This is a discussion on Max it out? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have noticed that my front tires are different from the back . I am a member of the 44/42 ...
Max it out?
Old 07-10-2008, 12:05 PM   #1
perryma
perryma's Avatar
Default Max it out?
I have noticed that my front tires are different from the back . I am a member of the 44/42 club but have realized my front tires have a max of 55. The rear is ...45? Something like that. Anyway, should I bump up the pressure on the front or will this mess things up?
perryma is offline
Old 07-10-2008, 12:17 PM   #2
Friends: 37
Default Re: Max it out?
stick with the 2psi pressure difference. try 50 fr 48r.
efusco is offline
Old 07-10-2008, 12:20 PM   #3
I like to use 2 front, 0 rear psi, which still maintains the required two psi delta. I find it gives a softer ride.
Old 07-10-2008, 12:26 PM   #4
GatorJZ
My Car: Other Hybrid
2 PSI differentail, but do NOT exceed the manufacturer's maximum PSI rating as indicated on the side of the tire.
GatorJZ is offline
Old 07-10-2008, 12:52 PM   #5
TonyPSchaefer
Your Friendly Moderator
TonyPSchaefer's Avatar
Friends: 23
How does that work for your mileage?
I was thinking of running 0 front and 1 rear since the adding the fronts and adding the rears would be a 2psi difference.
TonyPSchaefer is offline
Old 07-10-2008, 01:34 PM   #6
rigormortis
Package: #5 Touring
i tried that max pressure thing on my touring for one day, was impressed with the less rolling resistance, took one look at the tires, laughed, worried about my new tire warranty and changed it back to what it says on the door jam
ill try it again when i can get cheap tires in the 195 55 16 size
rigormortis is offline
Old 07-10-2008, 03:38 PM   #7
I don't know yet. The tires keep falling off of the back rims. Do you think I need better tires?
Old 07-10-2008, 04:03 PM   #8
richard schumacher
Destination: Eschaton
I don't understand: what did you see that made you laugh?
richard schumacher is offline
Old 07-10-2008, 04:30 PM   #9
priusenvy
priusenvy's Avatar
I took this a step further and tried 0 front, -2 rear, but the ride suffered, as atmospheric pressure crushed the rear tire carcasses.
priusenvy is offline
Old 07-10-2008, 05:23 PM   #10
hiremichaelreid
Wrnchs OScopes Computers oh my
hiremichaelreid's Avatar
Package: Pioneer #3
No, just use some super-glue...
I've been running my Touring at 50/48 for 4 weeks. It was a bit unstable in wind on my last long trip, and I'm concerned my traction is lower, so I'm going to try 40/38 for a while.
So far, I think I'm getting a 5-10% MPG hit. But if the car handles better and stops quicker and is less susceptible to wind, I don't care about the MPG hit; it's only $60-120 a year; One prevented accident every 5-10 years will more than pay for the gas IMO.
2008 "Canadian base" (Touring pkg 2++): PSI: 50/48. Best 40 mile RT commute max 31-44 MPH: 60 US MPG. (37-50 MPH: 54 MPG)
Why: (1) thrift, (2) Priups/PHEV hackable, (3) ecology.
Week 5: 1250 miles, 3MClearbra, oil lower, 50/48 PSI, Trim ring remov, ScotchGard, UOA.
hiremichaelreid is offline
out?
