| This is a discussion on Clock & MPG Screen Random Reset? Gas Gauge? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Our '08 is randomly resetting the clock and mpg computer plus the gas gauge reading goes from nearly full to ... |
| Junior Member Join Date: Apr 2008 Location: NY
Friends: 0 | Our '08 is randomly resetting the clock and mpg computer plus the gas gauge reading goes from nearly full to almost empty and starts flashing (there is gas in the tank). Also, a couple of times the car's power button did not work. The car's power came back on after the power button was pushed to turn it off, or pushing the power button would not turn the power on. These all happen at the same time, when the car is started. (Except for the times the power came back on by itself after pushing the power button off). It has been in for service to take look at the problem twice in the last month. So far they have checked - 12 volt battery connections and fuse box connections. The car is running fine - mileage is about 50 mpg - no indicator lights have come on and the service department has not reported any trouble code readings. Anyone else have this problem? Or suggestions on what might be the cause? |
Friends: 1 | have them physically remove the battery from the car and do a load test on it to rule it out. i dunno about the gas gauge the general rule of thumb is toyota dealers do not like physically testing the 12 v battery |
Friends: 1 | http://www.autoshop101.com/forms/Hybrid13.pdf that says the dealer can recalibrate the gauge if you have problems with it |
| Junior Member Join Date: Feb 2008 Location: South Carolina
Friends: 0 | My '08 just did almost the same thing. This morning, the mileage-per-tank counter reset in the middle of a tank, and this afternoon, the gas gauge dropped from 3 pips missing to empty (fill tank indicator came on.) I filled up right away and only had to put in 3.5 gallons. I hope this is not a symptom of problems! |
Friends: 44 | My guess is that your 12V auxiliary battery is bad. If you have access to a digital voltmeter, perhaps you could measure the battery voltage when the car is IG-OFF and when it is READY. You can do this either by measuring the voltage from the dedicated jump start terminal in the large relay/fuse box near the driver's side fender to a bare metal point on the body; or else finding the battery in the right-rear corner of the hatch and measuring the voltage at the battery terminals. When IG-OFF, the voltage should read ~12.6V several hours after the car was last driven. If the voltage is much lower than this, this is evidence that the battery needs to be charged or is bad. When READY, the voltage should read ~13.8V which shows that the DC to DC converter is working properly.
__________________ 2006 Highlander Hybrid 4WD-i 2004 Prius 2001 Prius (sold Feb. 2008, 75K miles) 2000 Ford Mustang GT conv. |
Friends: 0 | Update on problem - First Dealer visit - they traced the problem to the fuse block and "fixed" the connection. Second Dealer visit - this was a problem that took a few days to solve. Because they had just worked on the fuse block they looked at other areas. Everything seemed OK, but the resets kept happening. It appears that there was a bent/loose pin in the connector at the fuse block that would open when the car was "cold" from sitting - but would close after the engine compartment warmed up from running the engine or sitting in the sun. So far (less than a week) it appears to have been fixed. All three (clock, mpg screen, and gas gauge) resets seem to be related to power interruptions from the loose connection. |
| Junior Member Join Date: Jan 2008 Location: Nashville
My Car: Model: Package: N/A Thanks: 0
I've checked the voltage on the 12volt using the onscreen display check and i'm at 14v in ready mode. So, i'm ruling out that its my battery. | |
Friends: 2 | Quote:
I've been looking for the directions to get the 12V battery voltage up on the MFD without success. Could you post how to do this or provide a pointer to where it is? | |
My Car: 2004 Prius Model: Package: Base Thanks: 0
Friends: 10 | Quote:
Now press the POWER button to put a larger current load on the battery. The voltage should drop a little, but stay above 12v. Now hold the BRAKE down and then press the POWER button to go into READY mode. The voltage should jump to just below 14 volts as the charging system turns on. Powering down your Prius puts everything back into its normal operation. JeffD | |
| clock, random, reset |
| Odd digital fuel gauge performance - reset? | quixotequest | Gen II Prius Fuel Economy | 4 | 01-18-2008 03:33 PM |
| Fuel gauge reset to full with 376 miles on resettable odometer | koa | Gen II Prius Main Forum | 16 | 04-24-2006 09:05 PM |
| Consumption Screen Random Resets | Prianista | Gen II Prius Care, Maintenance and Troubleshooting | 16 | 03-23-2006 12:50 PM |
| [KB] How to Reset Gas Gauge | Bill Merchant | Knowledge Base Articles Discussion | 18 | 08-14-2005 08:59 PM |
| Fuel Tank Gauge Didn't Reset | jchu | Gen II Prius Care, Maintenance and Troubleshooting | 10 | 12-29-2004 03:04 PM |
