This is a discussion on 2002: Where's the oil drain plug? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hello, I found the auto transmission drain plug I think. I got under the engine on the driver's side near ...
Old 07-02-2008, 08:47 PM   #1
zip2008
My Car: 2002 Prius
Question 2002: Where's the oil drain plug?
Hello,
I found the auto transmission drain plug I think. I got under the engine on the driver's side near the front of the car and found a plug fitting a 24 mm socket. Then, I cracked it and saw reddish fluid .... AT fluid I think.
So I looked around some and did not see an oil drain plug. Is it under a skid-plate? Where is it?
Where is the oil filter and how hard is it to get to?
Documentation has how to check the oil but not how to change it.
s,
mark
zip2008 is offline
Old 07-02-2008, 11:00 PM   #2
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 14
Default Re: 2002: Where's the oil drain plug?
Engine oil drain bolt is 12 mm and on the (US) passenger side of the vehicle. If you get your head under there and look straight up, you will see the oil filter can. It is vertically oriented with the treaded connection on top.
When you remove the oil filter there will be some dribbling. You can capture that using a soda bottle with its top cut off. Loosen the filter a bit (endcap wrench is good for that) and then continue unscrewing it with your catcher-bottle.
tochatihu is online now
2002:, drain, plug?, where's
Which Oil Drain Plug To Buy Smooth Operator Gen II Prius Care, Maintenance and Troubleshooting 15 08-21-2009 11:38 PM
Two Oil Drain Plug Gaskets Together Aaron Gen II Prius Care, Maintenance and Troubleshooting 6 05-26-2008 04:16 PM
Oil drain plug torque tfelder Gen II Prius Care, Maintenance and Troubleshooting 1 07-01-2006 03:48 PM
Magnetic Oil drain plug? silentak1 Gen II Prius Care, Maintenance and Troubleshooting 22 11-08-2005 12:42 AM
Oil Drain Plug Gasket berryman Gen II Prius Care, Maintenance and Troubleshooting 1 11-06-2004 06:26 PM
