This is a discussion on At 65 MPH my Prius shifted into neutral ? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I could not believe it but I had just filled up with fuel and was about 6 miles down the ...
Old 07-25-2008, 10:29 PM   #1
Chuck41
Default At 65 MPH my Prius shifted into neutral ?
I could not believe it but I had just filled up with fuel and was about 6 miles down the road when the car went out of CC and started to slow down. My first goal was to get off the road. Before I got stopped I noticed there was no power flow of any kind showing on the MFD. I run a scangauge II and checked for error codes but none were available. One thing I did not do was to look at the dash indication of the where the shifter was indicated. I put the car in D and away we went. Very SCARY !!
The only unusual thing that might of caused this was we received a cell phone call at the same time as the incident. I keep the cell phone in the second cup holder back from the dash.
We have had one other incident that is not explainable. We were at an Auto Parts Store and we could not use the FOB to lock the car. I blamed it on the stores security system.
Chuck41 is offline
Old 07-26-2008, 01:28 AM   #2
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
Default Re: At 65 MPH my Prius shifted into neutral ?
Hi Chuck,
If you are on the tall side, is it possible that your right knee might have bumped against the shift lever?
Patrick Wong is offline
Old 07-26-2008, 04:10 AM   #3
N3FOL
N3FOL's Avatar
I will admit that the shift level is easy to bump. I've done it several times and luckily have not accidentally shifting the car to N while in motion.
N3FOL is offline
Old 07-26-2008, 05:24 AM   #4
Fraser
I'm wondering how the driver's knee could move the shift lever to neutral. It would have had to pull the lever from right to left.
Fraser is offline
Old 07-26-2008, 06:04 AM   #5
Neicy
Neicy's Avatar
Friends: 6
Neutral is the default gear in the event that the shifter knob is moved out of D or B while the vehicle is moving forward at any speed that would cause damage to the engine. I have bumped it a few times by accident, but never hard enough to knock it out of D. I was once pulling out of a parking space and instead of pushing the power for the radio, I hit the park button. I was just barely moving so the car did as I requested and stopped. Very abruptly. Boy, was that a surprise. My first thought was too many P buttons too close together. My second thought was pay better attention to what I'm doing.
Neicy
2009 Silver Pine Mica Pkg #2
2 Scangauge IIs v 3.15 with X-gauge
Neicy is offline
Old 07-26-2008, 01:04 PM   #6
edthefox5
edthefox5's Avatar
Don't know about the neutral thing have never heard that before but no SKS is common. I learned here that your cell phone can interfere with it. Mine does on my belt. I have to turn my waist/phone away from the car to make the SKS lock most of the time.
Your right about the store too. A local TV station reported a store at the mall that had a dead zone all the way around it into the parking lot. People couldn't lock there cars or if could lock couldn't get them back open later. It was there security system blasting the lot with power.The anti-theft devices on clothes reader if I remember correctly.
edthefox5 is offline
Old 07-26-2008, 01:13 PM   #7
narf
narf's Avatar
Is it possible that when you reached for the cell phone or the phone controls you bumped the shifter into neutral?
narf is offline
neutral, prius, shifted
Prius Parking Footbrake and N (neutral) Stick Position. ronhowell Gen II Prius Technical Discussion 21 11-09-2007 07:58 PM
Hey Prius Clubs...Make your cars Carbon Neutral! Suburban600 Environmental Discussion 0 06-17-2007 08:36 AM
Automatic Car Wash: How to put the 2004 Prius in neutral: Ken Cooper Gen II Prius Main Forum 53 08-08-2005 09:41 AM
Help, it won't go into neutral! mpruis Gen II Prius Main Forum 6 04-07-2005 10:44 AM
MFD (touch screen) buttons shifted left, now useless... hdrygas Gen II Prius Care, Maintenance and Troubleshooting 2 07-08-2004 07:38 AM
