| This is a discussion on 12,000 mile oil change interval success within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by PAPARYNO at 10K I have the "maint req'd " light now on. I checked my oil and ... |
| | #11 | |
| EPA MPG #'s killer Join Date: May 2007 Location: Elkhart, IN
Friends: 6 | Quote:
| | #12 |
| Taxi! Join Date: Jan 2006 Location: Burnaby B.C
My Car: 2004 Prius Model: Package: Base Thanks: 0
Friends: 0 | the maintainence light just comes on as a suggestion you can reset it anytime, its just a reminder light. so i just keep some of the oil and then send it to this company? or somewhere in canada i can drop off the oil, what do you guys usually catch the oil with? How much does it cost? I'd really love to see if my 195,000 km car has some bad wear with 0w20 oil |
| | #13 |
My Car: 2008 Prius Model: Package: #2 Thanks: 112
Friends: 0 | Changing Prius oil at 5,000 miles doesn't make much sense, especially with Mobil1. Afterall, the Prius engine is not running nearly as frequently as a normal vehicle. Since all my other vehicles were fine with 7500+ miles using Mobil1, it seems likely that the Prius would be good for at least 50% more than them. Hmmm...since I had the 1000 mile initial change done, I think I'll go ahead and wait for 7,500 (total) for the first normal change, and 7,500 throughout the powertrain warranty period assuming the oil looks good. When that expires I might try 10,000 miles. |
| | #14 | |
Friends: 12 | Quote:
Toromont CAT : Oil Analysis Services S·O·S However, the Toromont operating territory is Manitoba and Ontario. For BC, you would use Finning Finning (Canada) They have a sample pump for their sample bottles, and I highly recommend you invest the $20 in this pump. It is much easier to draw a sample through plastic tubing you can supply yourself, then to monkey with trying to catch a sample with oil draining out Toromont charges me $20 to perform an analysis. It appears the cost can vary from $20-$30, depending on what region you are in Hope this helps! jay
__________________ 2007 Toyota FJ Cruiser 5AT "C", Sun Fusion | |
| 12000 mile oic, success |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/50436-12-000-mile-oil-change-interval-success.html | ||||
| maintenance: Blogs, Photos, Videos and more on Technorati | This thread | Refback | 07-06-2008 07:02 PM | |
| Oil Change Interval | nitewolfgtr | Gen II Prius Technical Discussion | 14 | 10-12-2009 05:00 AM |
| Oil change interval with synthetic oil | DougSlug | Gen II Prius Care, Maintenance and Troubleshooting | 15 | 06-26-2008 08:18 PM |
| synthetic oil change interval | whodat | Gen II Prius Care, Maintenance and Troubleshooting | 17 | 06-11-2008 09:36 PM |
| Oil change interval | hkozinn | Gen II Prius Technical Discussion | 9 | 03-14-2008 01:04 PM |
| Oil Change Interval | john1701a | Gen II Prius Care, Maintenance and Troubleshooting | 22 | 10-28-2006 11:40 AM |
