This is a discussion on Aged Tires: a Driving Hazard? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by zenMachine What consumers need is a way to test or measure these 'aged' tires for their roadworthiness. ...
Old 07-17-2008, 04:41 PM   #21
dwreed3rd
Package: #3 Touring
Default Re: Aged Tires: a Driving Hazard?
It would be great if they had something like that. If you have a service mechanic that you trust, one that won't be influence by wanting to sell you new tires, He/she should be able to inspect the tire(s) if you're not comfortable doing it yourself. The best way is to pull it off of the rim to inspect it. However, you can get a pretty good idea without pulling it off of the rim. Let the air out of the tire by unscrewing the plunger inside of the valve, so that you can flex the side walls. If the side walls have dried out, they will be stiffer then a newer tire and hard to flex. Flexing the tire should emphasize any signs of cracking in the sidewall. If you are not familiar with how a good tire flexes and what it feels like, then you need to take it to someone who can tell. I would think that if you can flex the sidewall and it flexes back into shade easily and no fine signs cracking can be seen in the sidewalls, the rubber should still be lively enough for a few K more of driving. Again, this is a personal decision and I would never encourage anyone to drive on tires that weren't absolutely sure of. There are some things in life that aren't worth taking chances with, and I consider tires to be in that category.
Dave & Joan, wishing all "Happy Motoring"
2008 Prius Touring CVT on-order, Seaside Pearl, Dark Grey Leather, Pkg#3
2000 Toyota Avalon XLS, Silver Spruce, 111K+, Extremely satisfied original owners.
dwreed3rd is offline
Old 07-17-2008, 04:44 PM   #22
pdhenry
It's HEEERE!
pdhenry's Avatar
There is a note in the Prius manual that says something to the effect that the Prius tires need to be inspected by a "quaified professional" (or words to that effect) after 5 years of use.
pdhenry is offline
aged, driving, hazard?, tires:
Defective valve stem hazard hobbit Gen II Prius Technical Discussion 16 08-26-2008 07:30 PM
Hybrids a hazard to the blind? orracle Prius and Hybrid News 65 04-04-2008 02:33 AM
Smart Key - Health Hazard?? esetter Gen II Prius Main Forum 43 08-11-2007 09:47 PM
Tires for Gravel Driving? PriusPhotog Gen II Prius Modifications 2 11-09-2006 11:20 AM
Good experience with road hazard warranty onerpm Gen II Prius Main Forum 0 03-18-2006 06:24 PM
