Taking a Stand on 2007 Prius AC Mold Problem!
| View Poll Results: I will call Toyota to Report this problem | |||
| Yes | | 6 | 19.35% |
| No | | 12 | 38.71% |
| Maybe | | 5 | 16.13% |
| Dont think it will help one damn bit | | 8 | 25.81% |
| Voters: 31. You may not vote on this poll | |||
| | #41 |
| Junior Member Join Date: Jun 2008 Location: Germantown, TN
Friends: 0 | I have a 2007 Mercedes E 320 CDI that has this same problem. |
| | #42 |
My Car: 2004 Prius Model: Package: B Thanks: 220
Friends: 16 | |
| | #43 | ||
Friends: 16 | Quote:
Why 1/2 you ask? Because that is a *very* common electrical knockout size. Knockout plugs are easily and cheaply available at jobbers and most big box stores When I inspected the e-coil with my fibre optic scope, there was no indication of actual dirt or mold buildup. That's common though, the stinky stuff is usually invisible to the naked eye I chose to use NuCalgon EvapFresh as I have seen this product used a lot in commercial, institutional, and industrial settings, and trust it Nu-Calgon Wholesaler Inc. : Products : Evap-Fresh Unlike other products that claim to offer disinfection, EvapFresh is EPA certified to do so. It also doesn't leave behind a perfumey or hospital ward smell I actually had to treat my Prius e-coil twice. The first time there was still a hint of the stench, so I zapped it again. That fixed it. I used a common garden poly sprayer, the kind with the pump in the handle and the wand. I only use it for servicing my e-coils in my two homes, it never has any other chemical in it Quote:
With a thermal expansion valve in the evaporator, the system is designed to run constantly at the lowest speed. This enhances moisture removal as the air spends more time at the e-coil. Our summers are brief but very muggy I have to clean the e-coils in my Bryant units at least once a year or the stench returns. Of course, depending on what sort of molds are in the environment, you can expect to frequently clean the coils So far my Prius has remained funk-free. However, the temps soared to +33 C over Canada Day here, and I noticed at the hobby farm my FJ is starting to stink. Not bad yet, but that familiar crotch odor is starting I'm not going to monkey around with the fibre optic scope this time. I'll try to drop the fan first, as it's easy to get to on the FJ. If I can't get to the e-coil from there, I'll go through the grommet at the firewall
__________________ 2007 Toyota FJ Cruiser 5AT "C", Sun Fusion | ||
| | #44 | |
If the mold is already in the local environment, replacing the entire case will buy some time. But once the mold establishes itself again? | |
| | #45 | |
FWIW here is the proper way to clean an e-coil, to wipe out the widest range of icky things: First, the coil must be squeaky clean. No sense spraying a disinfectant on the e-coil if it's filthy, as molds can easily survive then. It's best to clean twice, using an alkaline cleaner, rinsing, and then an acidic cleaner For example, NuCalgon CalBrite is an acidic cleaner but is relatively safe Nu-Calgon Wholesaler Inc. : Products : Cal-Brite NuCalgon Special HD CalClean is an alkaline cleaner that is quite safe when used according to directions Nu-Calgon Wholesaler Inc. : Products : CalClean, Special HD Once the e-coil has been rinsed and allowed to dry, use a combination light cleaner and disinfectant, like EvapFresh Nu-Calgon Wholesaler Inc. : Products : Evap-Fresh If the infestation is quite bad, you may have to follow up with a chlorine dioxide product, like BioFresh, which is also EPA certified for disinfection Nu-Calgon Wholesaler Inc. : Products : Bio-Fresh cd NuCalgon also recommends spraying a teflon product on the e-coil once it's dry. Their product is CalShield, it also works well on rads to make it easier to hose bugs off Nu-Calgon Wholesaler Inc. : Products : Cal-Shield It takes me about 1.5 hours to clean my house e-coil using the steps above. Of course, most of that time is waiting for the e-coil to dry. I only have to do this at the start of the A/C season BioFresh can also be fogged into ductwork to take care of anything growing in there. No sense in cleaning and disinfecting the e-coil if the ductwork is filthy, and you get the same mold back next week | |
