| This is a discussion on Pulls Left: Dealer Says Tire is to Blame; not an Alignment Problem within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi, Godiva, It does download when I click on the link, but when I open it I get a "PDF"-type ... |
| | #11 |
| Senior Member Join Date: Oct 2007 Location: Bolton,CT
Friends: 1 | Hi, Godiva, It does download when I click on the link, but when I open it I get a "PDF"-type box (like I usually do) that says Adobe reader (in the top border) but with a big white box in the middle of it that has an error message in it that says "file can't be found". Have you tried to click on his PDF attachment, & if you did, could you see the contents of the TSB? Ken (in Bolton,Ct) |
| | #12 | |
Friends: 1 | Quote:
HOWEVER, Do not have the Integrity tires on 2 or 3 'corners' and something else on the others. If not exactly the same tire, they must match pretty close and anything you would WANT to buy won't be the 'same' as the Integrity. If they are willing to replace one or 2 Integrity tires (I'm SURE they won't do all of them UNLESS they can all be shown to be bad), you might want to drive them to 'end of life' before shelling out for new tires all around.
__________________ Bruce Mine: Driftwood '04 BC 24 Sept 2004 - added: mudflaps, door edge guards, side panel moldings, Coastal Tech EV switch, OEM Integrity tires, WeatherTech window deflectors. Last tank - 14 Jul '09: 728.9 miles - MFD MPG: 56.0 Actuals Lifetime: 93,087.3 miles, 48.90 MPG. Wife's: Barcelona '06 #7 May 2006 - added: front mudflaps, Coastal Tech EV switch. OEM Integrity tires. Last tank - 21 May '09: 419.4 miles - MFD MPG: 46.7 Actuals Lifetime: 31571.4 miles, 44.82 MPG. | |
| | #13 | |
| Canonus Curiosus Join Date: Aug 2007 Location: Chicagoland (West)
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 150
Friends: 18 | Quote:
This doesn't really sound like much of a help to me -- except that it should remove the left pull, of course! | |
| | #14 |
Friends: 18 | |
| | #15 | |
Friends: 6 | Quote:
Ideally, the two tires on the same axle should have relatively equal tread depth. (Do you know the depth on yours?) Of course, a new tire matched with one nearly new should be fine. A new tire paired with one with barely legal tread depth could create handling or braking problems. You're probably somewhere in between. Here's another idea: Replace the other one on your nickel and use the old one as another spare. Story: The donut spare and an unrepairable road hazard last summer forced me to buy tires before I was ready. The Integritys had 27K on them, still legal, but I was planning to replace them before winter. When I awoke one Saturday morning to a flat, I had to scramble to find a complete set of tires that day. Replacing only one was not an option due to the tread wear. Michelin Hydroedges were among the tire models I was considering, though they probably wouldn't have been my first choice. But they were the only ones I could get that day. The others would have taken a week or two for dealers to order, and I couldn't be running on the donut that long. If I had had a full size spare I could have taken my time. So when I replaced them I kept one of the old ones for this purpose. My plan was to buy a used steel wheel (I think a Corolla wheel fits), have the tire mounted on that, and keep it in my storage shed. If I have a flat around town I can slap the donut spare on long enough to get home. (Won't help on extended road trips, but they are pretty infrequent.) Then I can run with the full-sized spare for weeks if I have to, and I'm not forced into immediate action; I can get repairs or replacements on my terms. (I confess that I have procrastinated badly on this -- the tire still sits in storage without a wheel. Does me a lot of good, huh?) | |
| | #16 | ||
__________________ Previous Prius: 2007 Silver Pine Mica Pkg #6. 29,492 miles. Lifetime: 52.2 MPG; Last Rolling 12 Months: 53.4 MPG Current Car: 2010 Blue Ribbon Metallic Prius V w/ AT Pkg. (from 5/25/09) Lifetime City Mileage: . . . . . . . 57.7 MPG Lifetime Highway Mileage: . . .56.8 MPG Lifetime Combined Mileage:. .57.1 MPG @ 8,242 miles Best Trip Odo: (778.7 mi at 20 mph): 60.6 MPG & (390.0mi at 47 mph): 64.5 MPG | ||
| | #17 | |
My Car: 2007 Prius Model: Package: #6 Thanks: 288
Friends: 11 | Quote:
Were you able to figure this out? I would have responded earlier, but I'm in a primitive land where WiFi is very hard to find. I think its called Oregon by the natives. I placed a copy of the TSB here: .Mac - iDisk Click the arrow on the right side to download the TSB | |
| | #18 | |
Friends: 6 | Quote:
Here is an excerpt from an article from TireRack.com that discusses mixing tires: The best choice is to select the exact tire currently on the vehicle. This assures that the tire's physical dimensions, internal construction, tread design and tread compound are equal to the tires being replaced.Either way, not an optimal solution. Having said that, I would be comfortable exercising the second option for myself. | |
| | #19 | |
No problems with different brands as long as they are the same size and matched in pairs on front or rear axle. | |
| alignment, left, pulls, tire |
| Tutorial: Rear tire alignment | bwilson4web | Knowledge Base Articles Discussion | 26 | 09-11-2009 07:21 PM |
| Alignment at Toyota or Independent Tire Shop ??? | dorf | Gen II Prius Care, Maintenance and Troubleshooting | 3 | 04-28-2008 07:16 AM |
| 08 Prius: Pulls to the left when braking. | Joe 26 | Gen II Prius Main Forum | 7 | 03-15-2008 01:23 PM |
| 2006 PULLS TO THE LEFT ON BRAKE | icemanjrperu | Gen II Prius Main Forum | 39 | 03-12-2008 03:10 PM |
