This is a discussion on noise when braking, even when engine is off within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hello. I have a 2008 Prius, bought in April. I've recently noticed a relatively loud noise coming from under the ...
Old 07-28-2008, 11:58 PM   #1
TonyD50
Default noise when braking, even when engine is off
Hello. I have a 2008 Prius, bought in April. I've recently noticed a relatively loud noise coming from under the hood, directly in front of the driver. It occurs when braking at low speeds, and sometimes on acceleration from a complete stop. For the first few minutes after turning off the engine, you can hear the noise when you step on the brake. It sounds like a very rapid, machine-gun fast clicking. Sorry for the poor description, but it's the best I can do. A Toyota mechanic said that it's the ABS pump, and that it always made the noise, and that I just didn't notice it before. I'm concerned that he might have blown it off. Has anyone had this problem? Thank you!
TonyD50 is offline
Old 07-29-2008, 08:13 AM   #2
realale
realale's Avatar
Default Re: noise when braking, even when engine is off
We've noticed this too. My searches on the forum indicated it was something to do with the brake system as well.
Mine seems to be more prevalent when I'm carrying more passengers or cargo, but it definitely happens from time to time on both braking and acceleration when it's just me in the car as well. I'll be interested to see what the more experienced say. It definitely makes me nervous.
Great description of the noise, by the way! I always think it sounds like a Vibraslap (most like the LP 209 soundclip, but not as metallic, on this site: Latin Percussion: LP Vibra-SlaP II ). Ours lasts about 1.5 seconds each time.
Mods:
NuShield MFD Screen Protector
Rear Bumper Applique (the clear one)
JDM 20" Rear Wiper
42/40 tire pressure
realale is offline
Old 07-29-2008, 09:10 AM   #3
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
The noise likely is from the brake pressure accumulator pump. If you repeatedly depress the brake pedal while the car is READY, you should hear the pump running to rebuild pressure in the system. If that is the same sound that you expressed a concern about, then no worries.
Patrick Wong is offline
Old 07-29-2008, 09:12 AM   #4
This is the brake accumulator pump. The power brakes on the Prius are driven by an electric pump, since the engine does not run continuously as it does on a normal car. The accumulator pump kicks on about every third time you use the brakes. It builds pressure in a little tank, which is then used to power the hydraulic system. The accumulator pump makes a buzzing or ratcheting sound.
The other noise you hear after powering off is the coolant transfer pump. The transfer pump saves hot engine coolant in a thermos bottle, which is then used later to preheat the engine. The coolant transfer pump makes a whirring sound.
Black 2006 package #7
Northern Michigan
Old 07-29-2008, 11:34 AM   #5
TonyD50
Thank you for the input. I have an appointment with a dealer today. I'll let you know what they say.
TonyD50 is offline
Old 07-29-2008, 09:04 PM   #6
TonyD50
Well, the mechanic who worked on my car doesn't know quite what's wrong with it. He thinks the noise is much too loud. They kept the car and put me in a loaner. I'm glad that this dealer isn't blowing it off, as did the dealer who sold me the car.
TonyD50 is offline
Old 08-02-2008, 04:52 PM   #7
TonyD50
Well, I finally got my car back. It took 3 days. They said that the noise was from the "electronic brake booster." They contacted the "tech line" and were told to reset the linear calibration. They did that. Nothing has changed. The noise is the same as before they made the adjustment. I've been told that it's not a safety or drivability problem, so I'm going to ignore it.
TonyD50 is offline
Old 08-03-2008, 09:48 PM   #8
It's the brake accumulator pump. I have this comment on a hot key, so I can press it once to answer this question. It's one of the most common.
Old 08-11-2008, 07:49 PM   #9
Large
Thanks, Tom! for the clear reply to the question.
I have found this in various forums, so I will ignore this noise, unless it gets worse or I feel it affects performance. It's just unusual to have this noise when you hit the breaks (as you say, approx every third time or so and sometimes when accelerating out of a stop).
But I guess it comes with driving around with a lot of technology under the hood and the seats and the trunk and everywhere.
Large is offline
braking, engine, noise
Strange noise when braking?? Bikeman Gen II Prius Care, Maintenance and Troubleshooting 11 04-16-2008 09:48 PM
funny noise when braking at slow speeds pmanza Gen II Prius Technical Discussion 9 09-15-2007 04:46 PM
Whirring noise while braking?? BethlehemPrius Gen II Prius Care, Maintenance and Troubleshooting 4 07-12-2007 11:05 PM
Rhythmic noise when braking janna Gen II Prius Care, Maintenance and Troubleshooting 0 05-12-2007 11:54 PM
loud noise while braking and or coasting statultra Gen II Prius Technical Discussion 0 02-27-2007 09:37 PM
