This is a discussion on 2008 MPG monitor resets itself within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; The MPG Monitor on my new 2008 reset itself after I filled the tank. Is this normal and can it ...
Old 07-13-2008, 05:25 PM   #1
08 mag grey
08 mag grey's Avatar
Default 2008 MPG monitor resets itself
Is this normal and can it be set not to reset after every fill.
I did a search and someone said that after 2004 Toyota changed it some it wouldn'r reset itself.
I would prefer to do it myself.
08 mag grey is offline
Old 07-14-2008, 12:10 AM   #2
Jiipa
MGySgt USMC (Ret)
Jiipa's Avatar
Default Re: 2008 MPG monitor resets itself
The miles reset after a fill-up, but the mpg average does not unless you manually reset it on the touch screen. I do not think there is a way to prevent the miles from resetting, but I'm sure someone will show us both how if I'm wrong.
Jiipa is offline
Old 07-14-2008, 12:20 AM   #3
morpheusx
Professor Chaos
morpheusx's Avatar
the only way to get around it as far as I know is to only add a small amount of fuel such as less than $10.
morpheusx is offline
Old 07-14-2008, 01:48 AM   #4
Bill Merchant
absit invidia
Bill Merchant's Avatar
Friends: 60
Cool Re: 2008 MPG monitor resets itself
Use one of your two trip meters. You can't change the MFD display except to reset all to zero.
Bill Merchant is offline
Old 07-14-2008, 11:51 PM   #5
badrufus
I think mine did the same thing that 08 mag grey is talking about. I filled up for the first time on Saturday and noticed later that the miles on the MFD had reset. I had intentionally not pressed reset because I wanted to have the MFD provide a cumulative, from mile 0, record of mpg. I couldn't find anything about this in the Owner's Manual. Are you saying that the mpg reading on the MFD is still cumulative, ie that it does not reset at refueling (unless you actually press "reset")?
badrufus is offline
Old 07-15-2008, 12:07 AM   #6
PriuStorm
Friends: 8
My 2007 resets the miles (distance) upon fill-up but continues the mpg as cumulative unless I press 'reset'. I wish I had known that from the beginning so it would be the cumulative since Day 1, but alas, I didn't figure that out until a few months ago. Still, now that I know 'how' to drive more fuel efficient, it's easier to keep the mpg average up.
PriuStorm is offline
Old 07-15-2008, 03:56 PM   #7
08 mag grey
Thanks.....
I just filled up and the mileage did reset but not the MPG.
Now I know..
Old 07-17-2008, 01:14 PM   #8
bruceha_2000
bruceha_2000's Avatar
Package: #8
Thanks.....
If it is true that the MPG doesn't reset, I can't say I think it is an improvement. The Consumption Screen MPG should reflect the current tank (as was true apparently until the 2008 MY). It is the best way to calculate how much gas you need to fill the tank rather than trusting the pump shut off will not stop early or fail to stop and over fill.
What they NEED is a 'Lifetime MPG' value stored somewhere that you can get to when you want.
bruceha_2000 is offline
2008, monitor, sesets
Energy monitor kayemarschke2 Gen II Prius Main Forum 5 07-23-2008 09:23 PM
MPG Monitor Richard K Gen II Prius Care, Maintenance and Troubleshooting 2 06-30-2008 08:33 PM
G1 Energy monitor Synergy Generation 1 Prius Discussion 1 05-31-2008 11:46 PM
CAN Monitor Syclone Gen II Prius Care, Maintenance and Troubleshooting 1 10-14-2006 05:02 PM
Monitor Headrests simple_in_seattle Gen II Prius Audio and Electronics 1 10-23-2005 02:05 AM
