This is a discussion on 2004 prius trouble shutting down within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Dear members, Several months ago I had to replace the auxilliary battery because it drained out. Now when i turn ...
Old 07-07-2008, 04:46 PM   #1
solster
Default 2004 prius trouble shutting down
Dear members,
Now when i turn off the car it instead shuts down and starts again in the exclamation mode (warning light).
It stays idle and then I have to perform a second attempt ....The prius will then turn off.
Any assistance is appreciated.
Also I have noticed two codes show when I attached OBDII diagnostic scanner. I cant recall the codes currently...
solster is offline
Old 07-07-2008, 05:29 PM   #2
Bobwho
Bobwho's Avatar
Default Re: 2004 prius trouble shutting down
Please post the codes and then private message Galaxy to look at your post.
Bobwho is offline
Old 07-07-2008, 08:42 PM   #3
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
is the ground terminal connected properly? one reason a prius will restart itself is that the ground is loose.
galaxee is offline
Old 07-08-2008, 03:58 PM   #4
solster
Thanks for the advice.
I will look at ground connection and post codes tomorrow.
Solster
solster is offline
Old 07-11-2008, 08:05 PM   #5
solster
Ground connection was not the problem. It happened to be 099 code and the dealer fixed because under warranty.
099 code stipulates that the PCM which is computer system was not talking with something in the car.
That is, it need to be readjusted (put back in place) according to the mechanic at the toyota dealer. Cost zero because this under warranty.
Thanx...
Solster
solster is offline
off problem aux. battery
Gas pump keeps shutting off patrickmaher Gen II Prius Care, Maintenance and Troubleshooting 15 01-29-2009 04:00 PM
Consumer Reports trouble spots on a 2004 aggriffin3 Gen II Prius Main Forum 10 06-08-2007 12:39 PM
Shutting off the Prius mtsarpilot Gen II Prius Main Forum 22 08-18-2006 11:25 PM
Shutting Down in Neutral Alnilam Gen II Prius Main Forum 1 07-01-2006 06:08 AM
ICE has started shutting down at low temps storm petrol Gen II Prius Main Forum 6 03-03-2006 07:17 AM
