This is a discussion on 2006 back-up died / then the MFD within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; About a year ago, the back-up camera on my 2006 starts fritzing. First, every so often, the image would jiggle ...
LinkBack (1) Thread Tools
Old 07-15-2008, 04:56 PM   1 links from elsewhere to this Post. Click to view. #1
brayder
brayder's Avatar
Default 2006 back-up died / then the MFD
About a year ago, the back-up camera on my 2006 starts fritzing. First, every so often, the image would jiggle side to side. That happened occasionally for months. Then, every so often, it would just be static, no image. This became more frequent over the course of a couple months and then every so often it would just be black. This became more frequent to the point that every time I backed up, it was a crap shoot: normal, jiggle, static, or black? Finally, it went black all the time. Once every few months, it will come on as normal. The next time, back to black. I've got 53k miles on it so by the time I took it in, it was past warranty and the dealer wanted $600 to replace it despite the fact that I told him it must be wiring.
So I just got used to not having a backup camera.
Now, the MFD has done the same thing at a much faster pace. It went blank a couple times when I turned on the air, then came back on the next time I started the car. Then it was 50/50 that when I started the car it would come on at all. Then it went permanently blank. The radio/CD still works. The bluetooth still connects to my phone, but I can't talk/hear through the speakerphone. The air/temp buttons on the steering wheel still work.
I know there are a lot of threads about this, but most of them are the '04 MFD Service Bulletin type. I can't find anything like this.
Does anyone have any advice?
Thanks
one love
2006 Prius Black Package #6
brayder is offline
Old 02-02-2009, 05:02 PM   #2
carpedm
Package: #8
Default Re: 2006 back-up died / then the MFD
Thanks
Have you found a way to get yours fixed?
I have '06 Prius and over the weekend MFD failed.
Nothing on the screen works. It is simply dead with dark black screen that does not respond at all. Mine just passed the 36k warranty mark, so I don't know what to do... I certainly hope that I don't have to shell out 4K to get it fixed.
Please let me know how you were able to take care of your MFD issue!!
Thanks!!
carpedm is offline
Old 02-02-2009, 07:07 PM   #3
hobbit
hobbit's Avatar
Sounds almost like a loose connection in the back. If you're
handyish, you might be able to refer to Chris's instructions
and pull the MFD for looksee-and-connector-wiggle to see if you
can localize it.
_H*
hobbit is online now
Old 02-03-2009, 06:20 PM   #4
carpedm
Package: #8
can localize it.
_H*
Thanks for the tips!
BTW, not too long ago, I had the dealership to replace my speaker sitting right on top the MFD. Do you think there is a chance that they some how touch the connector while performing the replacement?
Hmm.. I looked at the instruction to take the dashboard out, but it seems like a like of work just get to the back of the MFD.. Aaaarrrrrgggg!!
Thanks for your support.
It seems MFD issues are more common for '04 models than '06 models, right??
carpedm is offline
2006, back-up, died
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/50950-2006-back-up-died-then-mfd.html
2006 back-up died / then the MFD - Latest Toyota Prius News - Toyota Prius: Blogs and News - Newsbeet This thread Refback 02-02-2009 03:59 PM
My car died pnsji Gen II Prius Technical Discussion 16 06-10-2007 09:24 AM
My 10 month old 2006 red Prius died yesterday. ilovemyprius Gen II Prius Main Forum 19 10-14-2006 06:44 PM
Back Up Camera when not in reverse on 2006 bbgun Gen II Prius Audio and Electronics 1 04-26-2006 11:40 PM
Back-to-back drives of a 2004 and a 2005 dpool Gen II Prius Main Forum 12 04-28-2005 09:31 PM
Back-to-Back Hybrid Test Drives Tideland Prius Other Cars 8 04-26-2005 02:15 PM
