This is a discussion on Headlight glass changing within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I bought a used Prius and headlights doesn't seem as bright as a new ones. It looks like it has ...
Old 07-09-2008, 06:34 AM   #1
pvdo
Post Headlight glass changing
I bought a used Prius and headlights doesn't seem as bright as a new ones. It looks like it has a soft mist on the glass and my question would be, is there a possibility to change headlight glass only? What would be your advice how to make the glass look brighter?
Thanks,
pvdo is offline
Old 07-09-2008, 08:05 AM   #2
Huntceet
Default Re: Headlight glass changing
The plastic lenses can be polished to remove the fine scratches. There are a number of products that will work. Do a Google search for "Headlight Restoration".
Rod
Huntceet is offline
Old 07-09-2008, 01:59 PM   #3
fnc
Metro owner
Plastic polish and a random orbit buffer will do the trick.
fnc is offline
Old 07-09-2008, 03:38 PM   #4
KayakerNC
KayakerNC's Avatar
Thanks,
Maybe the previous owner slapped on some of that "clear" protective film.
KayakerNC is offline
Old 07-10-2008, 01:11 AM   #5
pvdo
No, there are no protective film. I'll try a plastic polishing. Thanks, guys.
pvdo is offline
Old 07-10-2008, 01:50 AM   #6
Rest
Actually the plastic lens does have a UV protective film. Eventually it will peel and then the plastic will yellow and turn brittle. If you polish the plastic that will also remove the UV protection.
Rest is offline
Old 07-10-2008, 02:28 AM   #7
priusenvy
priusenvy's Avatar
You can shoot the lenses with a layer of clearcoat to give them back UV protection.
Also, unless you're really patient, an orbital buffer is way too slow. A rotary, or even a cordless drill, with a 4" pad mounted is way faster.
priusenvy is offline
changing, glass, headlight
Privacy Glass? Grocked Gen II Prius Main Forum 3 04-26-2008 04:28 PM
Changing "auto" headlight sensor sensitivity rodney1 Gen II Prius Main Forum 5 05-23-2006 11:27 PM
Glass treatment? ScottY Gen II Prius Care, Maintenance and Troubleshooting 21 04-14-2006 02:52 PM
privatcy glass for 06? asaca Gen II Prius Main Forum 1 03-20-2006 03:22 AM
XM under glass? naterprius Gen II Prius Audio and Electronics 4 10-04-2004 05:24 PM