| | #46 | |
Over Canada Day I noticed our first really nasty muggy day, +33 C, my FJ started to stink. Instead of monkeying around with the fibre optic scope and drill bits, I'm going to also go through the firewall port As a friendly reminder to anybody reading this thread, do NOT try household laundry bleach to disinfect your e-coil. Although the bleach will absolutely wipe out whatever is growing in your e-coil and case, you will probably ruin the e-coil. Sodium hypochlorite is corrosive to copper and aluminum, typical components of an e-coil: aluminum for the fins, copper for the tubing. The metals will suffer severe corrosion, which will then give off a weird metallic odor And never, EVER try to mix laundry bleach with ammonia, as you can form an explosive mixture. Never, ever, EVER mix bleach with acids like toilet bowl cleaner, hydrochloric acid, as you can expect copious amounts of chlorine gas. Any stunt like I have mentioned could very well kill you, or severely injure you, eg lung damage | |
| | #47 |
| Senior Member Join Date: Mar 2007 Location: Virginia Beach
My Car: 2007 Prius Model: Package: #5 Thanks: 0
Friends: 0 | Quote: thanks |
| | #48 |
| Senior Member Join Date: Mar 2007 Location: West Palm Beach, FLA
My Car: Model: Package: Thanks: 16
Friends: 11 | Although we have not seen any 04-05 Prius with smells... my 97 Tacoma does get an odor now and then... I believe that some of the time, the odor is simply from too much humidity.... Bear in mind, that is only SOME ofthe time. |
| | #49 |
My Car: 2007 Prius Model: Package: #2 Thanks: 81
Friends: 0 | Thanks again jayman! Well done! Having such good luck so far on the smell. The car smells really nice. And I do expect it to be an ongoing maint. issue. Probably monthly. Its just a little weird spraying liquid into the firewall and not really knowing where its going but i don't care. I'm desperate. I going to try the Walk the Walk route though since THEBear has given me alot of hope there might be something fixable here. Thanks again Mr Bear. Awaiting a call back from my dealer about this. They've been calling me weekly for the last 5 months asking me to come if for an oil change so they can over fill my oil...underinflate my tires and maybe throw in a free door ding.![]() Since I actually have an issue I'm sure I'll never hear from them again. |
| | #50 | |
| Senior Member Join Date: Jan 2006 Location: Bel Air, MD, USA -=- Blair, Merlin, Merka
My Car: 2006 Prius Model: Package: #6 Thanks: 0
Got home and called the corporate service number, and a kind person took down my info, the issue, the dealer's solution to the issue, and assigned a case number. The kind person also verified there were no open TSB for this issue. I agree with OP - call and let the system know there is a problem. In my case, the drain line was clogged. This is an item I will be sure to have the dealer re-check every oil change.
__________________ front dome LED x 3, door edge LED x 2, rear dome LED alloy wheel trim mod (free) rear wiper lift mod (free) | |
| 2007, air conditioner, mold, prius, problem |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/49705-taking-stand-2007-prius-ac-mold-problem.html | ||||
| 1 2's Public Library | Diigo | This thread | Refback | 06-02-2011 09:25 AM | |
| Jack Stand Placement | OrlandoGuy | Gen II Prius Care, Maintenance and Troubleshooting | 11 | 01-27-2010 10:38 AM |
| Attach laptop to Prius display or to mount laptop for stand-alone use | azz710 | Gen II Prius Modifications | 19 | 10-16-2008 07:05 PM |
| 2007 Prius, Bluetooth/Motorola L7 Sync Problem | alphlulu | Gen II Prius Care, Maintenance and Troubleshooting | 8 | 04-18-2008 04:50 PM |
| What do the letters NHW stand for? | Jerry W | Gen II Prius Main Forum | 15 | 02-12-2007 08:10 PM |
| A problem with my 2-day-old 2007! | peakfinder | Gen II Prius Main Forum | 8 | 10-06-2006 11:51 AM |
