This is a discussion on Non-factory window causing bunching-up of rubber within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Anyone ever have a problem with a replacement window for one of the front doors? I got broken into a ...
Old 07-08-2008, 08:26 PM   #1
apostasy10
Default Non-factory window causing bunching-up of rubber
Anyone ever have a problem with a replacement window for one of the front doors? I got broken into a few weeks ago and a local shop replaced my window with a non-factory window (that is, it doesn't say Toyota in the corner like the one on the other side), and I've notice ever since the rubber along the front edge of the window bunching up ever time I roll the window up. I end up going up and down a few times so that it straightens itself out. I'm going to see the guy again on Thursday to see if he can do anything for me. If that doesn't work, does anyone have any suggestions? Should I try to get a Toyota window put in there instead?
apostasy10 is offline
Old 07-09-2008, 01:57 PM   #2
fnc
Metro owner
Default Re: Non-factory window causing bunching-up of rubber
The brand of glass should not matter. However the installation does. Sounds to me like the window regulator is misaligned. Return to who did the work and have them realign it. Or take it somewhere else and send them the bill.
fnc is offline
Old 07-10-2008, 11:34 AM   #3
turnbowm
I always make sure that the shop uses OEM glass. Have had several bad experiences where that was not the case. The quality of the repair work can also be an issue.....
turnbowm is offline
Old 08-11-2008, 07:16 PM   #4
apostasy10
Ended up trying 2 other non-Toyota windows and neither ended up working. The 4th window was an official Toyota replacement and works perfectly. (Thanks to A OK in Phili for not charging me the $20 for the extra cost.)
Old 08-14-2008, 09:41 PM   #5
shimadog
I got a bum piece of aftermarket rear door replacement glass. The new OEM Toyota piece, while not perfect, is a lot better.
shimadog is offline
bunching-up, causing, non-factory, rubber, window
Non-factory navigation system on factory screen drewllbrb Gen II Prius Audio and Electronics 5 08-11-2007 10:50 PM
Info Request: factory vs post-factory nav geologyrox Gen II Prius Audio and Electronics 9 11-03-2005 06:06 PM
?highlight= causing problems mspencer PriusChat Website Questions 21 04-05-2005 02:57 AM
If water is causing so many problems..... macreative Gen II Prius Main Forum 21 09-28-2004 10:43 PM
Report: buying rubber floor mats/ Seeking rubber cargo mat MadDebSalsa Gen II Prius Modifications 5 02-12-2004 10:16 PM
