008 Location: Milwaukee, WI
Friends: 0 | I have a 2005 prius, pkg #6 w/ nav system. The not to be ignored red ! came on with the nav system showing the headlight level alert. A dealer visit was not productive as they could only reset the alert. It happened again today. We revisit the dealer tomorrow. They say Toyota has no info about it. The car works fine. Nothing I can trace sets the alert off. I feel I am not alone with this problem. Any help would be appreciated. Thanks |
Friends: 60 | |
| The Following User Says Thank You to Bill Merchant For This Useful Post: | kenmce (10-07-2009) |
Friends: 37 | Yup, Bill's nailed it. That sensor needs to be replaced...should be a warranty item for an '06. |
Friends: 0 | Thanks! I went to the dealer, showed him your input, they replaced the sensor. No problems after ~ 300mi.http://priuschat.com/forums/images/smilies/smile.gif It's nice having experts around......and I don't mean the dealer! |
Friends: 60 | I'm glad you got the problem fixed. It's amazing how we, focused on one car, can be so much more aware than some dealers with open access to all Toyota knowledge. |
My Car: 2006 Prius Model: Package: #6 Thanks: 18
Friends: 12 | it isn't rocket science to make a weatherproof enclosure. Grr. I can't believe this is still happening on the '06's! |
| Junior Member Join Date: Mar 2009 Location: Oregon
My Car: 2006 Prius Model: Package: #6 Thanks: 0
Friends: 0 | Do you know what the resistance reading on a working module should be? |
| High Voltage Member Join Date: May 2004 Location: terra
My Car: 2004 Prius Model: Package: #8 Thanks: 2
Friends: 0 | My impression is that six volts comes in on one side, an amount which is less than six volts comes out the other side without variation, and the signal coming out the center pin varies with the load in the back. I suspect that if the signal coming out the other side pin drops below a certain level the car assumes the sensor or a wire has failed in the open position, and if it goes up to a full six volts it assumes a short. Last edited by kenmce; 10-14-2009 at 06:21 PM. |
| alert, headlight, level |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/49339-headlight-level-alert.html | ||||
| maintenance: Blogs, Photos, Videos and more on Technorati | This thread | Refback | 06-20-2008 02:16 PM | |
| Headlight level sensor corroded? | timg | Gen II Prius Care, Maintenance and Troubleshooting | 19 | 08-13-2009 07:38 PM |
| Alert Light Help | Tancard | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 01-15-2008 11:02 AM |
| Smug Alert! | Skywalker | Environmental Discussion | 2 | 01-08-2008 07:45 PM |
