This is a discussion on Dealer's tire inflation rate within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I just got my 20,000 mile oil change and was hit with the news that I need new tires. The ...
Old 07-23-2008, 02:34 AM   #11
cmeteach
Default Re: Dealer's tire inflation rate
I just got my 20,000 mile oil change and was hit with the news that I need new tires. The sides of my tires are totally worn and I am totally befuddled! The dealer told me to inflate no higher than 35psi, but I decided to stick with somewhere between 35-40 since the tires where rated higher and I was concerned about the wear on my tires. Yet here I am trying to understand how tires that are rated at 50,000 miles are totally worn at 20,000. I have had the car since May '07 and although I admit 20,000 miles in a little over a year is a bit much, but wheels are wheels right? ugh...I really don't feel like forking over $$$ for tires right now, but I have no choice. Are the goodyear tires the best or are there others???
cmeteach is offline
Old 07-23-2008, 10:55 AM   #12
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
Originally Posted by cmeteach View Post
I just got my 20,000 mile oil change and was hit with the news that I need new tires. The sides of my tires are totally worn and I am totally befuddled! ... Are the goodyear tires the best or are there others???
The Goodyear Integrity tires are not good for much except they allow pretty good mpg even when new.
If you are a Costco customer, that chain carries Michelin-X in the Prius size. That tire model should offer exceptionally long tread life. However I suggest that you inflate at 42/40 psi to promote even tread wear.
Patrick Wong is online now
Old 07-23-2008, 02:39 PM   #13
doubleg2005
doubleg2005's Avatar
Package: #3 Touring
every time i take my Touring in for an oil change and tire rotation, I ask them to look at the sidewall ratings on the tires (51) and inflate the fronts to 50 and rears to 48. after they finish i look at the tires and can actually SEE that they are too low, and when I ask about it... without fail, they have looked not at the sidewall, but at the door sticker that suggests to inflate to 35 and have put all four tires at 35 psi.
when i ask them to look at the sidewall or to allow me to use their air compressor, they cite that that would create an unsafe environment. thank goodness Brookshire's offers free air...
"Pablo"
2007 Prius Touring, Black, Pkg. 3
Born: July 13, 2007
doubleg2005 is offline
Old 07-23-2008, 02:50 PM   #14
Fraser
Just talked with a Goodyear dealer about Integrities. He recommended using the door panel figures, adding the tire is pretty good for its type. I replied that many Prius owners go to max or near-max of the tire. He said that will wear out the center tread early. I countered that mileage gets better with higher pressures. He shrugged, we talked about our various diseases. Knowledgeable guy, and he may be right about tire pressures. I intent to at least try the higher pressures for a while. He strongly recommends the TripleTread, BTW.
Fraser is offline
Old 07-24-2008, 02:51 AM   #15
F8L
Collecting Data on Nature
F8L's Avatar
Friends: 35
In terms of the Integrity he is wrong about excess tire pressures wearing out the center of the tire. There have been enough anecdotal evidence to prove otherwise.
I've got over 40k miles on these ones with pressures exceeding 50psi. Right now they are at 66/64. I'll likely drop em to 60psi or 62/60.
Dealer's tire inflation rate-integrity-35k-.jpg   Dealer's tire inflation rate-inner-tread.jpg   Dealer's tire inflation rate-middle-tread.jpg   Dealer's tire inflation rate-outer-tread.jpg
F8L is offline
Old 07-24-2008, 02:08 PM   #16
Sheepdog
C'Mere Sheepie!
Sheepdog's Avatar
Friends: 6
some of your dealers service advisor's are real idiot's! I told my dealer exactly what I wanted in my tires. 42/40 and he started to object but I asked him how he liked me coming back?
My service file now states to maintain 42/40 and it's in my service records that they do it. and yes I also check to make sure....
Sheepdog is offline
Old 07-24-2008, 03:44 PM   #17
dwreed3rd
Package: #3 Touring
Way to go Sheepdog!
dwreed3rd is offline
Old 07-24-2008, 06:57 PM   #18
pt95148
My dealer actually told me to ignore the psi on the door plate and to go higher as he said the Prius drives and glides better. I checked the tires when cold and found that they inflated to 40 all round.
I just went in for a warranty check on alignment, nothing else done.
When I took it back, it was washed!
"zero' dollars paid and a free car wash
Totally did not expect that!
pt95148 is offline
dealer's, inflation, rate, tire
If inflation is bad, why is deflation bad? burritos Fred's House of Pancakes 16 08-21-2007 12:02 AM
tire inflation clifford Gen II Prius Technical Discussion 12 07-26-2006 12:16 PM
Tire Inflation gliffe Gen II Prius Main Forum 11 07-07-2006 12:05 PM
Best Tire Inflation by Experience? jillsidious Gen II Prius Care, Maintenance and Troubleshooting 2 01-06-2005 04:26 PM
Dealer's Allocations NorthStar Gen II Prius Main Forum 3 03-10-2004 01:14 PM
