| This is a discussion on CVT fuild change..... within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I changed the fluid yesterday, it was easier then I expected. Thanks to the suggestions on the use of vinyl ... |
| | #71 |
| Junior Member Join Date: May 2009 Location: CA
My Car: 2005 Prius Model: N/A Package: #3 Thanks: 2
Friends: 1 | I changed the fluid yesterday, it was easier then I expected. Thanks to the suggestions on the use of vinyl tube and funnel. I bought some 1/2" OD tubing from OSH and it worked perfectly. I made a mess at first by dumping the fluid too fast and did not insert the tubing far enough. In the end I put in 3 & 2/3 qts of ATF WS. My car has 117k miles and the old fluid was pretty dark so I suspect it has never been changed before. Next DIY will be coolant for engine and inverter. |
| The Following User Says Thank You to mec0t0 For This Useful Post: | ETP (07-20-2009) |
| | #72 |
Friends: 12 | There are two styles of 1 quart/litre bottles: those with a wide mouth and those with a narrow mouth. Most of the pumps I have seen fit the narrow mouth. However, the pump still works even if you can't screw it down on the bottle. Just be prepared for a bit of a mess. |
| The Following User Says Thank You to jayman For This Useful Post: | ETP (07-20-2009) |
| | #73 | |
| Member Join Date: Apr 2005 Location: Columbus, OH
My Car: 2005 Prius Model: N/A Package: #4 Thanks: 3
Friends: 0 | Did you put the car up on ramps to do the fluid drain, or is there some other method that is more effective? Quote:
| | #74 |
| Ancient and decrepit Join Date: Apr 2009 Location: Crestview/North Florida
My Car: 2009 Prius Model: N/A Package: #6 Touring Thanks: 160
Friends: 57 | My local independent shop said he would do it for $50 if I supplied the fluid.. |
| | #75 |
Friends: 1 | I did not put the car up on stands, I was able to reach in to get to the drain and fill ports. The reach is about the same as if you were doing an oil change oil change without raising the car. |
| | #76 |
Friends: 1 | |
| change....., fuild |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/50444-cvt-fuild-change.html | ||||
| maintenance: Blogs, Photos, Videos and more on Technorati | This thread | Refback | 07-06-2008 07:02 PM | |
| Would you change your pkg. | B Rad | Gen II Prius Main Forum | 25 | 05-30-2006 02:19 PM |
| Did my first ever self oil change... | lowspeed | Gen II Prius Main Forum | 20 | 03-31-2006 08:35 PM |
| Where do you Keep Change? | too tall | Gen II Prius Main Forum | 33 | 02-04-2006 01:20 AM |
| To make them change or not to change (the oil?) | micheal | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 08-07-2005 01:21 AM |
| how do I change oil HELP | timebum | Gen II Prius Care, Maintenance and Troubleshooting | 13 | 05-19-2005 10:50 PM |
