| This is a discussion on 10-month storage within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I'll be going out of the country for about 10 months and am trying to decide what to do with ... |
10-month storage
| Junior Member Join Date: Aug 2008 Location: minnesota
My Car: 2003 Prius Model: Package: Base Thanks: 0
Friends: 0 | I'll be going out of the country for about 10 months and am trying to decide what to do with my 2003 prius. After reading other threads, I plan to disconnect the negative terminal of the battery, then have my dad reconnect it every 2 months, then put the car in READY for 30 minutes. Does that sound about right? Or should I just sell it off and buy a new prius when i get back? P.S. I'm not mechanically inclined, and playing with the battery makes me nervous. |
My Car: 2004 Prius Model: Package: Base Thanks: 0
Friends: 10 | Quote:
12 Volt-1 Amp Charger and Maintainer JeffD | |
Friends: 44 | |
| Junior Member Join Date: May 2008 Location: Texas
Friends: 0 | Worst case, dont buy a new Prius when you return, just buy a new battery. But best case, just buy one of these battery chargers and leave it connected while gone: or I have the Schumacher, and it's great. These are low power battery chargers (more specifically, a "maintainer"), which are expressly designed to be used during long storage to keep the battery fully charged. These are very small chargers, which may take a full day to recharge a low battery, but is designed then to easily and safely keep the battery fully charged in storage. Basically the same effect on the battery as leaving the car in Ready 100% of the time, which is a very good thing to do for the battery. Keeping the lead-acid battery fully charged is the best possible thing you can do for it to insure its long life. This prevents the sulfurization which always occurs in a low battery, which ruins the battery. These just clip on in the fuse box under the hood. Be very careful to observe correct polarity, red to red, and black to ground. However for 10 months, I would disconnect the battery from the car, and connect the charger to the battery. Be sure to turn off the Smart Key button under the steering wheel, to prevent the continual battery drain that it causes. Last edited by WayneF; 08-03-2008 at 10:23 AM. |
| battery, garage, storage |
| any issues with 3 month storage | litespeed | Gen II Prius Main Forum | 4 | 04-12-2008 07:02 PM |
| The Secret Storage Bin | abq sfr | Gen II Prius Main Forum | 47 | 09-05-2007 07:23 PM |
| extended storage | Tadashi | Gen II Prius Main Forum | 15 | 02-05-2007 07:05 PM |
| Luggage storage box | ml86 | Gen II Prius Main Forum | 2 | 04-13-2006 05:18 PM |
| Trash storage | tedb | Gen II Prius Main Forum | 60 | 03-22-2006 10:26 PM |
