| This is a discussion on Oil overfill within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Two weeks and 300 miles ago I got a new Prius (05, BC). Yesterday I checked the oil level, and ... |
Oil overfill
Friends: 0 | Two weeks and 300 miles ago I got a new Prius (05, BC). Yesterday I checked the oil level, and I found that it is overfilled by approx. 0.5in (1.27cm). Unfortunately, the dealer I bought the car from is a bit too far away (100 miles) to drive there and get the extra oil drained for free. This morning I went to the local Toyota dealer and I was told that the price for draining the extra oil will be only $0.75 cheaper compared to complete oil change ($32). This price seems a bit too high for just draining sth. like 0.4qt so I just made an appointment for tomorrow morning and left. I was wondering whether shall I: (a) Don't worry about the 0.5in overfill and keep driving the car. ( © Do something else. Yes, I know that draining the extra oil is very trivial for those of you who change the oil by yourself, but doing it by myself is an option I don't want to consider for now. I know it will take me lots of time to find the right place to do it, and then I will make lots of mess Unless you tell me that I can cleanly remove the extra oil from the top by using some tiny plastic tube... Thanks, PR P.S. Love the car! |
| Progressive Member Join Date: May 2004 Location: Southern California
My Car: 2005 Prius Model: Package: #6 Thanks: 3
Friends: 0 | Call the dealer where you purchased the car and speak to someone with authority. The selling dealer should pay the dealer nearer your home to perform the correction. |
Friends: 0 | Worry about it, overfill can cause frothing leading to decreased lubrication. Get them to fix the problem ( at no charge ) as it was their mistake In the future if you are having someone else changing the oil bring your own oil 3 to 3.5 quarts; that way they can't overfill it. This seems to be a perennial problem as there are numerous other older threads on PC about this. |
Friends: 1 | It is possible to drain it through the fill tube, but you would need the proper size hose and a pump of some sort. Inboard boat engines (at least sail boats) are generally drained the way since the drain plug is not accessable. |
Friends: 23 | How to reduce the oil level via the dip stick: 1) insert dip stick entirely into tube. 2) remove dip stick. 3) if oil too high, goto 4; else, goto 10. 4) wipe oil from dipstick. 5) goto 1. 10) end. |
Friends: 0 | Tony, With half an inch over the full line, the Priapus method PR is gonna take a lo...o...ong time. :P |
Friends: 1 | Tony does seem to have some ideas that are not as practical as one might like. ;-) |
Friends: 23 | Sorry y'all. I was just in a fiesty mood. :-D And now that I think of it, as the overall oil level drops, the amount of oil removed with each wipe diminishes. |
Friends: 0 | <div class='quotetop'>QUOTE(TonyPSchaefer\";p=\"50675)</div> Quote:
after I failed to find a tiny tube in the local auto-parts store. Until I made the back-on-the envelope calculation that I have to "pull" approx. half a quart/liter of oil. Well, in my algorhthm I didn't use "goto", but this didn't change the execution time Anyway, thanks for the suggestions. Tomorrow morning I am going change the oil with the local dealer to avoid developing any potential problems. PR | |
| Oil Overfill | tbstout2 | Gen II Prius Care, Maintenance and Troubleshooting | 9 | 10-23-2007 02:48 AM |
| Oil Overfill? | AOV | Gen II Prius Care, Maintenance and Troubleshooting | 13 | 09-06-2007 09:09 PM |
| Oil Overfill | Houston | Gen II Prius Technical Discussion | 5 | 12-14-2006 07:24 PM |
| Overfill - What did I do? | daronspicher | Gen II Prius Main Forum | 7 | 03-06-2006 01:47 AM |
| Oil overfill | Gurmail | Gen II Prius Care, Maintenance and Troubleshooting | 10 | 08-21-2004 03:14 PM |
:P
