This is a discussion on Gas tank took 11 gallons!!! Then puked it back out within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I never trust the automatic shut off enough to walk away. I stay with the car to monitor the fill....
LinkBack (1) Thread Tools
Old 07-03-2008, 05:08 PM   #11
Godiva
AmeriKan Citizen
Godiva's Avatar
Package: #1
Friends: 7
Default Re: Gas tank took 11 gallons!!! Then puked it back out
Godiva is offline
Old 07-03-2008, 10:26 PM   #12
brick
brick's Avatar
I find it irritating that a feature designed to improve air quality has, in many cases, resulted in a fuel spill that defeats its purpose many times over. Even if the pump should have cut off, fuel wouldn't dribble, stream, or gush out of the tank under pressure if not for the bladder. I really hope Toyota ditches it in the next model because it seems worse than useless.
Watching the pump would be a good call, though. I never leave mine partially because I've read so many stories just like this.
brick is offline
Old 07-04-2008, 12:14 PM   #13
rigormortis
Package: #5 Touring
ive posted before my opinions about the fuel bladder.
i want to go to a wrecker yard and get a real prius bladder to see how much liquid that bladder actually holds.
i believe when toyota says the fuel capacity is 11.9 gallons what they really mean
is 10.71 gallons at 90 % ullage and 1.19 gallons of vapor
its hard to imagine the prius holds 1.19 gallons of gasoline vapor "in the system" outside the bladder, and i dont think gasoline vapor really burns anyway it just goes
back to the gas stations tank to be picked up by the truck, hense "vapor recovery system"
run dry the most ive ever been able to put in the tank and not take a chance of overfilling or damaging the charcoal canister is coicidently 10.75 gallons
rigormortis is offline
Old 07-04-2008, 12:45 PM   #14
rigormortis
Package: #5 Touring
and also the prius manual says:
the given fuel tank capacity is measured on EPA/CARB orvr testing conditions which is approved for nominal capacity measurement condition
on page 9228 of http://www.epa.gov/otaq/url-fr/fr24fr98.pdf it says something about either 85% ullage or 95% ullage of the tank, and unless your in -10c or 14 degrees f) i think were risking a lot of damage to this car by following all that "stretching the bladder to restore capacity" advice.
Old 07-04-2008, 02:07 PM   #15
Originally Posted by F8L View Post
...I just put the pump at the middle setting and went to wash my windows and get a drink from inside the store...
This was a fault with the auto-shutoff on the pump, which is why it's illegal in most areas to walk away from the pump while refueling. It's not much fun, and shouldn't happen with good equipment, but ultimately you can only blame yourself for leaving the pump unattended.
Old 07-04-2008, 02:20 PM   #16
F8L
Collecting Data on Nature
F8L's Avatar
Friends: 35
I cannot argue that Tom. I am not placing ultimate blame on anyone but myself. Yes it would be nice for all of the associated systems to work correctly but the world is not perfect.
I do however wonder if I would have had a leakage problem even had I been attending the fuel pump like a good citizen. If the auto-shutoff did not activate and it kept pumping to say 10 gallons (which I doubt my car could have held at that given time) and I decided to stop pumping would the fuel tank have decided to "purge" the excess fuel out anyway? What I'm saying is, the fuel pump was not running when I walked back to the car, it had stopped at 11 gallons yet fuel continued to leak out of the filler neck for the next 15min or so.
F8L is online now
Old 07-04-2008, 03:03 PM   #17
brick
brick's Avatar
F8L- The exact situation you are describing happened to me, and a spill was averted. I'm used to getting maybe 9 gallons in when it's on the last pip and I decided at 10 gallons that the pump was misbehaving. I left the nozzle in for a few seconds for things to settle and carefully removed it.
brick is offline
Old 07-04-2008, 03:06 PM   #18
F8L
F8L's Avatar
Friends: 35
Good to hear you didn't have an issue. For the sake of future problems I will just stay with the pump and once if it hits 9.5ga (I've never put more than that in the tank that I recall) I'm callin it quits. lol
F8L is online now
Old 07-04-2008, 03:47 PM   #19
richard schumacher
Destination: Eschaton
Keeping your hand on the nozzle also removes the possibility of static discharge starting a fire.
richard schumacher is offline
back, gallons!!!, puked, tank
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/50329-gas-tank-took-11-gallons-then-puked-back-out.html
maintenance: Blogs, Photos, Videos and more on Technorati This thread Refback 07-04-2008 12:01 AM
How many gallons in a reserve tank when the last pip start blinking? angeliz421 Gen II Prius Fuel Economy 24 06-16-2008 06:45 PM
First Fill-up only took 6 gallons... stevendwatson Newbie Forum 8 05-28-2008 05:59 AM
Low fuel warning came on with 3 gallons still in the tank Soylent Gen II Prius Main Forum 29 09-13-2006 10:06 PM
Do I need to run out of gas again to see if the tank really holds 11.9 gallons? CarlsbadKiter Gen II Prius Main Forum 15 08-18-2006 12:03 PM
gallons to fill an empty tank kente777 Gen II Prius Main Forum 9 11-22-2005 06:44 PM
