| This is a discussion on Change your own oil! within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by doubleg2005 how synthetic lasts longer than dino or blend, isn't contributing to the middle east... It actually ... |
| | #21 |
| Grumpy, Cranky Senior Member Join Date: Jun 2007 Location: Fullerton CA
Friends: 4 | It actually is. They make synthetic oil out of petroleum derived chemicals, and they get the petroleum to make those chemicals on the open market (read: Middle East). Last edited by kohnen; 07-28-2008 at 02:10 PM. Reason: typo |
| | #22 |
| Junior Member Join Date: Jun 2005
Friends: 0 | does anyone use those quick lube or oil can henry's to change oil? I hate going to the Toyota dealer. |
| | #23 |
| Senior Member Join Date: Aug 2005 Location: CA
My Car: 2007 Prius Model: Package: N/A Thanks: 0
Friends: 0 | |
| | #24 |
My Car: 2008 Prius Model: Package: #2 Thanks: 112
Friends: 0 | John's oil change guide is well done, but is missing one important thing: torque wrench for the oil drain plug and proper setting. (I haven't found the setting in my manual but they typically run about 25 ft-lbs in my other vehicles' drain plugs. I'll need to find the actual value.) |
| | #25 | |
| Member Join Date: Apr 2008 Location: Los Angeles, CA
Friends: 0 | I found this other product which seems to be a much better alternative. Has anyone tried it? Welcome to LiquidVac.com - Oil changing vacuum system Oil Change Pump DIY Quote:
| | #26 |
Friends: 44 | 28 ft.-lb. However, I've noticed when removing the oil drain plug (after 5K miles have elapsed) that not much effort is required to unbolt the plug (apparently less than 28 ft.-lb). I assume this is because the fiber gasket has collapsed a bit while in service. |
| | #27 |
| Senior Member Join Date: Dec 2007 Location: Stewartstown, PA.
My Car: 2008 Prius Model: Package: #4 Thanks: 0
Friends: 0 | I never used a torque wrench to tighten an oil drain plug. Simply tighten snugly and that's it. (never use a lot of muscle) |
| | #28 |
Friends: 0 | The problem is that there is a lot of variation in what "tighten snugly" means. For some it means stripping the threads apparently. For others it is not much more than hand tight. Using the torque setting you can be certain you are getting compression of the gasket without making it too hard to remove or stripping the threads. It's a pain when somebody strips the threads, because it leaks oil until you put a new plug in on the next oil change. |
| change, oil! |
| First oil change | mkbender | Gen II Prius Care, Maintenance and Troubleshooting | 8 | 09-16-2007 06:17 AM |
| how much is an oil change (5k, 10k, 15k?) | dyyuan | Gen II Prius Main Forum | 24 | 12-06-2005 10:34 PM |
| To make them change or not to change (the oil?) | micheal | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 08-07-2005 01:21 AM |
| First oil change | Jared | Gen II Prius Care, Maintenance and Troubleshooting | 18 | 06-20-2005 08:49 PM |
| First Oil Change | PriusPhotog | Gen II Prius Main Forum | 8 | 06-04-2005 01:53 AM |
